求助,!谁会就帮帮小弟!
2155|1
 楼主| lc7745166 发表于 2010-12-17 18:07 | 显示全部楼层 |阅读模式
sd, TE, AD, ST, ni
#include<reg52.h>
#include<intrins.h>
#define uchar unsigned char
#define uint unsigned int
uchar const LED[]={0x3f,0x06,0x5b,0x4f,0x66,
                            0x6d,0x7d,0x07,0x7f,0x6f,0x77,0x7c,
                            0x39,0x5e,0x79,0x71,0x3f};// 显示段码值0123456789ABCDEF
sbit scl=P1^1;
sbit sda=P1^2;
sbit wp=P1^0;
uchar byte_read(uchar add);
void byte_write(uchar add,uchar date);
void delay(uint);
void star();
void stop();
void respon();
void unrespon();
uchar read();
void write(uchar add);
void init();
void main()
uchar i,da;
init();
da=byte_read(1);
da++;
if(da==0xff)
  da=0;
delay(350);
byte_write(11,da);
delay(500);
P1=0xff;
//while(1)
for(i=0;i<255;i++)
    P0=0;
    P2=1;
    P0=LED[da/100];
    delay(500);
    P0=0;
    P2=2;
    P0=LED[da%100/10];
    delay(500);
    P0=0;
    P2=3;
    P0=LED[da%10];
   // keys=0;
    delay(500);
  // break;
void delay(uint z)
{ uint x;
for(x=z;x>0;x--)
  for(;;);
void init()
scl=1;
delay(5);
sda=1;
delay(5);
void star()
sda=1;
delay(5);
scl=1;
delay(5);
sda=0;
delay(5);
//scl=0;
//delay(5);
void stop()
sda=0;
delay(5);
scl=1;
delay(5);
sda=1;
delay(5);
// sda=0;
// delay(5);
void respon()
{ uchar i;
scl=1;
delay(5);
while((sda==1)&&(i>200))
i++;
scl=0;
/*void unrespon()
{ uchar j;
scl=1;
delay(5);
while((sda==0)&&(j<200))
j++;
uchar i,temp;
temp=add;
delay(5);
for(i=0;i<8;i++)
  temp=temp<<1;
  scl=0;//拉低时钟开始写入
  sda=CY;
  delay(5);
  scl=1;//拉高时钟一位传输完毕
  delay(5);
scl=0;//允许数据变化
delay(5);
sda=1;//释放总线
delay(5);
uchar read()
uchar i,k;
scl=0;//允许数据变化
delay(5);
sda=1;//释放总线
delay(5);
for(i=0;i<8;i++)
{ scl=1;//数据不变开始按位读取
  delay(5);
  k=(k<<1)|sda;
  scl=0;//准备读取下一位
  delay(5);
return k;
star();
write(0xae);
respon();
write(add);
respon();
write(date);
respon();
stop();
{ uchar a;
star();
write(0xae);
respon();
write(add);
respon();
star();
write(0xaf);
respon();
a=read();
//unrespon();
stop();
return a;
 楼主| lc7745166 发表于 2010-12-17 18:08 | 显示全部楼层
就是这家伙,折磨了我好久,谁会就和小弟说下吧!谢谢
