[C语言]
请问 循环展开(loop unrolling)相对于M0 与 M3 有何不同
781|1
mrbbsp|  楼主 | 2017-8-28 11:05 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
TI, TE, IO, rc, ps
在与一个朋友讨论时,发现 CMSIS DSP_lib 的函数中, 对于 M3核进行了循环展开,而M0并没有
请问 M3核 哪些特性 循环展开后 效率相对于M0核来说 效率更高?
-------------------------  以下是 CMSIS DSP_lib 的一个函数  ------------------------------------------------
* Copyright (C) 2010 ARM Limited. All rights reserved.
* $Date:        15. July 2011
* $Revision:         V1.0.10
* Project:             CMSIS DSP Library
* Title:            arm_mult_f32.c
* Description:        Floating-point vector multiplication.
* Target Processor: Cortex-M4/Cortex-M3/Cortex-M0
* Version 1.0.10 2011/7/15
*    Big Endian support added and Merged M0 and M3/M4 Source code.
* Version 1.0.3 2010/11/29
*    Re-organized the CMSIS folders and updated documentation.
* Version 1.0.2 2010/11/11
*    Documentation updated.
* Version 1.0.1 2010/10/05
*    Production release and review comments incorporated.
* Version 1.0.0 2010/09/20
* Version 0.0.5  2010/04/26
*    incorporated review comments and updated with latest CMSIS layer
* Version 0.0.3  2010/03/10
*    Initial version
#include "arm_math.h"
* @ingroup groupMath
* @defgroup BasicMult Vector Multiplication
* Element-by-element multiplication of two vectors.
* <pre>
*     pDst[n] = pSrcA[n] * pSrcB[n],   0 <= n < blockSize.
* </pre>
* There are separate functions for floating-point, Q7, Q15, and Q31 data types.
* @addtogroup BasicMult
* @brief Floating-point vector multiplication.
* @param[in]       *pSrcA points to the first input vector
* @param[in]       *pSrcB points to the second input vector
* @param[out]      *pDst points to the output vector
* @param[in]       blockSize number of samples in each vector
* @return none.
void arm_mult_f32(
  float32_t * pSrcA,
  float32_t * pSrcB,
  float32_t * pDst,
  uint32_t blockSize)
  uint32_t blkCnt;                               /* loop counters */
#ifndef ARM_MATH_CM0
/* Run the below code for Cortex-M4 and Cortex-M3 */
  /* loop Unrolling */
  blkCnt = blockSize >> 2u;
  /* First part of the processing with loop unrolling.  Compute 4 outputs at a time.
   ** a second loop below computes the remaining 1 to 3 samples. */
  while(blkCnt > 0u)
    /* C = A * B */
    /* Multiply the inputs and store the results in output buffer */
    *pDst++ = (*pSrcA++) * (*pSrcB++);
    /* Decrement the blockSize loop counter */
    blkCnt--;
  /* If the blockSize is not a multiple of 4, compute any remaining output samples here.
   ** No loop unrolling is used. */
  blkCnt = blockSize % 0x4u;
#else
  /* Run the below code for Cortex-M0 */
  /* Initialize blkCnt with number of samples */
  blkCnt = blockSize;
#endif /* #ifndef ARM_MATH_CM0 */
  while(blkCnt > 0u)
    /* C = A * B */
    blkCnt--;
* @} end of BasicMult group
linqing171| | 2017-8-28 21:07 | 只看该作者
因为啊,M0同时执行的指令没有M3多.
M3能同时执行的指令多, 但是有个缺点, 循环回去的时候, 流水线里面后面有几个执行了一半的要废弃了.
