F28035 用外部输入过流信号至TZ1封锁PWM慢是怎么回事
1693|6
452828196|  楼主 | 2017-9-7 16:15 | 显示全部楼层 |阅读模式
用TZ引脚接受外部输入过流信号来触发封锁PWM,但是很慢,经过排查,发现同步(Sync)貌似有问题,我用软件给OSHT置1就可以封锁,但是外部触发就是很慢,而且一点外部过流信号消失又会发出PWM,TZ配置如下:
    EALLOW;
// CPU Halt Trip
    EPwm1Regs.TZSEL.bit.CBC6=0x1;
    EPwm2Regs.TZSEL.bit.CBC6=0x1;
    EPwm3Regs.TZSEL.bit.CBC6=0x1;
    EPwm1Regs.TZSEL.bit.OSHT1   = 1;  //enable TZ1 for OSHT
    EPwm2Regs.TZSEL.bit.OSHT1   = 1;  //enable TZ1 for OSHT
    EPwm3Regs.TZSEL.bit.OSHT1   = 1;  //enable TZ1 for OSHT
// What do we want the OST/CBC events to do?
// TZA events can force EPWMxA
// TZB events can force EPWMxB
    EPwm1Regs.TZCTL.bit.TZA = TZ_FORCE_LO; // EPWMxA will go low
    EPwm1Regs.TZCTL.bit.TZB = TZ_FORCE_LO; // EPWMxB will go low
    EPwm2Regs.TZCTL.bit.TZA = TZ_FORCE_LO; // EPWMxA will go low
    EPwm2Regs.TZCTL.bit.TZB = TZ_FORCE_LO; // EPWMxB will go low
    EPwm3Regs.TZCTL.bit.TZA = TZ_FORCE_LO; // EPWMxA will go low
    EPwm3Regs.TZCTL.bit.TZB = TZ_FORCE_LO; // EPWMxB will go low
    EDIS;
   // Clear any spurious OV trip
    EPwm1Regs.TZCLR.bit.OST = 1;
    EPwm2Regs.TZCLR.bit.OST = 1;
    EPwm3Regs.TZCLR.bit.OST = 1;
PWM配置如下:
#define PWM_INIT_MACRO(ch1,ch2,ch3,v)        \
             /* Setup Sync*/        \
         (*ePWM[ch1]).TBCTL.bit.SYNCOSEL = 0;       /* Pass through*/                \
                 (*ePWM[ch2]).TBCTL.bit.SYNCOSEL = 0;       /* Pass through*/                \
                 (*ePWM[ch3]).TBCTL.bit.SYNCOSEL = 0;       /* Pass through*/                \
         /* Allow each timer to be sync'ed*/        \
         (*ePWM[ch1]).TBCTL.bit.PHSEN = 1;        \
         (*ePWM[ch2]).TBCTL.bit.PHSEN = 1;        \
         (*ePWM[ch3]).TBCTL.bit.PHSEN = 1;        \
         /* Init Timer-Base Period Register for EPWM1-EPWM3*/                                \
         (*ePWM[ch1]).TBPRD = v.PeriodMax;        \
         (*ePWM[ch2]).TBPRD = v.PeriodMax;        \
         (*ePWM[ch3]).TBPRD = v.PeriodMax;        \
         /* Init Timer-Base Phase Register for EPWM1-EPWM3*/                                \
         (*ePWM[ch1]).TBPHS.half.TBPHS = 0;        \
         (*ePWM[ch2]).TBPHS.half.TBPHS = 0;        \
         (*ePWM[ch3]).TBPHS.half.TBPHS = 0;        \
         /* Init Timer-Base Control Register for EPWM1-EPWM3*/                                \
         (*ePWM[ch1]).TBCTL.all = PWM_INIT_STATE;                                                        \
                 (*ePWM[ch2]).TBCTL.all = PWM_INIT_STATE;                                                        \
                 (*ePWM[ch3]).TBCTL.all = PWM_INIT_STATE;                                                        \
         /* Init Compare Control Register for EPWM1-EPWM3*/                                        \
         (*ePWM[ch1]).CMPCTL.all = CMPCTL_INIT_STATE;                                                \
         (*ePWM[ch2]).CMPCTL.all = CMPCTL_INIT_STATE;                                                \
