【嵌入式开发】手把手教你4418/6818开发板屏幕修改
1836|6
流年o空折枝|  楼主 | 2017-12-18 16:34 | 显示全部楼层 |阅读模式
本文转自迅为
开发平台:iTOP-4418/6818开发板
4418&6818屏幕修改分别需要修改uboot和内核,首先是修改uboot
1.首先进入到android源码目录下:
4418平台,需要修改uboot的文件是:u-boot/board/s5p4418/drone2/board.c,使用vi命令打开这个文件,屏幕的默认参数设置在49行到93行,如下图:
4418暂时支持9.7寸,7寸,4.3寸屏幕,他们的设置在该文件,如下图所示的地方:
上图中代码的功能,首先是从uboot的环境变量里面读取出当前使用的哪款屏幕,然后根据屏幕类型选择对应分支的设置。比如屏幕的宽,高,刷新率,如果用户使用其它的屏幕,需要在此处修改(需要根据自己屏幕的参数,修改图2中的那些默认变量)(6818的修改文件是:u-boot/board/s5p6818/dronel/board.c,方法同上)
2linux内核部分的修改:
首先是文件kernel/arch/arm/plat-s5p4418/topeet/include/cfg_main.h(6818对应的文件是:kernel/arch/arm/plat-s5p6818/topeet/include/cfg_main.h)
这个文件里定义里一组与屏幕相关的宏,如下所示:
*      Display (DPC and MLC)
/* Primary */
#define CFG_DISP_PRI_SCREEN_LAYER               0
#define CFG_DISP_PRI_SCREEN_RGB_FORMAT          MLC_RGBFMT_A8R8G8B8
#define CFG_DISP_PRI_SCREEN_PIXEL_BYTE          4
#define CFG_DISP_PRI_SCREEN_COLOR_KEY           0x090909
#define CFG_DISP_PRI_VIDEO_PRIORITY                             2       // 0, 1, 2, 3
#define CFG_DISP_PRI_BACK_GROUND_COLOR          0x000000
#define CFG_DISP_PRI_MLC_INTERLACE              CFALSE
#define CFG_DISP_PRI_LCD_WIDTH_MM                               154
#define CFG_DISP_PRI_LCD_HEIGHT_MM                              85
/* modify by cym 20150811 */
#if 0
#define CFG_DISP_PRI_RESOL_WIDTH                        1024    // X Resolution
#define CFG_DISP_PRI_RESOL_HEIGHT                               600     // Y Resolution
#else
#define CFG_DISP_PRI_RESOL_WIDTH                        800//1024    // X Resolution
#define CFG_DISP_PRI_RESOL_HEIGHT                               1280//768     // Y Resolution
#endif
/* end remove */
#define CFG_DISP_PRI_HSYNC_SYNC_WIDTH            20
#define CFG_DISP_PRI_HSYNC_BACK_PORCH           160
#define CFG_DISP_PRI_HSYNC_FRONT_PORCH          160
#define CFG_DISP_PRI_HSYNC_ACTIVE_HIGH          CTRUE
#define CFG_DISP_PRI_VSYNC_SYNC_WIDTH            3
#define CFG_DISP_PRI_VSYNC_BACK_PORCH            23
#define CFG_DISP_PRI_VSYNC_FRONT_PORCH           12
#define CFG_DISP_PRI_VSYNC_ACTIVE_HIGH          CTRUE
#define CFG_DISP_PRI_CLKGEN0_SOURCE             DPC_VCLK_SRC_PLL2
#define CFG_DISP_PRI_CLKGEN0_DIV                12 // even divide
#define CFG_DISP_PRI_CLKGEN0_DELAY              0
#define CFG_DISP_PRI_CLKGEN0_INVERT                             0
#define CFG_DISP_PRI_CLKGEN1_SOURCE             DPC_VCLK_SRC_VCLK2
#define CFG_DISP_PRI_CLKGEN1_DIV                1
#define CFG_DISP_PRI_CLKGEN1_DELAY              0
#define CFG_DISP_PRI_CLKGEN1_INVERT                             0
#define CFG_DISP_PRI_CLKSEL1_SELECT                             0
#define CFG_DISP_PRI_PADCLKSEL                  DPC_PADCLKSEL_VCLK      /* VCLK=CLKGEN1, VCLK12=CLKGEN0 */
#define CFG_DISP_PRI_PIXEL_CLOCK                                800000000/CFG_DISP_PRI_CLKGEN0_DIV
#define CFG_DISP_PRI_OUT_SWAPRB                                 CFALSE
#define CFG_DISP_PRI_OUT_FORMAT                 DPC_FORMAT_RGB888
#define CFG_DISP_PRI_OUT_YCORDER                DPC_YCORDER_CbYCrY
#define CFG_DISP_PRI_OUT_INTERLACE              CFALSE
#define CFG_DISP_PRI_OUT_INVERT_FIELD           CFALSE
#define CFG_DISP_LCD_MPY_TYPE                                           0
*      LVDS
#if 0
#define CFG_DISP_LVDS_LCD_FORMAT                LVDS_LCDFORMAT_VESA
#else
#define CFG_DISP_LVDS_LCD_FORMAT                LVDS_LCDFORMAT_JEIDA
#endif
/* end modify */
然后是文件:kernel/arch/arm/plat-s5p4418/topeet/device.c(6818对应的文件:kernel/arch/arm/plat-s5p6818/topeet/device.c)
在这个文件找到函数setup_width_height_param,如下:
/* add by cym 20151128 */
#if 1
static int __init setup_width_height_param(char *str)
        if (!strncasecmp("9.7", str, 3)) {
                //printk("fun:%s, line = %d(lcdtype:%s)\n", __FUNCTION__, __LINE__, str);
#if defined(CONFIG_TOUCHSCREEN_FT5X0X)
                ft5x0x_pdata.screen_max_x = 768;
                ft5x0x_pdata.screen_max_y = 1024;
#endif
#if defined (CONFIG_FB_NXP)
#if defined (CONFIG_FB0_NXP)
