[STM8] 意法半导体扩展并增强了超低功耗的STM8L产品线
4367|6
 楼主| 香水城 发表于 2010-9-20 18:33 | 显示全部楼层 |阅读模式
STMicroelectronics Extends and Enhances STM8L Microcontroller Family, Leveraging Ultra Low-Power EnergyLite™ Technology
Latest 8-bit microcontrollers increase program memory, user-interface support, timekeeping capabilities, and security features for advanced, power-conscious applications
Geneva, September 16,2010 - STMicroelectronics (NYSE: STM), a world-leading supplier of microcontrollers for consumer, medical, and industrial applications, has extended its STM8L EnergyLite™ ultra low-power microcontroller family with new devices offering enhanced features, such as larger program/data memory, high-accuracy time-keeping, a controller for as many as16 touch-sensitive keys, and support for 128-bit AES encryption.
The three variants of the STM8L family are the STM8L151, the STM8L152, and the STM8L162. Each of the new devices has 64 Kbytes of Flash memory, effectively doubling the maximum program/data memory available to developers using the 8-bit STM8L family. SRAM density is also increased to 4 Kbytes. To these valuable new features, the STM8L152 also adds an enhanced LCD controller that supports larger segments. Aiming to provide increased security, the STM8L162 is the first device in a new line featuring on-chip 128-bit AES encryption.
Common to all the new devices is an enhanced Real-Time Clock (RTC) module offering sub-second accuracy, as well as support for calibration, enabling increased precision in applications requiring time-stamping and accurate synchronization. These applications include utility metering and use within RF networks. The hardware RTC and its associated automatic wake-up unit have combined current consumption below 1 microamp, allowing developers to use power-saving sleep modes to maximum effect.
To meet increased demand for touch sensitive user interfaces in many consumer and professional markets, the new STM8L devices also provide designers with a robust and power-efficient 16-channel touch controller. This provides capacity for 16 individual touch buttons or a combination of up to 10 buttons plus one rotary sensor, equivalent to a dial or knob, and one slider.
About ST’s EnergyLite Ultra Low-Power Platform:
The entire STM8L family (and ST’s STM32L family using the industry-standard 32-bit ARM® Cortex™-M3 CPU core) is built using ST’s EnergyLite ultra-low-power platform. This platform combines a proprietary 130nm ultra-low leakage process with ultra low-power non-volatile memory (EEPROM), and achieves dynamic current consumption as low as 150uA/MHz.
EnergyLite devices implement a voltage regulator capable of maintaining low operating current at low supply voltages, which provides extra flexibility for designers to minimize the overall energy consumption of their applications. Speed and functionality are not compromised, as the full CPU performance is maintained up to the maximum operating frequency at any supply voltage (Vdd) from 1.65V to 3.6V. In addition, integrated analog peripherals are fully functional at supply voltages down to 1.8V. This can help simplify design as well as helping to minimize overall power demand.
The platform also implements multiple power-management modes including a 5.1uA Low-Power Run mode, 3.0uA Low-Power Wait mode, 1.2uA Active Halt with full RTC, and down to 350nA Halt mode. The device can wake from Halt within 4us, enabling frequent use of the lowest-power mode.
Major features of STM8L151/152/162:
  • 16Kbyte to 64Kbyte Flash
  • Enhanced RTC module
  • Enhanced segment-LCD controller (STM8L152)
  • Support for 128-bit AES encryption (STM8L162)
  • Touch sensing - up to 16-channels
Common STM8L family features:
  • Package options from 20-pin QFN/TSSOP to 80-pin LQFP
  • Complete pin-out, peripheral and software compatibility between family members
  • Motor-control timer
  • Fast ADC and 2x12-bit DAC
  • Integrated DMA controller
The STM8L15x variants are in full production for Flash densities up to 32 Kbytes, at prices from $0.82* (in quantities of 1000) for the 16-Kbyte STM8L151. The 64-Kbyte STM8L152 and STM8L162 are now sampling to lead customers. Full production is scheduled for Q4 2010 priced from $1.13* (unit price for 1000). Prices for the STM8L family start at $0.57* (unit price for 1000) for the STM8L101 with 4 Kbytes of Flash. Further pricing options are available for larger volumes.
