[DemoCode下载]
N76E003通过PWM触发ADC采样
2705|5
yiy|  楼主 | 2017-11-9 21:27 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
/* Copyright(c) 2016 Nuvoton Technology Corp. All rights reserved.                                         */
//  Nuvoton Technoledge Corp.
//  Website: http://www.nuvoton.com
//  E-Mail : MicroC-8bit@nuvoton.com
//  Date   : Apr/21/2016
//  File Function: N76E003 ADC demo code
#include "N76E003.h"
#include "SFR_Macro.h"
#include "Function_define.h"
#include "Common.h"
#include "Delay.h"
//*****************  The Following is in define in Fucntion_define.h  ***************************
//****** Always include Function_define.h call the define you want, detail see main(void) *******
#if 0
//#define Enable_ADC_AIN0                        ADCCON0&=0xF0;P17_Input_Mode;AINDIDS=0x00;AINDIDS|=SET_BIT0;ADCCON1|=SET_BIT0        //P17
//#define Enable_ADC_AIN1                        ADCCON0&=0xF0;ADCCON0|=0x01;P30_Input_Mode;AINDIDS=0x00;AINDIDS|=SET_BIT1;ADCCON1|=SET_BIT0                //P30
//#define Enable_ADC_AIN2                        ADCCON0&=0xF0;ADCCON0|=0x02;P07_Input_Mode;AINDIDS=0x00;AINDIDS|=SET_BIT2;ADCCON1|=SET_BIT0                //P07
//#define Enable_ADC_AIN3                        ADCCON0&=0xF0;ADCCON0|=0x03;P06_Input_Mode;AINDIDS=0x00;AINDIDS|=SET_BIT3;ADCCON1|=SET_BIT0                //P06
//#define Enable_ADC_AIN4                        ADCCON0&=0xF0;ADCCON0|=0x04;P05_Input_Mode;AINDIDS=0x00;AINDIDS|=SET_BIT4;ADCCON1|=SET_BIT0                //P05
//#define Enable_ADC_AIN5                        ADCCON0&=0xF0;ADCCON0|=0x05;P04_Input_Mode;AINDIDS=0x00;AINDIDS|=SET_BIT5;ADCCON1|=SET_BIT0                //P04
//#define Enable_ADC_AIN6                        ADCCON0&=0xF0;ADCCON0|=0x06;P03_Input_Mode;AINDIDS=0x00;AINDIDS|=SET_BIT6;ADCCON1|=SET_BIT0                //P03
//#define Enable_ADC_AIN7                        ADCCON0&=0xF0;ADCCON0|=0x07;P11_Input_Mode;AINDIDS=0x00;AINDIDS|=SET_BIT7;ADCCON1|=SET_BIT0                //P11
//#define Enable_ADC_BandGap        ADCCON0|=0x0F;ADCCON1|=SET_BIT0        //Band-gap 1.22V
//#define PWM0_FALLINGEDGE_TRIG_ADC                ADCCON0&=~SET_BIT5;ADCCON0&=~SET_BIT4;ADCCON1&=~SET_BIT3;ADCCON1&=~SET_BIT2;ADCCON1|=SET_BIT1
//#define PWM2_FALLINGEDGE_TRIG_ADC                ADCCON0&=~SET_BIT5;ADCCON0|=SET_BIT4;ADCCON1&=~SET_BIT3;ADCCON1&=~SET_BIT2;ADCCON1|=SET_BIT1
//#define PWM4_FALLINGEDGE_TRIG_ADC                ADCCON0|=SET_BIT5;ADCCON0&=~SET_BIT4;ADCCON1&=~SET_BIT3;ADCCON1&=~SET_BIT2;ADCCON1|=SET_BIT1
//#define PWM0_RISINGEDGE_TRIG_ADC                ADCCON0&=~SET_BIT5;ADCCON0&=~SET_BIT4;ADCCON1&=~SET_BIT3;ADCCON1|=SET_BIT2;ADCCON1|=SET_BIT1
//#define PWM2_RISINGEDGE_TRIG_ADC                ADCCON0&=~SET_BIT5;ADCCON0|=SET_BIT4;ADCCON1&=~SET_BIT3;ADCCON1|=SET_BIT2;ADCCON1|=SET_BIT1
//#define PWM4_RISINGEDGE_TRIG_ADC                ADCCON0|=SET_BIT5;ADCCON0&=~SET_BIT4;ADCCON1&=~SET_BIT3;ADCCON1|=SET_BIT2;ADCCON1|=SET_BIT1
//#define PWM0_CENTRAL_TRIG_ADC                                ADCCON0&=~SET_BIT5;ADCCON0&=~SET_BIT4;ADCCON1|=SET_BIT3;ADCCON1&=~SET_BIT2;ADCCON1|=SET_BIT1
