[51单片机]
分享一个简单的音乐播放器
1505|7
一路向北lm|  楼主 | 2017-12-13 12:07 | 显示全部楼层 |阅读模式
乐谱部分
#ifndef __SOUNDPLAY_H_REVISION_FIRST__
#define __SOUNDPLAY_H_REVISION_FIRST__
#include"music.h"
#define SYSTEM_OSC                 12000000        //定义晶振频率12000000HZ
#define SOUND_SPACE         4/5                 //定义普通音符演奏的长度分率,//每4分音符间隔
sbit    BeepIO    =           P1^5;                //定义输出管脚
unsigned char value=0;
unsigned int  code FreTab[12]  = { 262,277,294,311,330,349,369,392,415,440,466,494 }; //原始频率表
unsigned char code SignTab[7]  = { 0,2,4,5,7,9,11 };        //1~7在频率表中的位置
unsigned char code LengthTab[7]= { 1,2,4,8,16,32,64 };
unsigned char Sound_Temp_TH0,Sound_Temp_TL0;        //音符定时器初值暂存
unsigned char Sound_Temp_TH1,Sound_Temp_TL1;        //音长定时器初值暂存
void InitialSound(void)
        BeepIO = 0;
        Sound_Temp_TH1 = (65535-(1/1200)*SYSTEM_OSC)/256;        // 计算TL1应装入的初值         (10ms的初装值)
        Sound_Temp_TL1 = (65535-(1/1200)*SYSTEM_OSC)%256;        // 计算TH1应装入的初值
        TH1 = Sound_Temp_TH1;
        TL1 = Sound_Temp_TL1;
        TMOD  |= 0x11;
        ET0    = 1;
        ET1           = 0;
        TR0           = 0;
        TR1    = 0;
        EA     = 1;
void BeepTimer0(void) interrupt 1        //音符发生中断
        static unsigned char i;
        BeepIO = !BeepIO;
        TH0    = Sound_Temp_TH0;
         TL0    = Sound_Temp_TL0;
        i++;
        if(i==100)
                i=0;
                value++;
                if(value==5)value=0;
void Play(unsigned char *Sound,unsigned char Signature,unsigned Octachord,unsigned int Speed)
        unsigned int NewFreTab[12];                //新的频率表
        unsigned char i,j;
        unsigned int Point,LDiv,LDiv0,LDiv1,LDiv2,LDiv4,CurrentFre,Temp_T,SoundLength;
        unsigned char Tone,Length,SL,SH,SM,SLen,XG,FD;
        for(i=0;i<12;i++)                                 // 根据调号及升降八度来生成新的频率表
                j = i + Signature;
                if(j > 11)
                        j = j-12;
                        NewFreTab = FreTab[j]*2;
                else
                        NewFreTab = FreTab[j];
                if(Octachord == 1)
                        NewFreTab>>=2;
                else if(Octachord == 3)
                        NewFreTab<<=2;
        SoundLength = 0;
        while(Sound[SoundLength] != 0x00)        //计算歌曲长度
                SoundLength+=2;
        Point = 0;
        Tone   = Sound[Point];
        Length = Sound[Point+1];                         // 读出第一个音符和它时时值
        LDiv0 = 12000/Speed;                                // 算出1分音符的长度(几个10ms)
        LDiv4 = LDiv0/4;                                         // 算出4分音符的长度
        LDiv4 = LDiv4-LDiv4*SOUND_SPACE;         // 普通音最长间隔标准
        TR0          = 0;
        TR1   = 1;
        while(Point < SoundLength)
                SL=Tone%10;        //计算出音符
                SM=Tone/10%10;        //计算出高低音
                SH=Tone/100;        //计算出是否升半
                CurrentFre = NewFreTab[SignTab[SL-1]+SH];         //查出对应音符的频率
                if(SL!=0)
                        if (SM==1) CurrentFre >>= 2;                 //低音
                        if (SM==3) CurrentFre <<= 2;                 //高音
                        Temp_T = 65536-(50000/CurrentFre)*10/(12000000/SYSTEM_OSC);//计算计数器初值
                        Sound_Temp_TH0 = Temp_T/256;
                        Sound_Temp_TL0 = Temp_T%256;
                        TL0 = Sound_Temp_TL0 + 12; //加12是对中断延时的补偿
                SLen=LengthTab[Length%10];         //算出是几分音符
                XG=Length/10%10;                         //算出音符类型(0普通1连音2顿音)
