[技术问答]
N76E003测试捕抓问题
1963|11
liu_33|  楼主 | 2017-11-4 22:10 | 显示全部楼层 |阅读模式
拿新塘的范例用死机和无功能。
程序如下:
#include <stdio.h>
#include "N76E003.h"
#include "Common.h"
#include "Delay.h"
#include "SFR_Macro.h"
#include "Function_Define.h"
sbit P15        = P1^5;
//sbit P14        = P1^4;
xdata long d=0;
//*****************  The Following is in define in Fucntion_define.h  ***************************
//****** Always include Function_define.h call the define you want, detail see main(void) *******
#if 0
//#define                TIMER0_MODE0_ENABLE                TMOD&=0x0F
//#define                TIMER0_MODE1_ENABLE                TMOD&=0x0F;TMOD|=0x10
//#define                TIMER0_MODE2_ENABLE                TMOD&=0x0F;TMOD|=0x20
//#define                TIMER0_MODE3_ENABLE                TMOD&=0x0F;TMOD|=0x3F
//#define                TIMER1_MODE0_ENABLE                TMOD&=0xF0
//#define                TIMER1_MODE1_ENABLE                TMOD&=0xF0;TMOD|=0x01
//#define                TIMER1_MODE2_ENABLE                TMOD&=0xF0;TMOD|=0x02
//#define                TIMER1_MODE3_ENABLE                TMOD&=0xF0;TMOD|=0xF3
#endif
#define TH0_INIT        50000
#define TL0_INIT        50000
#define TH1_INIT        5000
#define TL1_INIT        5000
UINT8 u8TH0_Tmp,u8TL0_Tmp,u8TH1_Tmp,u8TL1_Tmp,aa,bb;
*    TIMER 0 interrupt subroutine
void Timer0_ISR (void) interrupt 1  //interrupt address is 0x000B
    TH0 = u8TH0_Tmp;
    TL0 = u8TL0_Tmp;
  //  P15 = ~P15;                     // GPIO1 toggle when interrupt
*    TIMER 1 interrupt subroutine
void Timer1_ISR (void) interrupt 3  //interrupt address is 0x001B
    TH1 = u8TH1_Tmp;
    TL1 = u8TL1_Tmp;
P13 = ~P13;
  P15 = ~P15;
    P03 = ~P03;                     //P0.3 toggle when interrupt
void Timer2_ISR (void) interrupt 5
          clr_TF2;                                //Clear Timer2 Interrupt Flag
        //  P12 = ~P12;        // GPIO1 toggle
void Capture_ISR (void) interrupt 12
        clr_CAPF0;                          // clear capture0 interrupt flag
        aa = C0L;        // For capture mode CxL/CxH with data capture from I/O pin
        bb = C0H;                                                        //得不到数字
        P14 = ~P14;                                                        //toggle GPIO1 to show int
*    Main function
void main (void)
    Set_All_GPIO_Quasi_Mode;
                TIMER0_MODE1_ENABLE;
                TIMER1_MODE1_ENABLE;
                          TIMER2_Compare_Capture_Mode;
                IC3_P00_CAP0_BothEdge_Capture;           //还是下降沿为什么?
  //  set_ET2;                                    //Enable Timer2 interrupt        加上它就死机
    set_ECAP;                                   //Enable Capture interrupt
    set_TR2;                                    //Triger Timer2
    clr_T1M;
    //set_T1M;
   CKDIV=0;
CKCON=CKCON|0X18;
    u8TH0_Tmp = (65536-TH0_INIT)/256;
    u8TL0_Tmp = (65536-TL0_INIT)%256;
    u8TH1_Tmp = (65536-TH1_INIT)/256;
    u8TL1_Tmp = (65536-TL1_INIT)%256;
    TH0 = u8TH0_Tmp;
    TL0 = u8TL0_Tmp;
    TH1 = u8TH1_Tmp;
    TL1 = u8TL1_Tmp;
    set_ET0;                                    //enable Timer0 interrupt
    set_ET1;                                    //enable Timer1 interrupt
    set_EA;                                     //enable interrupts
    set_TR0;                                    //Timer0 run
    set_TR1;                                    //Timer1 run
    while(1);
liu_33|  楼主 | 2017-11-4 22:11 | 显示全部楼层
打开 set_ET2;就死机,以及设置是边沿触发还是下降沿触发。数字也得不到。为什么请新塘高手解答下
liu_33|  楼主 | 2017-11-4 22:19 | 显示全部楼层
最近STM8的涨价,准备下新塘的单片机,发现资料比较少呀
天灵灵地灵灵| | 2017-11-5 17:39 | 显示全部楼层
用最新版刚看到更新了
liu_33|  楼主 | 2017-11-6 15:15 | 显示全部楼层
这个问题没人碰到吗
Alisa000| | 2017-11-7 16:50 | 显示全部楼层
可以找我们 一级代理 多交流 Q1574540195
座机呀| | 2017-11-7 18:45 | 显示全部楼层
看门狗没喂?没有中断服务函数?
liu_33|  楼主 | 2017-11-14 09:36 | 显示全部楼层
这些都是拿范例测试的。死机呀
zhuomuniao110| | 2017-11-14 11:56 | 显示全部楼层
用最新版的范例试试看。
gejigeji521| | 2017-11-14 14:51 | 显示全部楼层
有种熟悉的感觉,51的风格。
huahuagg| | 2017-11-14 17:11 | 显示全部楼层
不行?你自己根据寄存器写个试试呢
liu_33|  楼主 | 2017-11-15 00:34 | 显示全部楼层
最新的范例是什么版本,这些范例已经是寄存器操作了。
