[技术问答]
为何**作mini58的ADC寄存器全部是0.
1001|6
我在处理mini58的ADC,操作ADC->CHEN,ADC->STATUS,ADC->CTL几个寄存器都是0,我用的是Keil MDK5.23.
难道ADC的寄存器很特殊。
初始化
        CLK_EnableModuleClock(ADC_MODULE);
     CLK_SetModuleClock(ADC_MODULE,CLK_CLKSEL1_ADCSEL_HIRC,CLK_CLKDIV_ADC(5));//用的片内晶振。
/* Set P5.3 to ADC channel 0 input pin */
    SYS->P3_MFP |= SYS_MFP_P30_ADC_CH6;
                SYS->P3_MFP |= SYS_MFP_P31_ADC_CH7;
          SYS->P1_MFP |= SYS_MFP_P14_ADC_CH4;
    /* To update the variable SystemCoreClock */
          P3->DINOFF |= (1 << 0) << GP_DINOFF_DINOFF6_Pos;
                P3->DINOFF |= (1 << 1) << GP_DINOFF_DINOFF7_Pos;
                P1->DINOFF |= (1 << 4) << GP_DINOFF_DINOFF4_Pos;
//        ADC->CHEN=BAadc_channel;
                switch(BAadc_channel)
                        case 0:
                                        ADC->CHEN=0x01;
                                break;
                        case 1:
                                  ADC->CHEN=0x02;
                                break;
                        case 2:
                                  ADC->CHEN=0x04;
                                break;
                        case 3:
                                 ADC->CHEN=0x08;
                                break;
                        case 4:
                                 ADC->CHEN=0x10;
                                break;
                        case 5:
                                 ADC->CHEN=0x20;
                                break;
                        case 6:
                                 ADC->CHEN=0x40;
                                break;
                        case 7:
                                 ADC->CHEN=0x80;
                                break;
                        case 8:
                                 ADC->CHEN=0x180;
                                break;
                        default:
                                break;
    // Power on ADC
    ADC_POWER_ON(ADC);
                //ADC_SET_INPUT_CHANNEL(ADC,BAadc_channel);
          ADC_EnableInt(ADC, ADC_ADIF_INT);
    NVIC_EnableIRQ(ADC_IRQn);
                  if(!ADC_IS_BUSY(ADC)) {
            ADC_START_CONV(ADC);
无论怎么操作ADC->CHEN,ADC->STATUS,ADC->CTL几个寄存器都是0,请高手指点迷津
huangcunxiake| | 2017-8-13 19:37 | 只看该作者
不是很懂,你看看官方的例程吧,我都是看着改。
yiy| | 2017-8-14 21:30 | 只看该作者
* [url=home.php?mod=space&uid=288409]@file[/url]     main.c
* [url=home.php?mod=space&uid=895143]@version[/url]  V1.00
* $Revision: 2 $
* $Date: 15/09/24 5:50p $
* [url=home.php?mod=space&uid=247401]@brief[/url]    Demonstrate ADC function by repeatedly convert the input of ADC
*           channel 5 (P1.5) and shows the result on UART console.
* @note
* Copyright (C) 2015 Nuvoton Technology Corp. All rights reserved.
#include <stdio.h>
#include "Mini51Series.h"
void ADC_IRQHandler(void)
    uint32_t u32Flag;
    // Get ADC comparator interrupt flag
    u32Flag = ADC_GET_INT_FLAG(ADC, ADC_ADF_INT);
    // Get ADC convert result
    printf("Convert result is %x\n", (uint32_t)ADC_GET_CONVERSION_DATA(ADC, 0));
    ADC_CLR_INT_FLAG(ADC, u32Flag);
void SYS_Init(void)
    /* Init System Clock        */
    /* Unlock protected registers */
    SYS_UnlockReg();
    /* Set P5 multi-function pins for XTAL1 and XTAL2 */
    SYS->P5_MFP = SYS_MFP_P50_XTAL1 | SYS_MFP_P51_XTAL2;
    /* Enable external 12MHz XTAL, HIRC */
    CLK->PWRCON = CLK_PWRCON_OSC22M_EN_Msk | CLK_PWRCON_HXT;
    /* Waiting for clock ready */
    CLK_WaitClockReady(CLK_CLKSTATUS_OSC22M_STB_Msk | CLK_CLKSTATUS_XTL_STB_Msk);
    /* Switch HCLK clock source to XTL */
    CLK_SetHCLK(CLK_CLKSEL0_HCLK_S_XTAL,CLK_CLKDIV_HCLK(1));
    /* Enable IP clock */
    CLK_EnableModuleClock(UART_MODULE);
    /* Select IP clock source */
    CLK_SetModuleClock(UART_MODULE,CLK_CLKSEL1_UART_S_XTAL,CLK_CLKDIV_UART(1));
    CLK_SetModuleClock(ADC_MODULE,CLK_CLKSEL1_ADC_S_XTAL,CLK_CLKDIV_ADC(6));
    /* Init I/O Multi-function        */
    /* Set P0 multi-function pins for UART RXD, TXD */
    SYS->P0_MFP = SYS_MFP_P00_TXD | SYS_MFP_P01_RXD;
    /* Set P1 multi-function pin ADC channel 5 input*/
    SYS->P1_MFP = SYS_MFP_P15_AIN5;
    /* Analog pin OFFD to prevent leakage */
    P1->OFFD |= (1 << 5) << GPIO_OFFD_OFFD_Pos;
    SystemCoreClockUpdate();
    /* Lock protected registers */
    SYS_LockReg();
int32_t main (void)
    /* Init System, IP clock and multi-function I/O
       In the end of SYS_Init() will issue SYS_LockReg()
       to lock protected register. If user want to write
       protected register, please issue SYS_UnlockReg()
       to unlock protected register if necessary */
    SYS_Init();
    /* Init UART to 115200-8n1 for print message */
    UART_Open(UART0, 115200);
    printf("\nThis sample code demonstrate ADC channel 5 conversion and printf the result on UART\n");
    // Enable channel 5
    ADC_Open(ADC, 0, 0, 0x01 << 5);
    // Power on ADC
    ADC_POWER_ON(ADC);
    // Enable ADC convert complete interrupt
    ADC_EnableInt(ADC, ADC_ADF_INT);
    while(1) {
        // Trigger ADC conversion if it is idle
/*** (C) COPYRIGHT 2015 Nuvoton Technology Corp. ***/
* @file     main.c
* @version  V1.00
* $Revision: 6 $
* $Date: 15/10/06 1:19p $
* @brief    Demonstrate ADC conversion and comparison function by monitoring
*           the conversion result of channel 0.