                FD=Length/100;
                LDiv=LDiv0/SLen;                         //算出连音音符演奏的长度(多少个10ms)
                if (FD==1)
                        LDiv=LDiv+LDiv/2;
                if(XG!=1)
                        if(XG==0)                                 //算出普通音符的演奏长度
                                if (SLen<=4)
                                        LDiv1=LDiv-LDiv4;
                                else
                                        LDiv1=LDiv*SOUND_SPACE;
                        else
                                LDiv1=LDiv/2;                 //算出顿音的演奏长度
                else
                        LDiv1=LDiv;
                if(SL==0) LDiv1=0;
                        LDiv2=LDiv-LDiv1;                 //算出不发音的长度
                  if (SL!=0)
                        TR0=1;
                        for(i=LDiv1;i>0;i--)         //发规定长度的音
                                while(TF1==0);
                                TF1=0;
                if(LDiv2!=0)
                        TR0=0; BeepIO=0;
                        for(i=LDiv2;i>0;i--)         //音符间的间隔
                                while(TF1==0);
                                TF1=0;
                Point+=2;
                Tone=Sound[Point];
                Length=Sound[Point+1];
        BeepIO = 0;
#endif
一路向北lm|  楼主 | 2017-12-13 12:08 | 显示全部楼层
音乐部分3首歌
#ifndef __MUSIC_H__
#define __MUSIC_H__
//*****************************Music******************************************************
//挥着翅膀的女孩
unsigned char code Music_Girl[]={ 0x17,0x02, 0x17,0x03, 0x18,0x03, 0x19,0x02, 0x15,0x03,
                                  0x16,0x03, 0x17,0x03, 0x17,0x03, 0x17,0x03, 0x18,0x03,
                                  0x19,0x02, 0x16,0x03, 0x17,0x03, 0x18,0x02, 0x18,0x03,
                                  0x17,0x03, 0x15,0x02, 0x18,0x03, 0x17,0x03, 0x18,0x02,
                                  0x10,0x03, 0x15,0x03, 0x16,0x02, 0x15,0x03, 0x16,0x03,
                                  0x17,0x02, 0x17,0x03, 0x18,0x03, 0x19,0x02, 0x1A,0x03,
                                  0x1B,0x03, 0x1F,0x03, 0x1F,0x03, 0x17,0x03, 0x18,0x03,
                                  0x19,0x02, 0x16,0x03, 0x17,0x03, 0x18,0x03, 0x17,0x03,
                                  0x18,0x03, 0x1F,0x03, 0x1F,0x02, 0x16,0x03, 0x17,0x03,
                                  0x18,0x03, 0x17,0x03, 0x18,0x03, 0x20,0x03, 0x20,0x02,
                                  0x1F,0x03, 0x1B,0x03, 0x1F,0x66, 0x20,0x03, 0x21,0x03,
                                  0x20,0x03, 0x1F,0x03, 0x1B,0x03, 0x1F,0x66, 0x1F,0x03,
                                  0x1B,0x03, 0x19,0x03, 0x19,0x03, 0x15,0x03, 0x1A,0x66,
                                  0x1A,0x03, 0x19,0x03, 0x15,0x03, 0x15,0x03, 0x17,0x03,
                                  0x16,0x66, 0x17,0x04, 0x18,0x04, 0x18,0x03, 0x19,0x03,
                                  0x1A,0x03, 0x19,0x03, 0x19,0x03, 0x1F,0x03, 0x1B,0x03,
                                  0x1F,0x00, 0x1A,0x03, 0x1A,0x03, 0x1A,0x03, 0x1B,0x03,
                                  0x1B,0x03, 0x1A,0x03, 0x19,0x03, 0x19,0x02, 0x17,0x03,
                                  0x15,0x17, 0x15,0x03, 0x16,0x03, 0x17,0x03, 0x18,0x03,
                                  0x17,0x04, 0x18,0x0E, 0x18,0x03, 0x17,0x04, 0x18,0x0E,
                                  0x18,0x66, 0x17,0x03, 0x18,0x03, 0x17,0x03, 0x18,0x03,
                                  0x20,0x03, 0x20,0x02, 0x1F,0x03, 0x1B,0x03, 0x1F,0x66,
                                  0x20,0x03, 0x21,0x03, 0x20,0x03, 0x1F,0x03, 0x1B,0x03,