//#define PWM2_CENTRAL_TRIG_ADC                                ADCCON0&=~SET_BIT5;ADCCON0|=SET_BIT4;ADCCON1|=SET_BIT3;ADCCON1&=~SET_BIT2;ADCCON1|=SET_BIT1
//#define PWM4_CENTRAL_TRIG_ADC                                ADCCON0|=SET_BIT5;ADCCON0&=~SET_BIT4;ADCCON1|=SET_BIT3;ADCCON1&=~SET_BIT2;ADCCON1|=SET_BIT1
//#define PWM0_END_TRIG_ADC                                                ADCCON0&=~SET_BIT5;ADCCON0&=~SET_BIT4;ADCCON1|=SET_BIT3;ADCCON1|=SET_BIT2;ADCCON1|=SET_BIT1
//#define PWM2_END_TRIG_ADC                                                ADCCON0&=~SET_BIT5;ADCCON0|=SET_BIT4;ADCCON1|=SET_BIT3;ADCCON1|=SET_BIT2;ADCCON1|=SET_BIT1
//#define PWM4_END_TRIG_ADC                                                ADCCON0|=SET_BIT5;ADCCON0&=~SET_BIT4;ADCCON1|=SET_BIT3;ADCCON1|=SET_BIT2;ADCCON1|=SET_BIT1
//#define P04_FALLINGEDGE_TRIG_ADC                ADCCON0|=0x30;ADCCON1&=0xF3;ADCCON1|=SET_BIT1;ADCCON1&=~SET_BIT6
//#define P13_FALLINGEDGE_TRIG_ADC                ADCCON0|=0x30;ADCCON1&=0xF3;ADCCON1|=SET_BIT1;ADCCON1|=SET_BIT6
//#define P04_RISINGEDGE_TRIG_ADC                        ADCCON0|=0x30;ADCCON1&=~SET_BIT3;ADCCON1|=SET_BIT2;ADCCON1|=SET_BIT1;ADCCON1&=~SET_BIT6
//#define P13_RISINGEDGE_TRIG_ADC                        ADCCON0|=0x30;ADCCON1&=~SET_BIT3;ADCCON1|=SET_BIT2;ADCCON1|=SET_BIT1;ADCCON1|=SET_BIT6
#endif
* FUNCTION_PURPOSE: ADC interrupt Service Routine
void ADC_ISR (void) interrupt 11
    clr_ADCF;                               // Clear ADC interrupt flag
                printf ("\n Value = 0x%bx",ADCRH);                // printf display will cause delay in ADC interrupt
                P30 ^= 1;        // Check the P3.0 toggle at falling edge of PWM
The main C function.  Program execution starts
here after stack initialization.
void main (void)
    Set_All_GPIO_Quasi_Mode;
                InitialUART0_Timer1(9600);
        ADC trig initial setting
        Please modify #if value to open diffent type
#if 1
// By PWM falling edge
                PWM0_P12_OUTPUT_ENABLE;
                Enable_ADC_AIN0;        // Enable AIN0 P1.7 as ADC input
                PWM0_FALLINGEDGE_TRIG_ADC;
#endif
#if 0
// By PWM rising edge
                PWM0_RISINGEDGE_TRIG_ADC;
#endif
#if 0
// By PWM central point
                PWM_CENTER_TYPE;
                PWM0_CENTRAL_TRIG_ADC;
#endif
#if 0
// By PWM end point
                PWM_CENTER_TYPE;
                PWM0_END_TRIG_ADC;
#endif
// Setting PWM value
                PWMPH = 0x07;        //Setting PWM value
    PWMPL = 0xFF;
    PWM0H = 0x02;
    PWM0L = 0xFF;
          set_LOAD;        // PWM run
    set_PWMRUN;
// Setting ADC
          set_EADC;        // Enable ADC interrupt (if use interrupt)
                EA = 1;
                while(1);
之前是不是有朋友要这个例子的?现在有了,拿去不谢。
jiekou001| | 2017-11-9 22:27 | 只看该作者
是不是也可以颠倒一下,通过ADC的值设置PWM的占空比
这样可以通过一个电位器旋钮调整PWM。
zl1211| | 2018-1-24 14:00 | 只看该作者
请问如果我想用串口将采集到的电压值输出该怎样改
smilefenfen| | 2018-4-18 10:14 | 只看该作者
ADCCON1&=~SET_BIT6;
这是什么意思,谁能给解答一下
yiy
92
