[STM32F1]
双机通讯时在从机地址接收时出现了问题
423|11
wyjie|  楼主 | 2017-9-24 22:37 | 显示全部楼层 |阅读模式
STM32,i2c双机通讯
dengdc| | 2017-9-24 22:38 | 显示全部楼层
楼主程序可以公开吗?贴程序看下吧,这么说看不出什么原因
wyjie|  楼主 | 2017-9-24 22:39 | 显示全部楼层
主机接收n个字节:
void I2C_ByteRead(void)
                while(I2C_GetFlagStatus(I2C2,I2C_FLAG_BUSY));
                I2C_GenerateSTART(I2C2, ENABLE);
                //EV5
                while(!I2C_CheckEvent(I2C2,I2C_EVENT_MASTER_MODE_SELECT));
                //while(!((uint16_t)(I2C2->SR1)&(uint16_t)(0x0001)));//SB=1
                //while(((uint16_t)(I2C2->SR2)&(uint16_t)(0x0003))!=0x0003);//BUSY=1
                I2C_Send7bitAddress(I2C2, I2C2_SLAVE_ADDRESS7, I2C_Direction_Transmitter);
                //EV6
                while(!I2C_CheckEvent(I2C2,I2C_EVENT_MASTER_TRANSMITTER_MODE_SELECTED));
                //while(((uint16_t)(I2C2->SR1)&(uint16_t)(0x0002))!=0x0002);//??????????
                while(RxCounter!=BUFFER_SIZE)
                         if(RxCounter==(BUFFER_SIZE-1))
                                        if(I2C_GetFlagStatus(I2C2, I2C_FLAG_RXNE)==1)
                                                 I2C_AcknowledgeConfig(I2C2, DISABLE);
                                                 I2C_GenerateSTOP(I2C2, ENABLE);
                        //EV7
                        while(!(I2C_CheckEvent(I2C2,I2C_EVENT_MASTER_BYTE_RECEIVED)));
                        //while(((uint16_t)(I2C2->SR1)&(uint16_t)(0x0040))!=0x0040);
                        RxBuffer[RxCounter++] = I2C_ReceiveData(I2C2);
                I2C_AcknowledgeConfig(I2C2, ENABLE);
                RxCounter=0;
从机发送n个字节:
void I2C_ByteWrite()
    while(((uint16_t)(I2C2->SR1)&(uint16_t)(0x0002))!=0x0002);//ADDR=1 receive address matched
    while(((uint16_t)(I2C2->SR2)&(uint16_t)(0x0006))!=0x0006);//BUSY=1+MSL=0+TRA=1
    I2C_SendData(I2C2,TxBuffer[TxCounter++]);
    while(TxCounter!=BUFFER_SIZE)
                        while(((uint16_t)(I2C2->SR1)&(uint16_t)(0x0080))!=0x0080);//DRΪ¿ÕʱΪ1£¬Ð´ÈëDRÇå³ý¸Ãλ
                while(((uint16_t)(I2C2->SR1)&(uint16_t)(0x0010))!=0x0010);
                TxCounter=0;
heweibig| | 2017-9-24 22:40 | 显示全部楼层
楼主详细说说怎么回事啊,这么说太笼统了
wyjie|  楼主 | 2017-9-24 22:42 | 显示全部楼层
两个程序都卡在了ADDR的判断循环里
wuhany| | 2017-9-24 22:43 | 显示全部楼层
STM32的I2C建议采用模拟。
jiahy| | 2017-9-24 22:45 | 显示全部楼层
用示波器先对下时序;
可以先用模拟先调通,再改成硬件的;
lizye| | 2017-9-24 22:46 | 显示全部楼层
调过:硬件IIC后来改用新唐的MCU了。
shimx| | 2017-9-24 22:49 | 显示全部楼层
请问,用什么来模拟调I2C啊
wyjie|  楼主 | 2017-9-24 22:50 | 显示全部楼层
哦,那我就知道怎么回事了,多谢大家,结贴了哈
jiaxw| | 2017-9-24 22:51 | 显示全部楼层
普通IO就可以,关键是时序
wyjie|  楼主 | 2017-9-24 22:53 | 显示全部楼层
结贴了,多谢大家讨论这么多哈,呵呵