                                  0x1F,0x66, 0x1F,0x04, 0x1B,0x0E, 0x1B,0x03, 0x19,0x03,
                                  0x19,0x03, 0x15,0x03, 0x1A,0x66, 0x1A,0x03, 0x19,0x03,
                                  0x15,0x03, 0x15,0x03, 0x17,0x03, 0x16,0x66, 0x17,0x04,
                                  0x18,0x04, 0x18,0x03, 0x19,0x03, 0x1F,0x03, 0x1B,0x03,
                                  0x1F,0x66, 0x20,0x03, 0x21,0x03, 0x20,0x03, 0x1F,0x03,
                                  0x1B,0x03, 0x1F,0x66, 0x1F,0x03, 0x1B,0x03, 0x19,0x03,
                                  0x19,0x03, 0x1F,0x03, 0x1B,0x03, 0x1F,0x00, 0x18,0x02,
                                  0x18,0x03, 0x1A,0x03, 0x19,0x0D, 0x15,0x03, 0x15,0x02,
                                  0x18,0x66, 0x16,0x02, 0x17,0x02, 0x15,0x00, 0x00,0x00};
//同一首歌
const unsigned char code Music_Same[]={ 0x0F,0x01, 0x15,0x02, 0x16,0x02, 0x17,0x66, 0x18,0x03,
                                  0x17,0x02, 0x15,0x02, 0x16,0x01, 0x15,0x02, 0x10,0x02,
                                  0x15,0x00, 0x0F,0x01, 0x15,0x02, 0x16,0x02, 0x17,0x02,
                                  0x17,0x03, 0x18,0x03, 0x19,0x02, 0x15,0x02, 0x18,0x66,
                                  0x17,0x03, 0x19,0x02, 0x16,0x03, 0x17,0x03, 0x16,0x00,
                                  0x17,0x01, 0x19,0x02, 0x1B,0x02, 0x1B,0x70, 0x1A,0x03,
                                  0x1A,0x01, 0x19,0x02, 0x19,0x03, 0x1A,0x03, 0x1B,0x02,
                                  0x1A,0x0D, 0x19,0x03, 0x17,0x00, 0x18,0x66, 0x18,0x03,
                                  0x19,0x02, 0x1A,0x02, 0x19,0x0C, 0x18,0x0D, 0x17,0x03,
                                  0x16,0x01, 0x11,0x02, 0x11,0x03, 0x10,0x03, 0x0F,0x0C,
                                  0x10,0x02, 0x15,0x00, 0x1F,0x01, 0x1A,0x01, 0x18,0x66,
                                  0x19,0x03, 0x1A,0x01, 0x1B,0x02, 0x1B,0x03, 0x1B,0x03,
                                  0x1B,0x0C, 0x1A,0x0D, 0x19,0x03, 0x17,0x00, 0x1F,0x01,
                                  0x1A,0x01, 0x18,0x66, 0x19,0x03, 0x1A,0x01, 0x10,0x02,
                                  0x10,0x03, 0x10,0x03, 0x1A,0x0C, 0x18,0x0D, 0x17,0x03,
                                  0x16,0x00, 0x0F,0x01, 0x15,0x02, 0x16,0x02, 0x17,0x70,
                                  0x18,0x03, 0x17,0x02, 0x15,0x03, 0x15,0x03, 0x16,0x66,
                                  0x16,0x03, 0x16,0x02, 0x16,0x03, 0x15,0x03, 0x10,0x02,
                                  0x10,0x01, 0x11,0x01, 0x11,0x66, 0x10,0x03, 0x0F,0x0C,
                                  0x1A,0x02, 0x19,0x02, 0x16,0x03, 0x16,0x03, 0x18,0x66,
                                  0x18,0x03, 0x18,0x02, 0x17,0x03, 0x16,0x03, 0x19,0x00,
                                  0x00,0x00 };
//两只蝴蝶
const unsigned char code Music_Two[] ={ 0x17,0x03, 0x16,0x03, 0x17,0x01, 0x16,0x03, 0x17,0x03,
                                  0x16,0x03, 0x15,0x01, 0x10,0x03, 0x15,0x03, 0x16,0x02,
                                  0x16,0x0D, 0x17,0x03, 0x16,0x03, 0x15,0x03, 0x10,0x03,
                                  0x10,0x0E, 0x15,0x04, 0x0F,0x01, 0x17,0x03, 0x16,0x03,
                                  0x17,0x01, 0x16,0x03, 0x17,0x03, 0x16,0x03, 0x15,0x01,
                                  0x10,0x03, 0x15,0x03, 0x16,0x02, 0x16,0x0D, 0x17,0x03,
                                  0x16,0x03, 0x15,0x03, 0x10,0x03, 0x15,0x03, 0x16,0x01,
                                  0x10,0x0E, 0x15,0x04, 0x0F,0x01, 0x17,0x03, 0x19,0x03,
                                  0x19,0x01, 0x19,0x03, 0x1A,0x03, 0x19,0x03, 0x17,0x01,
                                  0x16,0x03, 0x16,0x03, 0x16,0x02, 0x16,0x0D, 0x17,0x03,
