[DemoCode下载]
N76E003单片机的I2C操作方式
5542|6
huahuagg|  楼主 | 2017-10-23 20:28 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
这个芯片最近成为了风云芯片,大家来学习啊
主机模式
/* Copyright(c) 2016 Nuvoton Technology Corp. All rights reserved.                                         */
//  Nuvoton Technoledge Corp.
//  Website: http://www.nuvoton.com
//  E-Mail : MicroC-8bit@nuvoton.com
//  Date   : Apr/29/2016
//  File Function: N76E003 I2C master mode demo code, the Slave address = 0xA4
//   ____________            _____________
//  |            |   SDA    |             |
//  |N76E003(M) |          | N76E003(S) |
//  |(I2C_Master)|          | (I2C_Slave) |
//  |            |   SCL    |             |
//  |____________|          |_____________|
//  The protocol of I2C is same the "24LC64"
#include <stdio.h>
#include "N76E003.h"
#include "Common.h"
#include "Delay.h"
#include "SFR_Macro.h"
#include "Function_Define.h"
#define I2C_CLOCK               13
#define EEPROM_SLA              0xA4
#define EEPROM_WR               0
#define EEPROM_RD               1
#define ERROR_CODE              0x78
#define PAGE_SIZE               32
void Init_I2C(void)
//    /* Set I2C clock rate */
    I2CLK = I2C_CLOCK;
    /* Enable I2C */
    set_I2CEN;
void I2C_Error(void)
//    P3 = I2STAT;
//    P3 = ERROR_CODE;
    while (1);
void I2C_Process(UINT8 u8DAT)
    UINT32 u32Count;
//----  Page Write----------------------------------------------------------------------------
    /* Step1 */
    set_STA;                                    /* Send Start bit to I2C EEPROM */
    clr_SI;
    while (!SI);                                //Check SI set or not
    if (I2STAT != 0x08)                         //Check status value after every step
        I2C_Error();
    /* Step2 */
    clr_STA;                                    //STA=0
    I2DAT = (EEPROM_SLA | EEPROM_WR);
    clr_SI;
    if (I2STAT != 0x18)
        I2C_Error();
    /* Step3 */
    I2DAT = 0x00;                               //address high for I2C EEPROM
    clr_SI;
    if (I2STAT != 0x28)
        I2C_Error();
    /* Step4 */
    I2DAT = 0x00;                               //address low for I2C EEPROM
    clr_SI;
    if (I2STAT != 0x28)
        I2C_Error();
    /* Step5 */
    for (u32Count = 0; u32Count < PAGE_SIZE; u32Count++)
        I2DAT = u8DAT;
        clr_SI;
        if (I2STAT != 0x28)
            I2C_Error();
        u8DAT = ~u8DAT;
//----  Waitting the ready for I2C write------------------------------------------------------
    /* Step6 */
    do{
        set_STO;
        clr_SI;
        set_STA;                                //Check if no ACK is returned by EEPROM, it is under timed-write cycle
        clr_SI;
            I2C_Error();
        clr_STA;
        clr_SI;
    }while (I2STAT != 0x18);
    /* Step7 */
    set_STO;
    clr_SI;
    while (STO);                                /* Check STOP signal */
//----  Page Read ----------------------------------------------------------------------------
    /* Step8 */
    set_STA;
    clr_SI;
        I2C_Error();
    /* Step9 */
    clr_STA;
    clr_SI;
    if (I2STAT != 0x18)
        I2C_Error();
    /* Step10 */
    clr_SI;
    if (I2STAT != 0x28)
        I2C_Error();
    /* Step11 */
    clr_SI;
    if (I2STAT != 0x28)
        I2C_Error();
    /* Step12 */
    /* Repeated START */
    set_STA;
    clr_SI;
    if (I2STAT != 0x10)                         //Check status value after every step
        I2C_Error();
    /* Step13 */
