使用天嵌提供的3.6内核进行内核配置内核之后,不能启动内核 求大佬解答!!!!
467|1
434862295|  楼主 | 2017-11-25 12:05 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
434862295|  楼主 | 2017-11-25 12:06 | 只看该作者
U-Boot 2015.04 (Nov 25 2017 - 10:06:39)
CPU:   Freescale i.MX6Q rev1.5 at 792 MHz
CPU:   Temperature 38 C
Reset cause: POR
Board: MX6-SabreSD
I2C:   ready
DRAM:  2 GiB
MMC:   FSL_SDHC: 0, FSL_SDHC: 1, FSL_SDHC: 2
Display: CLAA-WVGA (800x480)
asd1
asd2
In:    serial
Out:   serial
Err:   serial
switch to partitions #0, OK
mmc2(part 0) is current device
check_and_clean: reg 0, flag_set 0
Fastboot: Normal
flash target is MMC:2
Bad partition index:5 for partition:system
Bad partition index:4 for partition:data
Net:   FEC [PRIME]
** Unable to read file **.bmp **
There is no valid bmp file at the given address
Normal Boot
Hit any key to stop autoboot:  0
reading zImage
8437728 bytes read in 397 ms (20.3 MiB/s)
reading imx6q-sabresd.dtb
44217 bytes read in 18 ms (2.3 MiB/s)
Kernel image @ 0x12000000 [ 0x000000 - 0x80bfe0 ]
## Flattened Device Tree blob at 18000000
   Booting using the fdt blob at 0x18000000
   Using Device Tree in place at 18000000, end 1800dcb8
Starting kernel ...
一直停留在这个界面!!!!!
求大佬解答一下