         (*ePWM[ch3]).CMPCTL.all = CMPCTL_INIT_STATE;                                                \
         /* Init Action Qualifier Output A Register for EPWM1-EPWM3*/                \
         (*ePWM[ch1]).AQCTLA.all = AQCTLA_INIT_STATE;                                                \
         (*ePWM[ch2]).AQCTLA.all = AQCTLA_INIT_STATE;                                                \
         (*ePWM[ch3]).AQCTLA.all = AQCTLA_INIT_STATE;                                                \
         /* Init Dead-Band Generator Control Register for EPWM1-EPWM3*/                \
         (*ePWM[ch1]).DBCTL.all = DBCTL_INIT_STATE;                                                        \
         (*ePWM[ch2]).DBCTL.all = DBCTL_INIT_STATE;                                                        \
         (*ePWM[ch3]).DBCTL.all = DBCTL_INIT_STATE;                                                        \
         /* Init Dead-Band Generator for EPWM1-EPWM3*/                                                \
         (*ePWM[ch1]).DBFED = v.Deadband;        \
         (*ePWM[ch1]).DBRED = v.Deadband;        \
         (*ePWM[ch2]).DBFED = v.Deadband;        \
         (*ePWM[ch2]).DBRED = v.Deadband;        \
         (*ePWM[ch3]).DBFED = v.Deadband;        \
         (*ePWM[ch3]).DBRED = v.Deadband;        \
         /* Init PWM Chopper Control Register for EPWM1-EPWM3*/                                \
         (*ePWM[ch1]).PCCTL.all = PCCTL_INIT_STATE;                                                        \
         (*ePWM[ch2]).PCCTL.all = PCCTL_INIT_STATE;                                                        \
         (*ePWM[ch3]).PCCTL.all = PCCTL_INIT_STATE;                                                        \
         EALLOW;                       /* Enable EALLOW */                                        \
         /* Init Trip Zone Select Register*/        \
         (*ePWM[ch1]).TZSEL.all = TZSEL_INIT_STATE;                                                        \
         (*ePWM[ch2]).TZSEL.all = TZSEL_INIT_STATE;                                                        \
         (*ePWM[ch3]).TZSEL.all = TZSEL_INIT_STATE;                                                        \
         EDIS;                         /* Disable EALLOW*/
基本上都是参考TI官方的程序做的,查了寄存器也看不出什么问题
zhangmangui| | 2017-9-7 22:49 | 显示全部楼层
过流到封锁是MCU的硬件完成的吧    有个特殊的引脚需要控制一下
等软件检测关断 太慢了
airwill| | 2017-9-10 08:38 | 显示全部楼层
对啊, 这是硬件完成的, 应该速度很快. 是不是引入了信号滤波?
太不专一| | 2017-9-14 11:48 | 显示全部楼层
CBC触发是在EPWM 计数器等于0时自动清0
OHST不自动清零,但最好选异步,不然等时钟会延时
452828196|  楼主 | 2017-9-14 17:24 | 显示全部楼层
等软件检测关断 太慢了 ...
对,应该是硬件完成,只需要配置成OST模式就行,但是目前就是很慢,需要100--200us才能关断,太慢了,我用的时TZ1引脚,不知道问题出在哪
452828196|  楼主 | 2017-9-14 17:25 | 显示全部楼层
GPIO没有配置信号滤波,目前就是需要100-200us才能关断输出,与我们预期的几微妙相差太多了,不知道怎么回事
452828196|  楼主 | 2017-9-14 17:27 | 显示全部楼层
OHST不自动清零,但最好选异步,不然等时钟会延时 ...
意思就是OST模式也不会很快关断?我们想要在2-3微秒关断输出
