[demo程序]
NV32F100x bootloader_demo
720|2
enginezhong|  楼主 | 2017-10-30 16:30 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#include "common.h"
#include "ics.h"
#include "rtc.h"
#include "uart.h"
#include "gpio.h"
#include "sysinit.h"
#include "start.h"
#include "boot.h"
#include "flash.h"
int main (void);
void RTC_Task(void);
int main (void)
    /*系统初始化*/
    sysinit();
          Flash_Init();
    uint8_t sectornum;
          uint32_t i;
          uint32_t *boot32;
          uint32_t adr;
          adr =0x400000;
          for(i=0;i<10;i++)
          Flash_EraseSector(adr+512*i);
         boot32=(uint32_t *)boot;
        for (i=0;i<boot_size/4;i++)
                Flash_Program1LongWord(adr,*boot32);
                boot32++;
                adr+=4;
    printf("\nRunning the GPIO_demo project.\n");
    GPIO_Init(GPIOB, GPIO_PTE7_MASK, GPIO_PinOutput);
    while (1);
* [url=home.php?mod=space&uid=247401]@brief[/url] RTC回调函数
* @param  none
* [url=home.php?mod=space&uid=266161]@return[/url] none
* @brief define interrupt service routines referenced by the vector table.
* Note: Only "vectors.c" should include this header file.
#ifndef __ISR_H
#define __ISR_H
/* Example */
#undef  VECTOR_036
#define VECTOR_036 RTC_Isr
// ISR(s) are defined in your project directory.
extern void RTC_Isr(void);
* @brief define interrupt service routine for different vectors.
#undef  VECTOR_036
#define VECTOR_036      RTC_Isr          /*!< Vector 36 points to RTC interrupt service routine */
#endif  //__ISR_H
/* End of "isr.h" */
enginezhong|  楼主 | 2017-10-30 16:31 | 只看该作者
bootloader_demo.rar (1008 Bytes)