                                  0x16,0x03, 0x15,0x03, 0x10,0x03, 0x10,0x0D, 0x15,0x00,
                                  0x19,0x03, 0x19,0x03, 0x1A,0x03, 0x1F,0x03, 0x1B,0x03,
                                  0x1B,0x03, 0x1A,0x03, 0x17,0x0D, 0x16,0x03, 0x16,0x03,
                                  0x16,0x0D, 0x17,0x01, 0x17,0x03, 0x17,0x03, 0x19,0x03,
                                  0x1A,0x02, 0x1A,0x02, 0x10,0x03, 0x17,0x0D, 0x16,0x03,
                                  0x16,0x01, 0x17,0x03, 0x19,0x03, 0x19,0x03, 0x17,0x03,
                                  0x19,0x02, 0x1F,0x02, 0x1B,0x03, 0x1A,0x03, 0x1A,0x0E,
                                  0x1B,0x04, 0x17,0x02, 0x1A,0x03, 0x1A,0x03, 0x1A,0x0E,
                                  0x1B,0x04, 0x1A,0x03, 0x19,0x03, 0x17,0x03, 0x16,0x03,
                                  0x17,0x0D, 0x16,0x03, 0x17,0x03, 0x19,0x01, 0x19,0x03,
                                  0x19,0x03, 0x1A,0x03, 0x1F,0x03, 0x1B,0x03, 0x1B,0x03,
                                  0x1A,0x03, 0x17,0x0D, 0x16,0x03, 0x16,0x03, 0x16,0x03,
                                  0x17,0x01, 0x17,0x03, 0x17,0x03, 0x19,0x03, 0x1A,0x02,
                                  0x1A,0x02, 0x10,0x03, 0x17,0x0D, 0x16,0x03, 0x16,0x01,
                                  0x17,0x03, 0x19,0x03, 0x19,0x03, 0x17,0x03, 0x19,0x03,
                                  0x1F,0x02, 0x1B,0x03, 0x1A,0x03, 0x1A,0x0E, 0x1B,0x04,
                                  0x17,0x02, 0x1A,0x03, 0x1A,0x03, 0x1A,0x0E, 0x1B,0x04,
                                  0x17,0x16, 0x1A,0x03, 0x1A,0x03, 0x1A,0x0E, 0x1B,0x04,
                                  0x1A,0x03, 0x19,0x03, 0x17,0x03, 0x16,0x03, 0x0F,0x02,
                                  0x10,0x03, 0x15,0x00, 0x00,0x00 };
#endif
一路向北lm|  楼主 | 2017-12-13 12:09 | 显示全部楼层
1602显示部分
#include"lcd.h"
void Read_Busy()           //忙检测函数,判断bit7是0,允许执行;1禁止
    unsigned char sta;      //
    LCD1602_DB = 0xff;
    LCD1602_RS = 0;
    LCD1602_RW = 1;
    do
        LCD1602_EN = 1;
        sta = LCD1602_DB;
        LCD1602_EN = 0;    //使能,用完就拉低,释放总线
    }while(sta & 0x80);
void Lcd1602_Write_Cmd(unsigned char cmd)     //写命令
    Read_Busy();
    LCD1602_RS = 0;
    LCD1602_RW = 0;
    LCD1602_DB = cmd;
    LCD1602_EN = 1;
    LCD1602_EN = 0;
void Lcd1602_Write_Data(unsigned char dat)   //写数据
      Read_Busy();
      LCD1602_RS = 1;
      LCD1602_RW = 0;
      LCD1602_DB = dat;
      LCD1602_EN = 1;
      LCD1602_EN = 0;
void LcdSetCursor(unsigned char x,unsigned char y)  //坐标显示
    unsigned char addr;
    if(y == 0)
        addr = 0x00 + x;
    else
        addr = 0x40 + x;
    Lcd1602_Write_Cmd(addr|0x80);
//按指定位置显示一个字符
void DisplayOneChar(unsigned char X, unsigned char Y, unsigned char DData)
        Y &= 0x1;
        X &= 0xF; //限制X不能大于15,Y不能大于1
        if (Y) X |= 0x40; //当要显示第二行时地址码+0x40;
        X |= 0x80; //算出指令码
        Lcd1602_Write_Cmd(X); //发命令字
        Lcd1602_Write_Data(DData); //发数据
void LcdShowStr(unsigned char x,unsigned char y,unsigned char *str)     //显示字符串
    LcdSetCursor(x,y);      //当前字符的坐标
    while(*str != '\0')
        Lcd1602_Write_Data(*str++);
void InitLcd1602()              //1602初始化
    Lcd1602_Write_Cmd(0x38);    //打开,5*8,8位数据
    Lcd1602_Write_Cmd(0x0c);
    Lcd1602_Write_Cmd(0x06);
    Lcd1602_Write_Cmd(0x01);    //清屏
一路向北lm|  楼主 | 2017-12-13 12:10 | 显示全部楼层
代码在这了需要玩的可以来下载 音乐播放器.rar (82.14 KB)
广东梁百万| | 2017-12-22 12:34 | 显示全部楼层
用什么单片机的?
ifxz0123| | 2018-1-2 09:49 | 显示全部楼层
不错,有时间研究研究
cactus0117| | 2018-1-4 16:16 | 显示全部楼层
zqx1000| | 2018-4-10 21:27 | 显示全部楼层
kankan