新闻来源:http://www.st.com/stonline/stappl/cms/press/news/year2010/p3067.htm
mcuisp 发表于 2010-9-20 19:53 | 显示全部楼层
12bitADC+2*12bit DAC,用来做语音处理,非常爽
 楼主| 香水城 发表于 2010-9-20 20:53 | 显示全部楼层
是的,我们做了一个实验,用ADC接上麦克风采集语音,再通过SPI存储在SD卡中,最后通过DAC播放出来,效果很不错。
哈哈,可以做个复读机,或者做个录音笔之类的,:lol
 楼主| 香水城 发表于 2010-9-20 21:05 | 显示全部楼层
意法半导体(ST)凭借EnergyLite™超低功耗技术扩大并强化STM8L系列微控制器
最新的8位微控制器扩大程序存储器容量,增强用户界面支持、定时功能以及先进低功耗应用要求的安全功能
中国,2010年9月21日 —— 全球领先的消费电子、医疗和工业应用微控制器供应商意法半导体(纽约证券交易所代码:STM),宣布其STM8L EnergyLite™系列超低功耗微控制器新增多款强化功能的产品,新产品不仅扩大了程序和数据存储器容量,同时提高了定时器的精度,增加一个16键触摸感应控制器,并支持128位AES加密算法。
这三款全新STM8L产品分别是STM8L151、STM8L152和STM8L162,均内置64KB闪存,将STM8L系列8位微控制器的用户可用程序和数据存储器的最大实际容量扩大一倍。 SRAM内存容量也扩大至4KB。除这些重要的新功能外,STM8L152还增加一个LCD控制器以支持更大的段显示。为提供更高的安全功能,意法半导体还推出一条片上128位AES加密算法的新产品线,STM8L162是该产品线的首款产品。
这三款新产品均提升了实时时钟(RTC)模块的性能,时钟精度达到亚秒级,并支持时间校正,在需要时间戳和精确同步的应用中,可提高定时精度。目标应用包括民生能源计量表以及无线射频网络单元。硬件实时时钟及相关的自动唤醒单元的总功耗低于1微安,开发人员可利用睡眠模式使节能效果达到最大化。
为满足消费电子和专业设备市场对触控用户界面日益增长的需求,全新STM8L微控制器还为设计人员提供一个稳健且高能效的16通道触感控制器,可控制16个独立液晶屏触摸按键或10个按键、一个相当于转盘或旋钮的旋转传感器、以及一个滑块。
关于意法半导体的EnergyLite超低功耗技术平台:
STM8L全系列产品(和基于工业标准32位ARM® Cortex™-M3 CPU内核的STM32L系列产品)的制造技术均采用意法半导体的EnergyLite超低功耗技术平台。这项平台整合了意法半导体独有的130nm超低功耗制程和超低功耗非易失性存储器(EEPROM),动态电流消耗低至150uA/MHz。
EnergyLite产品实现的稳压器能够在低电压下保持很低的工作电流,为设计人员最大限度降低应用的整体功耗提供了更多的灵活性。此项技术对微控制器的处理速度和功能没有任何影响,因为在1.65V到3.6V的电源电压(Vdd)范围内,CPU的整体性能可保持在最大频率的水平。此外,片上集成的模拟外设的正常工作电压降至1.8V,这有助于简化应用设计以及最大限度降低整体功耗需求。
该技术平台还实现了多种电源管理模式,包括5.1µA低功耗工作模式、3.0µA低功耗等待模式、1.2µA暂停模式(RTC正常运转)和350nA的停止模式。新器件可在4µs内从停止模式唤醒,为频繁使用最低功耗模式提供了可能。
STM8L151/152/162的主要特性:
• 16KB至64KB闪存
• 强化的RTC模块
• 强化的段LCD控制器(STM8L152)
• 支持128位AES加密算法(STM8L162)
• 16路触感控制器
STM8L系列产品的共同特性:
• 封装选择:20引脚QFN/TSSOP至80引脚 LQFP
• 全系列产品的管脚、外设和软件相互兼容
• 电机控制定时器
• 快速模数转换器(ADC)和2路12位数模数转换器(DAC)
• 内置DMA控制器
闪存容量高达32KB的STM8L15x产品已投入量产,64KB STM8L152 和 STM8L162目前正在向主要客户提供样片,预计2010年第四季度正式投产。
关于意法半导体
意法半导体是全球领先的半导体解决方案提供商,为各种应用领域的电子设备制造商提供创新的解决方案。凭借公司掌握的大量技术、设计能力和知识产权组合、战略合作伙伴关系和制造实力,意法半导体矢志成为多媒体融合和功率应用领域无可争议的行业领袖。2009年,公司净收入85.1亿美元。详情请访问意法半导体公司网站 www.st.com 或意法半导体中文网站 www.stmicroelectronics.com.cn
honami520 发表于 2010-9-21 07:48 | 显示全部楼层
怎么搞到样片啊,还好这些芯片要到第四季度才能投产,不然我新买的10片STM8L152C6就不是STM8L最高端的了!
STM8L103 发表于 2010-9-21 12:39 | 显示全部楼层
STM8L103怎么还没出
火箭球迷 发表于 2010-9-21 14:09 | 显示全部楼层
应该是可以申请到样片
认证:意法半导体(中国)投资有限公司
简介:STM32技术专家
596