    clr_STA;                                    //STA needs to be cleared after START codition is generated
    I2DAT = (EEPROM_SLA | EEPROM_RD);
    clr_SI;
    if (I2STAT != 0x40)
        I2C_Error();
    /* Step14 */
    for (u32Count = 0; u32Count <PAGE_SIZE-1; u32Count++)
        set_AA;
        clr_SI;
        if (I2STAT != 0x50)
            I2C_Error();
        if (I2DAT != u8DAT)
            I2C_Error();
        u8DAT = ~u8DAT;
    /* Step15 */
    clr_AA;
    clr_SI;
    if (I2STAT != 0x58)
        I2C_Error();
    /* Step16 */
    set_STO;
    clr_SI;
void main(void)
    /* Note
       MCU power on system clock is HIRC (22.1184MHz), so Fsys = 22.1184MHz
    Set_All_GPIO_Quasi_Mode;
    Init_I2C();                                 //initial I2C circuit
    I2C_Process(0x55);                          /* I2C Master will send 0x55,0xAA,.... to slave */
    P0 = 0x00;
    P3 = 0x00;
    while (1);
从机模式
/* Copyright(c) 2015 Nuvoton Technology Corp. All rights reserved.                                         */
//  Date   : May/1/2015
//  File Function: N76E003 I2C Slave demo code
#include <stdio.h>
#include "Common.h"
#include "Delay.h"
//  N76E885-series I2C slave mode demo code, the Slave address = 0xA4
//  |            |   SDA    |             |
//  |            |   SCL    |             |
UINT8 data_received[34], data_num = 0;
void I2C_ISR(void) interrupt 6
    switch (I2STAT)
        case 0x00:
            STO = 1;
            break;
        case 0x60:
            AA = 1;
            //P3 = 0x60;
            break;
        case 0x68:
                                                P02 = 0;
            while(1);
            break;
        case 0x80:
            //P3 = 0x80;
            data_received[data_num] = I2DAT;
            data_num++;
            if (data_num == 34)
                AA = 0;
            else
                AA = 1;
            break;
        case 0x88:
            //P3 = 0x88;
            data_num = 0;
            AA = 1;
            break;
        case 0xA0:
            //P3 = 0xA0;
            AA = 1;
            break;
        case 0xA8:
            //P3 = 0xA0;
            I2DAT = data_received[data_num];
            data_num++;
            AA = 1;
            break;
        case 0xB8:
            //P3 = 0xB8;
            data_num++;
            AA = 1;
            break;
        case 0xC0:
            AA = 1;
            break;
        case 0xC8:
            //P3 = 0xC8;
            AA = 1;
            break;
    SI = 0;
    while(STO);
void Init_I2C(void)
    P13_Quasi_Mode;                         //set SCL (P13) is Quasi mode
    P14_Quasi_Mode;                         //set SDA (P14) is Quasi mode
    SDA = 1;                                //set SDA and SCL pins high
    SCL = 1;
    set_P0SR_6;                             //set SCL (P06) is  Schmitt triggered input select.
    set_EI2C;                               //enable      I2C interrupt by setting IE1 bit 0
    set_EA;
    I2ADDR = EEPROM_SLA;                    //define own slave address
    set_I2CEN;                              //enable I2C circuit
    set_AA;
void main(void)
    /* Initial I2C function */
    while (1);
huahuagg|  楼主 | 2017-10-23 20:30 | 只看该作者
24LC64.pdf (588.3 KB)
NXP_I2C.pdf (280.85 KB)
21mengnan| | 2017-10-23 20:48 | 只看该作者
这是用IO模拟的吗
捉虫天师| | 2017-10-23 21:05 | 只看该作者
看到这个图我彻底懂了,主机就是发出时钟的一个。。
huangcunxiake| | 2017-10-23 21:23 | 只看该作者
应该有一些宏是在common里面定义的吧,在这个里面没有看到具体值。
zippozippo168| | 2017-10-25 20:47 | 只看该作者
什么是 风云芯片?
