[技术问答]
新唐M051系列单片机如何读取96位唯一ID(UID)?
2781|8
bobde163|  楼主 | 2017-11-21 09:02 | 显示全部楼层 |阅读模式
如题所示,有哪位朋友知道通过什么方式,在程序中获取M051系列单片机的96位唯一ID(UID)?我目前只能通过Nu-Linker在Nuvoton NuMicro ICP Programming Tool烧录软件上可以读出,不知道如何在单片机程序里读取,有知道的朋友请指点一下,先谢过了
643757107| | 2017-11-21 11:16 | 显示全部楼层
u32Data = FMC_ReadUID(i);
* [url=home.php?mod=space&uid=288409]@file[/url]     main.c
* [url=home.php?mod=space&uid=895143]@version[/url]  V3.00
* $Revision: 10 $
* $Date: 15/05/22 5:13p $
* [url=home.php?mod=space&uid=247401]@brief[/url]    FMC erase/program/read sample program for M051 series MCU
* @note
* Copyright (C) 2014 Nuvoton Technology Corp. All rights reserved.
#include <stdio.h>
#include "M051Series.h"
#define PLLCON_SETTING      CLK_PLLCON_50MHz_HXT
#define PLL_CLOCK           50000000
#define APROM_TEST_BASE             0x3000
#define APROM_TEST_END              0x10000
#define DATA_FLASH_TEST_BASE        (FMC->DFBADR)
#define DATA_FLASH_TEST_END         (FMC->DFBADR + 0x1000)
#define TEST_PATTERN                0x5A5A5A5A
void SYS_Init(void)
    /* Init System Clock        */
    /* Enable External XTAL (4~24 MHz) */
    CLK->PWRCON |= CLK_PWRCON_XTL12M_EN_Msk;
    CLK->PLLCON = PLLCON_SETTING;
    /* Waiting for clock ready */
    CLK_WaitClockReady(CLK_CLKSTATUS_PLL_STB_Msk | CLK_CLKSTATUS_XTL12M_STB_Msk);
    /* Switch HCLK clock source to PLL */
    CLK->CLKSEL0 = CLK_CLKSEL0_HCLK_S_PLL;
    /* Enable IP clock */
    CLK->APBCLK = CLK_APBCLK_UART0_EN_Msk;
    /* Select IP clock source */
    CLK->CLKSEL1 = CLK_CLKSEL1_UART_S_HXT;
    /* Update System Core Clock */
    /* User can use SystemCoreClockUpdate() to calculate PllClock, SystemCoreClock and CycylesPerUs automatically. */
    //SystemCoreClockUpdate();
    PllClock        = PLL_CLOCK;            // PLL
    SystemCoreClock = PLL_CLOCK / 1;        // HCLK
    CyclesPerUs     = PLL_CLOCK / 1000000;  // For SYS_SysTickDelay()
    /* Init I/O Multi-function        */
    /* Set P3 multi-function pins for UART0 RXD and TXD  */
    SYS->P3_MFP = SYS_MFP_P30_RXD0 | SYS_MFP_P31_TXD0;
void UART_Init()
    /* Init UART        */
    UART_Open(UART0, 115200);
int32_t FillDataPattern(uint32_t u32StartAddr, uint32_t u32EndAddr, uint32_t u32Pattern)
    uint32_t u32Addr;
    for(u32Addr = u32StartAddr; u32Addr < u32EndAddr; u32Addr += 4)
        FMC_Write(u32Addr, u32Pattern);
    return 0;
int32_t  VerifyData(uint32_t u32StartAddr, uint32_t u32EndAddr, uint32_t u32Pattern)
    uint32_t    u32Addr;
    uint32_t    u32Data;
        u32Data = FMC_Read(u32Addr);
        if(u32Data != u32Pattern)
            printf("\nFMC_Read data verify failed at address 0x%x, read=0x%x, expect=0x%x\n", u32Addr, u32Data, u32Pattern);
            return -1;
    return 0;
int32_t  FlashTest(uint32_t u32StartAddr, uint32_t u32EndAddr, uint32_t u32Pattern)
    uint32_t    u32Addr;
    for(u32Addr = u32StartAddr; u32Addr < u32EndAddr; u32Addr += FMC_FLASH_PAGE_SIZE)
        printf("    Flash test address: 0x%x    \r", u32Addr);
        // Erase page
        FMC_Erase(u32Addr);
        // Verify if page contents are all 0xFFFFFFFF
        if(VerifyData(u32Addr, u32Addr + FMC_FLASH_PAGE_SIZE, 0xFFFFFFFF) < 0)
            printf("\nPage 0x%x erase verify failed!\n", u32Addr);
            return -1;
        // Write test pattern to fill the whole page
        if(FillDataPattern(u32Addr, u32Addr + FMC_FLASH_PAGE_SIZE, u32Pattern) < 0)
            printf("Failed to write page 0x%x!\n", u32Addr);
            return -1;
        // Verify if page contents are all equal to test pattern
        if(VerifyData(u32Addr, u32Addr + FMC_FLASH_PAGE_SIZE, u32Pattern) < 0)
            printf("\nData verify failed!\n ");
            return -1;
        FMC_Erase(u32Addr);
            return -1;
    printf("\r    Flash Test Passed.          \n");
    return 0;
int main()
    uint32_t i, u32Data;
    /* Unlock protected registers */
    SYS_UnlockReg();
    SYS_Init();
    UART_Init();
        This sample code is used to show how to use StdDriver API to implement ISP functions.
