急!!DSP的SCI进不去中断
4272|12
 楼主| MapleSugar 发表于 2017-11-23 11:47 | 显示全部楼层 |阅读模式
DSP, pi, gp, IO, GPIO
RXBUF中有数据,但是进不去中断,怎么办?求助各位大神
#include "DSP28x_Project.h"     // Device Headerfile and Examples Include File
// Prototype statements for functions found within this file.
void scib_loopback_init(void);
void scib_fifo_init(void);
void scib_xmit(int a);
void configGPIO(void);
__interrupt void SCIRXINTb_ISR(void);
__interrupt void cpu_timer0_isr(void);
// Global counts used in this example
Uint16 LoopCount=0;
Uint16 ErrorCount;
Uint16 sci_count;
Uint16 ReceiveChar;
Uint16 Char;
unsigned char Navdata[85];
void main(void)
        InitSysCtrl();
        configGPIO();
        DINT;
        InitPieCtrl();
        IER = 0x0000;
        IFR = 0x0000;
        InitPieVectTable();
    EALLOW;
    PieVectTable.TINT0 = &cpu_timer0_isr;
    PieVectTable.SCIRXINTB= &SCIRXINTb_ISR;
    EDIS;
    InitScibGpio();
    scib_fifo_init();           // Initialize the SCI FIFO
    scib_loopback_init();  // Initalize SCI for digital loop back
    InitCpuTimers();
    ConfigCpuTimer(&CpuTimer0,90,1000000);
    CpuTimer0Regs.TCR.all = 0x4000;
    IER = 0x101;  // Enable CPU INT
    PieCtrlRegs.PIECTRL.bit.ENPIE = 1;
    PieCtrlRegs.PIEIER1.bit.INTx7 = 1;
    PieCtrlRegs.PIEIER9.bit.INTx3 = 1;     // PIE Group 9, INT3   Receive Navigation information
    EINT;   // Enable Global interrupt INTM
    ERTM;   // Enable Global realtime interrupt DBGM
        for(;;)
void scib_loopback_init()
         ScibRegs.SCICCR.all =0x0007;   // 1 stop bit,  No loopback
                                   // No parity,8 char bits,
                                   // async mode, idle-line protocol
        ScibRegs.SCICTL1.all =0x0003;  // enable TX, RX, internal SCICLK,
                                   // Disable RX ERR, SLEEP, TXWAKE
        ScibRegs.SCICTL2.all =0x0003;
        ScibRegs.SCICTL2.bit.TXINTENA =1;
        ScibRegs.SCICTL2.bit.RXBKINTENA =1;
    ScibRegs.SCIHBAUD    =64>>8;
    ScibRegs.SCILBAUD    =64 & 0x00FF;//38400波特率
        ScibRegs.SCICCR.bit.LOOPBKENA =0; // Enable loop back
        ScibRegs.SCICTL1.all =0x0023;     // Relinquish SCI from Reset
    ScibRegs.SCITXBUF=a;
void scib_fifo_init()
    ScibRegs.SCIFFTX.all=0xE040;
    ScibRegs.SCIFFRX.all=0x2044;
    ScibRegs.SCIFFCT.all=0x0;
        EALLOW;
        GpioCtrlRegs.GPAMUX2.bit.GPIO20 = 0;    //配置为通用I/O口
        GpioCtrlRegs.GPAMUX2.bit.GPIO21 = 0;
        GpioCtrlRegs.GPADIR.bit.GPIO20 = 1;     //作为输出I/O
        GpioDataRegs.GPADAT.bit.GPIO20 = 0;
        GpioDataRegs.GPADAT.bit.GPIO21 = 1;
        EDIS;
__interrupt void SCIRXINTb_ISR(void)     // SCI-B-RX  Receive Navigation
        int i;
        for (i=0;i<16;i++)
                Navdata = ScibRegs.SCIRXBUF.all;
        PieCtrlRegs.PIEACK.all = PIEACK_GROUP9;
        ErrorCount++;
        PieCtrlRegs.PIEACK.all = PIEACK_GROUP1;
 楼主| MapleSugar 发表于 2017-11-23 14:24 | 显示全部楼层
zhangmangui 发表于 2017-11-23 22:29 | 显示全部楼层
看看相关外设的时钟有没有使能
soodesyt 发表于 2017-11-23 22:29 | 显示全部楼层
楼主是怎么查看到sci有数据的?
mnynt121 发表于 2017-11-23 22:30 | 显示全部楼层
可以使用查询的方法。
plsbackup 发表于 2017-11-23 22:30 | 显示全部楼层
scib_loopback是什么意思?
mnynt121 发表于 2017-11-23 22:35 | 显示全部楼层
有可能中断没有开启。
plsbackup 发表于 2017-11-23 22:35 | 显示全部楼层
楼主的中断代码在哪配置的
soodesyt 发表于 2017-11-23 22:35 | 显示全部楼层
是单步调试吗?
xuerock 发表于 2019-1-16 16:17 | 显示全部楼层
//C2000ware
SCI_clearOverflowStatus(SCIA_BASE);
SCI_clearInterruptStatus(SCIA_BASE, SCI_INT_RXFF);
蒋博1026 发表于 2019-1-21 11:25 | 显示全部楼层
时钟使能了吗?如果没有使能,也会出现这种情况
狼烟客 发表于 2019-2-15 11:54 | 显示全部楼层
1、貌似没见使能SCI时钟;
2、使能SCI接收中断时,没有使用EALLOW对;
hitycy 发表于 2019-6-13 22:55 | 显示全部楼层
楼主问题解决了吗?把经验分享一下啊