* @note
* Copyright (C) 2013 Nuvoton Technology Corp. All rights reserved.
#include <stdio.h>
    uint32_t u32Flag;
    u32Flag = ADC_GET_INT_FLAG(ADC, ADC_CMP0_INT | ADC_CMP1_INT);
    if(u32Flag & ADC_CMP0_INT)
        printf("Channel 0 input < 0x200\n");
    if(u32Flag & ADC_CMP1_INT)
        printf("Channel 0 input >= 0x200\n");
void SYS_Init(void)
    SYS_UnlockReg();
    SYS->P5_MFP &= ~(SYS_MFP_P50_Msk | SYS_MFP_P51_Msk);
    SYS->P5_MFP |= (SYS_MFP_P50_XTAL1 | SYS_MFP_P51_XTAL2);
    /* Enable external 12MHz XTAL (UART), internal 22.1184MHz */
    CLK->PWRCON = CLK_PWRCON_XTL12M | CLK_PWRCON_IRC22M_EN_Msk;
    CLK_WaitClockReady(CLK_CLKSTATUS_XTL_STB_Msk | CLK_CLKSTATUS_IRC22M_STB_Msk);
    /* Enable UART and ADC clock */
    CLK->APBCLK = CLK_APBCLK_UART_EN_Msk | CLK_APBCLK_ADC_EN_Msk;
    /* Select UART clock source from external crystal*/
    CLK->CLKSEL1 = (CLK->CLKSEL1 & ~CLK_CLKSEL1_UART_S_Msk) | CLK_CLKSEL1_UART_S_XTAL;
    /* ADC clock source is 22.1184MHz, set divider to (3 + 1), ADC clock is 22.1184/4 MHz */
    CLK->CLKDIV |= (3 << CLK_CLKDIV_ADC_N_Pos);
    /* Update System Core Clock */
    /* User can use SystemCoreClockUpdate() to calculate SystemCoreClock and CycylesPerUs automatically. */
    /* Set P1 multi-function pins for UART RXD, TXD */
    SYS->P5_MFP = SYS_MFP_P53_AIN0;
    P5->OFFD |= (1 << 3) << GPIO_OFFD_OFFD_Pos;
    SYS_LockReg();
int32_t main (void)
    SYS_Init();
    UART_Open(UART, 115200);
    printf("\nThis sample code demonstrate ADC conversion and comparison function\n");
    printf("by monitoring the conversion result of channel 0 (P5.3)\n");
    // Enable channel 0
    ADC_Open(ADC, 0, 0, 0x01);
    // Power on ADC
    ADC_POWER_ON(ADC);
    // Configure and enable Comparator 0 to monitor channel 0 input less than 0x200
    ADC_ENABLE_CMP0(ADC, 0, ADC_CMP_LESS_THAN, 0x200, 16);
    // Configure and enable Comparator 1 to monitor channel 0 input greater or equal to 0x200
    ADC_ENABLE_CMP1(ADC, 0, ADC_CMP_GREATER_OR_EQUAL_TO, 0x200, 16);
    // Enable ADC comparator 0 and 1 interrupt
    ADC_EnableInt(ADC, ADC_CMP0_INT);
    ADC_EnableInt(ADC, ADC_CMP1_INT);
    while(1) {
/*** (C) COPYRIGHT 2013 Nuvoton Technology Corp. ***/
huangcunxiake| | 2017-8-14 22:11 | 只看该作者
不要使用寄存器搞。
21mengnan| | 2017-8-14 22:31 | 只看该作者
mini51好像可以用PIN tool配置管脚
21mengnan| | 2017-8-14 22:32 | 只看该作者
