[牛人杂谈]
八月新唐+NuTiny-SDK-M058S,最简单的开发板
1265|15
NuTiny-SDK-M058S是新唐推出的最简单的开发板了。。学习ARM单片机的好帮手,当年我在二姨家参加新唐的活动得的奖品。
今天找出来参加这个活动。
先看看这个板子。。保存的比较好呢。
看到了吧,这个板子左边是最小系统,外加一个复位按键,还有一个LED。。上面没有焊接管座,为了使用后面我焊接了排针。
然后我就按照官方的例子随便改吧改吧。
* [url=home.php?mod=space&uid=288409]@file[/url]     main.c
* [url=home.php?mod=space&uid=895143]@version[/url]  V3.0
* $Revision: 2 $
* $Date: 15/02/06 10:22a $
* [url=home.php?mod=space&uid=247401]@brief[/url]    Perform A/D Conversion with ADC continuous scan mode.
* @note
* Copyright (C) 2014 Nuvoton Technology Corp. All rights reserved.
#include <stdio.h>
#include "M058S.h"
#define PLL_CLOCK       50000000
/* Define Function Prototypes        */
void SYS_Init(void);
void UART0_Init(void);
void AdcContScanModeTest(void);
void SYS_Init(void)
    /* Init System Clock        */
    /* Enable Internal RC 22.1184 MHz clock */
    CLK_EnableXtalRC(CLK_PWRCON_OSC22M_EN_Msk);
    /* Waiting for Internal RC clock ready */
    CLK_WaitClockReady(CLK_CLKSTATUS_OSC22M_STB_Msk);
    /* Switch HCLK clock source to Internal RC and HCLK source divide 1 */
    CLK_SetHCLK(CLK_CLKSEL0_HCLK_S_HIRC, CLK_CLKDIV_HCLK(1));
    /* Enable external XTAL 12 MHz clock */
    CLK_EnableXtalRC(CLK_PWRCON_XTL12M_EN_Msk);
    /* Waiting for external XTAL clock ready */
    CLK_WaitClockReady(CLK_CLKSTATUS_XTL12M_STB_Msk);
    /* Set core clock as PLL_CLOCK from PLL */
    CLK_SetCoreClock(PLL_CLOCK);
    /* Enable UART module clock */
    CLK_EnableModuleClock(UART0_MODULE);
    /* Enable ADC module clock */
    CLK_EnableModuleClock(ADC_MODULE);
    /* Select UART module clock source */
    CLK_SetModuleClock(UART0_MODULE, CLK_CLKSEL1_UART_S_HXT, CLK_CLKDIV_UART(1));
    /* ADC clock source is 22.1184 MHz, set divider to 7, ADC clock is 22.1184/7 MHz */
    CLK_SetModuleClock(ADC_MODULE, CLK_CLKSEL1_ADC_S_HIRC, CLK_CLKDIV_ADC(7));
    /* Init I/O Multi-function        */
    /* Set P3 multi-function pins for UART0 RXD and TXD */
    SYS->P3_MFP &= ~(SYS_MFP_P30_Msk | SYS_MFP_P31_Msk);
    SYS->P3_MFP |= SYS_MFP_P30_RXD | SYS_MFP_P31_TXD;
    /* Disable the P1.0 - P1.3 digital input path to avoid the leakage current */
    GPIO_DISABLE_DIGITAL_PATH(P1, 0xF);
    /* Configure the P1.0 - P1.3 ADC analog input pins */
    SYS->P1_MFP &= ~(SYS_MFP_P10_Msk | SYS_MFP_P11_Msk | SYS_MFP_P12_Msk | SYS_MFP_P13_Msk);
    SYS->P1_MFP |= SYS_MFP_P10_AIN0 | SYS_MFP_P11_AIN1 | SYS_MFP_P12_AIN2 | SYS_MFP_P13_AIN3 ;
/* Init UART        */
void UART0_Init()
    /* Reset IP */
    SYS_ResetModule(UART0_RST);
    /* Configure UART0 and set UART0 Baudrate */
    UART_Open(UART0, 115200);
/* Function: ADC_GetConversionRate        */
/* Parameters:        */
/*   None.        */
/* Returns:        */
/*      Return the A/D conversion rate (sample/second)                                                     */
/* Description:        */
/*   The conversion rate depends on the clock source of ADC clock.                                         */
/*   It only needs 21 ADC clocks to complete an A/D conversion.                                            */
static __INLINE uint32_t ADC_GetConversionRate()
    uint32_t u32AdcClkSrcSel;
    uint32_t u32ClkTbl[4] = {__HXT, 0, 0, __HIRC};
    /* Set the PLL clock frequency */
    u32ClkTbl[1] = PllClock;
    /* Set the system core clock frequency */
    u32ClkTbl[2] = SystemCoreClock;
    /* Get the clock source setting */
    u32AdcClkSrcSel = ((CLK->CLKSEL1 & CLK_CLKSEL1_ADC_S_Msk) >> CLK_CLKSEL1_ADC_S_Pos);
    /* Return the ADC conversion rate */
    return ((u32ClkTbl[u32AdcClkSrcSel]) / (((CLK->CLKDIV & CLK_CLKDIV_ADC_N_Msk) >> CLK_CLKDIV_ADC_N_Pos) + 1) / 21);
/* Function: AdcContScanModeTest        */
/* Parameters:        */
/*   None.        */
/* Returns:        */
/*   None.        */
/* Description:        */
/*   ADC continuous scan mode test.        */
void AdcContScanModeTest()
    uint8_t  u8Option;
    uint32_t u32ChannelCount;
    int32_t  i32ConversionData;
