[PCB]
原理图生成网格文件错误
671|1
路宝毅|  楼主 | 2017-11-17 22:22 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#248 ERROR(SPCODD-248): All physical pins are common in section 14 of physical part 'EP4CE6F17C8_BGA256_EP4CE6F17C8'.  Each section must have at least one non-common pin.Open the part in Part Developer and ensure that you have at least one non-common pin for each section of a physical part.
路宝毅|  楼主 | 2017-11-18 13:03 | 只看该作者
这个怎么解决啊
