dBm0到底是什么意思?
8390|3
gohunter|  楼主 | 2007-6-24 16:34 | 显示全部楼层 |阅读模式
AN, ce, IO, TE, TI
找了下面的解释,但还是不明白,谁来解解谜底?
dBm0 is an abbreviation for the power in dBm measured at a zero transmission level point.
dBm0 is a concept used (amongst other areas) in audio/telephony processing since it allows a smooth integration of analog and digital chains. Noticeably, for A-law and μ-law CODECS the standards defines a sequence which has a 0dBm0 output.
Note1: a consequence for the A-law and μ-law CODECS of the 0dBm0 definition is that they have a respective 3.14dBm0 and 3.17dBm0 maximum output (ratio between the max amplitude of the sinewave and the maximum code).
Note2: 0dBm0 is often replaced by or used instead of digital milliwatt or zero transmission level point.
jimsboy| | 2007-6-25 00:14 | 显示全部楼层
1mw的功率
如果是电压就一定要在某个阻抗下.否则无意义
gohunter|  楼主 | 2007-6-26 20:18 | 显示全部楼层
在IDT821024的datasheet找到以下定义
0dBm0 is defined as 0.6832Vrms for A-law and 0.6778 Vrms for m-law, both for 600 ohm load.
chunyang| | 2007-6-26 21:05 | 显示全部楼层
一般在各种分贝单位中,0是基准
但不同定义的算法和条件不同,楼主其实应该已经知道了,0dBm0指600欧负载下A率有效电压0.6832V及u率有效电压0.6778V为基准参考值,其它值是基准值的相对指标。