    printf("\n\nConversion rate: %d samples/second\n", ADC_GetConversionRate());
    printf("\n");
    printf("+----------------------------------------------------------------------+\n");
    printf("|                            ADC连续扫描测试                            |\n");
    printf("\nIn this test, software will get 2 cycles of conversion result from the specified channels.\n");
    while(1)
        printf("\n\n选择输入模式:\n");
        printf("  [1] 单极性信号输入 (通道 0, 1, 2 和 3)\n");
        printf("  [2] 差分信号输入 (输入通道为 0 和 1)\n");
        printf("  其他按键: 推出连续扫描模式\n");
        u8Option = getchar();
        if(u8Option == '1')
            /* Set the ADC operation mode as continuous scan, input mode as single-end and
                 enable the analog input channel 0, 1, 2 and 3 */
            ADC_Open(ADC, ADC_ADCR_DIFFEN_SINGLE_END, ADC_ADCR_ADMD_CONTINUOUS, 0xF);
            /* Power on ADC module */
            ADC_POWER_ON(ADC);
            /* clear the A/D interrupt flag for safe */
            ADC_CLR_INT_FLAG(ADC, ADC_ADF_INT);
            /* start A/D conversion */
            ADC_START_CONV(ADC);
            /* Wait conversion done */
            while(!ADC_GET_INT_FLAG(ADC, ADC_ADF_INT));
            for(u32ChannelCount = 0; u32ChannelCount < 4; u32ChannelCount++)
                i32ConversionData = ADC_GET_CONVERSION_DATA(ADC, u32ChannelCount);
                printf("Conversion result of channel %d: 0x%X (%d)\n", u32ChannelCount, i32ConversionData, i32ConversionData);
            /* Stop A/D conversion */
            ADC_STOP_CONV(ADC);
        else if(u8Option == '2')
            /* Set the ADC operation mode as continuous scan, input mode as differential and
               enable analog input channel 0 and 2 */
            ADC_Open(ADC, ADC_ADCR_DIFFEN_DIFFERENTIAL, ADC_ADCR_ADMD_CONTINUOUS, 0x5);
            ADC_POWER_ON(ADC);
            for(u32ChannelCount = 0; u32ChannelCount < 2; u32ChannelCount++)
                i32ConversionData = ADC_GET_CONVERSION_DATA(ADC, u32ChannelCount * 2);
                printf("Conversion result of differential input pair %d: 0x%X (%d)\n", u32ChannelCount, i32ConversionData, i32ConversionData);
            ADC_STOP_CONV(ADC);
        else     return ;
/* MAIN function        */
int main(void)
    /* Unlock protected registers */
    SYS_UnlockReg();
    /* Init System, IP clock and multi-function I/O */
    SYS_Init();
    /* Lock protected registers */
    SYS_LockReg();
    /* Init UART0 for printf */
    UART0_Init();
    /* SAMPLE CODE        */
    printf("\n八月,新唐你好!");
    printf("\nHello,21ic.com!");
          printf("\n接下来进入ADC测试选项……");
    printf("\n系统时钟频率: %d Hz", SystemCoreClock);
    /* Continuous scan mode test */
    AdcContScanModeTest();
                printf("\n MyID:gaoyang9992006");
    /* Disable ADC module */
    ADC_Close(ADC);
    /* Disable ADC IP clock */
    CLK_DisableModuleClock(ADC_MODULE);
    /* Disable External Interrupt */
    NVIC_DisableIRQ(ADC_IRQn);
    printf("\nExit ADC sample code\n");
    while(1);
gaoyang9992006|  楼主 | 2017-8-13 16:24 | 只看该作者
这里我发现个奇妙的问题,如果你默认的情况下,保存的文件,中文会乱码,这个在好多朋友发帖里可以看到,。解决方法如下:
在编辑里,找到最后一个配置项目,看图中的内容,然后选择图中的保存格式。。。就可以完美解决中文乱码了,这样复制到网页里面也不乱了。
gaoyang9992006|  楼主 | 2017-8-13 16:25 | 只看该作者
完成了这些,烧录代码测试。
运行的很完美,通过按1和2,可以选择不同的测试模式。。
huangcunxiake| | 2017-8-13 21:25 | 只看该作者
这板子真漂亮。
598330983| | 2017-8-14 11:58 | 只看该作者
懂了,原来这么搞才不会有乱码。
598330983| | 2017-8-14 16:08 | 只看该作者
楼主没有打印自己的ID啊。哈哈。。
gaoyang9992006|  楼主 | 2017-8-14 16:09 | 只看该作者
598330983 发表于 2017-8-14 16:08
楼主没有打印自己的ID啊。哈哈。。
多谢提醒,一会儿重新搞了,补上。
dongnanxibei| | 2017-8-14 16:40 | 只看该作者
我看看你们都有什么板子。
gejigeji521| | 2017-8-15 20:21 | 只看该作者
观摩一下楼主的方法,怎么搞的汉字。
zhuotuzi| | 2017-8-19 18:19 | 只看该作者
真是最简单的板子,不过越简单那是越好玩。
wanduzi| | 2017-8-19 21:57 | 只看该作者
相当不错,原来可以这么玩。
huahuagg| | 2017-8-19 22:19 | 只看该作者
看你们晒板子,真捉急。
goodgsq| | 2017-8-28 13:15 | 只看该作者
  真不错。
稳稳の幸福| | 2017-8-28 15:44 | 只看该作者
下次有板子喊着我。
认证:西安公路研究院南京院
简介:主要工作从事监控网络与通信网络设计,以及从事基于嵌入式的通信与控制设备研发。擅长单片机嵌入式系统物联网设备开发,音频功放电路开发。
1893