    printf("\n\n");
    printf("+----------------------------------------+\n");
    printf("|          M051 FMC Sample Code          |\n");
    SYS_UnlockReg();
    /* Enable FMC ISP function */
    FMC_Open();
    /* Read BS */
    printf("  Boot Mode ............................. ");
    if(FMC_GetBootSource() == 0)
        printf("[APROM]\n");
    else
        printf("[LDROM]\n");
        printf("  WARNING: The driver sample code must execute in AP mode!\n");
        goto lexit;
    u32Data = FMC_ReadCID();
    printf("  Company ID ............................ [0x%08x]\n", u32Data);
    u32Data = FMC_ReadPID();
    printf("  Product ID ............................ [0x%08x]\n", u32Data);
    for(i = 0; i < 3; i++)
        printf("  Unique ID %d ........................... [0x%08x]\n", i, u32Data);
    for(i = 0; i < 4; i++)
        u32Data = FMC_ReadUCID(i);
        printf("  Unique Customer ID %d .................. [0x%08x]\n", i, u32Data);
    /* Read User Configuration */
    printf("  User Config 0 ......................... [0x%08x]\n", FMC_Read(FMC_CONFIG_BASE));
    /* Read Data Flash base address */
    u32Data = FMC_ReadDataFlashBaseAddr();
    printf("  Data Flash Base Address ............... [0x%08x]\n", u32Data);
    printf("\n\nLDROM test =>\n");
    FMC_EnableLDUpdate();
    if(FlashTest(FMC_LDROM_BASE, FMC_LDROM_BASE + FMC_LDROM_SIZE, TEST_PATTERN) < 0)
        printf("\n\nLDROM test failed!\n");
        goto lexit;
    FMC_DisableLDUpdate();
    printf("\n\nAPROM test =>\n");
    FMC_EnableAPUpdate();
    if(FlashTest(APROM_TEST_BASE, APROM_TEST_END, TEST_PATTERN) < 0)
        printf("\n\nAPROM test failed!\n");
        goto lexit;
    FMC_DisableAPUpdate();
    printf("\n\nData Flash test =>\n");
    if(FlashTest(DATA_FLASH_TEST_BASE, DATA_FLASH_TEST_END, TEST_PATTERN) < 0)
        printf("\n\nData Flash test failed!\n");
        goto lexit;
lexit:
    /* Disable FMC ISP function */
    FMC_Close();
    /* Lock protected registers */
    SYS_LockReg();
    printf("\nFMC Sample Code Completed.\n");
    while(1);
/*** (C) COPYRIGHT 2014 Nuvoton Technology Corp. ***/
参考上面的例子,提供的有库函数读取这个的。
bobde163|  楼主 | 2017-11-21 14:16 | 显示全部楼层
谢谢指导,我在用户手册中没有找到关于UID的信息,一时也没有想到查看库函数,我去看看
zhuomuniao110| | 2017-11-21 16:18 | 显示全部楼层
可以在手册里搜索关键词啊,我好多次,自己找不到,搜索到了,或者有的找不到的,我直接全部打开库函数文件,然后用工具搜索关键词。
wanduzi| | 2017-11-21 19:31 | 显示全部楼层
32*3=96,
原来如此
xinpian101| | 2017-11-21 19:48 | 显示全部楼层
之前我也奇怪,怎么读96位的数据,原来是分开读。。
jiekou001| | 2017-11-21 20:09 | 显示全部楼层
借楼主的光,学习一下。
