[STM32F1]
也写个JLINK OB的bootloader玩
2236|7
yjmwxwx|  楼主 | 2017-11-22 19:23 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
原版是minux十年前写的,模仿他的也写个玩。不知道能成功更新固件不?
jlink ob.zip (92.42 KB)
  .thumb
         .syntax unified
.section .data
        .equ STACKINIT,         0x20005000
yjmwxwx: .ascii "jlink ob boot 2017-11-19 yjmwxwx"
.section .text
_xiangliangbiao:
        .word STACKINIT
        .word _start + 1
        .word _nmi_handler + 1
        .word _hard_fault  + 1
        .word _memory_fault + 1
        .word _bus_fault + 1
        .word _usage_fault + 1
_start:
        cpsid i
        sub sp, sp, # 0x5000
        ldr r0, = yjmwxwx
        str r0, [sp]
        add sp, sp, # 0x5000
        ldr r0, = 0xffffffff
        ldr r1, = 0x8009c00
        ldr r1, [r1]
        cmp r1, r0
        bne _crcjisuan
_daogujian:
        ldr r0, = 0xe000ed08
        ldr r1, = 0x8004000
        str r1, [r0]
        add r1, r1, # 4
        ldr r1, [r1]
        cpsie i
        bx r1
_crcjisuan:
        ldr r0, = 0x8009c00
        ldr r1, = 0x5bfe
        mov r6, # 0
        movw r4, # 0x8408
_crcxunhuan:
        ldrb r5, [r0], # 1
        eor r6, r6, r5
        mov r2, # 8
_crcxunhuan1:
        mov r5, r6
        lsrs r6, r6, # 1
        tst r5, # 1
        it ne
        eorne r6, r6, r4
        subs r2, r2, # 1
        bne _crcxunhuan1
        subs r1, r1, # 1
        bne _crcxunhuan
        ldr r0, = 0x800f7fe
        ldr r1, [r0]
        cmp r6, r1
        bne _daogujian
                                        [url=home.php?mod=space&uid=72445]@[/url] flsh解锁
        ldr r0, = 0x40022000
        ldr r1, = 0x45670123
        str r1, [r0, # 0x04]
        ldr r1, = 0xcdef89ab
                                        @擦除23页
        mov r5, # 23
        ldr r4, = 0x8004000
        movw r8, # 0x400
_flashmang:
        ldr r2, [r0, # 0x0c]
        lsls r2, r2, # 31
        bmi _flashmang
        mov r1, # 2
        str r1, [r0, # 0x10]
        str r4, [r0, # 0x14]
        mov r1, # 0x42
        add r4, r4, r8
        subs r5, # 1
        bne _flashmang
                                                @写FLASH
        ldr r8, = 0x8004000
        ldr r4, = 0x8009c00
        mov r5, # 0
        movw r6, # 0x1700
_flashmang1:
        lsls r2, r2, # 31
        bmi _flashmang1
        mov r1, # 1
        ldrh r3, [r4, r5]
        strh r3, [r8, r5]
        add r5, r5, # 2
_flashmang2:
        lsls r2, r2, # 31
        bmi _flashmang2
        ldrh r3, [r4, r5]
        strh r3, [r8, r5]
        add r5, r5, # 2
        subs r6, r6, # 1
        bne _flashmang1
_flashmang3:
        lsls r2, r2, # 31
        bmi _flashmang3
        mov r1, # 2
        ldr r3, = 0x8009c00           [url=home.php?mod=space&uid=72445]@[/url] 擦去更新的一页
        str r3, [r0, # 0x14]
        mov r1, # 0x42
_flashmang4:
        lsls r2, r2, # 31
        bmi _flashmang4
        mov r1, # 0x80
        str r1, [r0]                          @flsh上锁
        ldr r0, = 0xe000ed0c
        ldr r1, = 0x05fa0004
        str r1, [r0]                          @复位
_nmi_handler:
        bx lr
_hard_fault:
        bx lr
_memory_fault:
        bx lr
_bus_fault:
        bx lr
_usage_fault:
         bx lr
mmuuss586| | 2017-11-22 20:13 | 只看该作者
厉害呀
zgd881009| | 2019-5-15 00:16 | 只看该作者
如何使用,能弄个j link ob 072的boot出来吗
戈卫东| | 2019-5-15 08:14 | 只看该作者
膜拜一下。。。。
海中水| | 2019-5-15 09:20 | 只看该作者
厉害。
海中水| | 2019-5-15 09:21 | 只看该作者
厉害。
antusheng| | 2019-5-15 22:19 | 只看该作者
高手啊,真是高
wangjiahao88| | 2019-5-16 08:12 | 只看该作者
这个 需要对 芯片 或者ARM 内核有深层次的了解
