FSK信号鉴频的程序
837|0
 楼主| Peonys 发表于 2017-11-9 10:37 | 显示全部楼层 |阅读模式
FSK信号鉴频的程序
  • /* This program implements the function of finding out the largest */
  • /* and the second largest values of the sequence of "in_buffer[10]"*/
  • #include <stdio.h>
  • #include <math.h>
  • #include "freq_max_finding.h"
  • //extern float cosf(float x);
  • extern int in_buffer[10]={0,0,0,0,0,0,0,0,0,0}; /* in_buffer[]中的值为频谱点 */
  • //int out_buffer[2];
  • static void dataIN(void);
  • void main()
  •         int                i=0;
  • //        float         data_max=0;
  •         int                data_max=0;
  • //        float         data_max2=0;
  •         int     data_max2=0;
  •         int         i_max=0;
  •         int         i_max2=0;
  •         float         f_max=0;
  •         float         f_max2=0;
  •         int                p=0;
  •         int                q=0;
  • //        float a=0, b=3.14159;
  • //        a=a+0;
  • //        b=b+0;
  • //        a=cosf(b);
  •         /** 几句废话,消除warning:data_max was set but never used **/
  •         data_max=data_max+0;
  •         data_max2=data_max2+0;
  • //        i_max=i_max+0;
  • //        i_max2=i_max2+0;
  •         f_max=f_max+0;
  •         f_max2=f_max2+0;
  •         dataIN();        /* read data into memory */
  • /** find out the greatest value of "in_buffer" **/
  •         for(i=0;i<=POINT_ALL-2;i++)
  •                  if (in_buffer[i+1]>in_buffer)
  •                            {data_max=in_buffer[i+1]; i_max=i+1;}
  •                  else {data_max=in_buffer; i_max=i;}
  •         f_max=FS*i_max/POINT_ALL; /* calculate the value of carrier frequency */
  • /* find out the second greatest value of "in_buffer" */
  •                 in_buffer[i_max]=0;        /* set 0 to "in_buffer[i_max]"*/
  •                 for(p=1;p<=POINT_ALL/2;p++)
  •                          for(q=0;q<=POINT_ALL/2-2;q++)
  •                                     if (in_buffer[q+1]>in_buffer[q])
  •                                                     {data_max2=in_buffer[q+1]; i_max2=q+1;}
  •                                     else        {data_max2=in_buffer[q]; i_max2=q;}
  •                          /* determines the availability of i_max2 through
  •                             estimating the distance of i_max between i_max2 */
  •                          if (abs(i_max-i_max2)<=GAP)        in_buffer[i_max2]=0;
  •                          else        break;
  •                 f_max2=FS*i_max2/POINT_ALL;        /* calculate the value of carrier frequency2 */
  •         while(1);
  • static void dataIN()
  •         /* do read data from host file */
  •         return;
复制代码