                fb0_plat_data.x_resol = 1024;
                fb0_plat_data.y_resol = 768;
#endif
#endif
        else if(!strncasecmp("7.0", str, 3))
                ft5x0x_pdata.screen_max_x = 800;
                ft5x0x_pdata.screen_max_y = 1280;
#endif
                fb0_plat_data.x_resol = 800;
                fb0_plat_data.y_resol = 1280;
#endif
#endif
/* add by cym 20160222 */
#if 1
        else if(!strncasecmp("4.3", str, 3))
                fb0_plat_data.x_resol = 480;
                fb0_plat_data.y_resol = 272;
#endif
#endif
#endif
/* end add */
/* add by cym 20170810 */
#if 1
        else if(!strncasecmp("1024x600", str, 8))
                ft5x0x_pdata.screen_max_x = 600;
                ft5x0x_i2c_bdi.irq = PB_PIO_IRQ(CFG_IO_TSC2007_TOUCH_PENDOWN_DETECT);
                ft5x0x_pdata.gpio_irq = CFG_IO_TSC2007_TOUCH_PENDOWN_DETECT;
                tsc2007_i2c_bdi.irq = NULL;//PB_PIO_IRQ(CFG_IO_TOUCH_PENDOWN_DETECT);
#endif
                fb0_plat_data.y_resol = 600;
#endif
#endif
#endif
/* end add */
/* add by cym 20161104 */
#if 1
        else if(!strncasecmp("hdmi", str, 3))
                fb0_plat_data.x_resol = 1920;
                fb0_plat_data.y_resol = 1080;
#endif
#endif
#endif
/* end add */
        //printk("fun:%s, line = %d\n", __FUNCTION__, __LINE__);
early_param("lcdtype", setup_width_height_param);
#endif
/* end add */
这个函数根据uboot传递过来的lcdtype选择对应屏幕的设置,这里主要是修改屏幕的分辨率,如果使用其它屏幕,修改对应的分辨率就可以了。
然后是文件:kernel/arch/arm/mach-s5p4418/dev-display.c(6818对应的文件:kernel/arch/arm/mach-s5p4418/dev-display.c)
同样在这个文件找到函数:setup_width_height_param,如下所示:
#if 1
#if defined (CONFIG_NXP_DISPLAY_LCD)
#if defined(CFG_DISP_PRI_RESOL_WIDTH) && defined(CFG_DISP_PRI_RESOL_HEIGHT)
                __lcd_vsync.h_active_len = 1024;
                __lcd_vsync.v_active_len = 768;
                __lcd_vsync.clk_div_lv0 = 14;
#endif
#endif
#if defined (CONFIG_NXP_DISPLAY_LVDS)
                __lvds_vsync.h_active_len = 1024;
                __lvds_vsync.v_active_len = 768;
                __lvds_vsync.clk_div_lv0 = 14;
#endif
#endif
#if defined (CONFIG_NXP_DISPLAY_MIPI)
                __mipi_vsync.h_active_len = 1024;
                __mipi_vsync.v_active_len = 768;
                __mipi_vsync.clk_div_lv0 = 14;
#endif
#endif
                 __lcd_vsync.h_active_len = 800;
                 __lcd_vsync.v_active_len = 1280;
#endif
#endif
                 __lvds_vsync.h_active_len = 800;
                 __lvds_vsync.v_active_len = 1280;
#endif
#endif
                 __mipi_vsync.h_active_len = 800;
                 __mipi_vsync.v_active_len = 1280;
#endif
#endif
#if 1
                 __lcd_vsync.h_active_len = 480;
                 __lcd_vsync.v_active_len = 272;
                __lcd_vsync.clk_div_lv0 = 24;
                __lcd_vsync.clk_div_lv1 = 2;
#endif
#endif
流年o空折枝|  楼主 | 2017-12-18 16:36 | 显示全部楼层
                 __lvds_vsync.h_active_len = 480;
                 __lvds_vsync.v_active_len = 272;
                __lvds_vsync.clk_div_lv0 = 24;
                __lvds_vsync.clk_div_lv1 = 2;
#endif
#endif
                 __mipi_vsync.h_active_len = 480;
                 __mipi_vsync.v_active_len = 272;
                 __mipi_vsync.clk_div_lv0 = 24;
                 __mipi_vsync.clk_div_lv1 = 2;
#endif
#endif
#endif
/* end add */
#if 1
                 __lcd_vsync.v_active_len = 600;
                //__lcd_vsync.clk_div_lv0 = 24;
                //__lcd_vsync.clk_div_lv1 = 2;
#endif
#endif
                 __lvds_vsync.v_active_len = 600;
                //__lvds_vsync.clk_div_lv0 = 24;
                //__lvds_vsync.clk_div_lv1 = 2;
#endif
#endif
                 __mipi_vsync.v_active_len = 600;
                 //__mipi_vsync.clk_div_lv0 = 24;
                 //__mipi_vsync.clk_div_lv1 = 2;
#endif
#endif
#endif
/* end add */
#if 1
                 __lcd_vsync.h_active_len = 1920;
                 __lcd_vsync.v_active_len = 1080;
#endif
#endif
                 __lvds_vsync.h_active_len = 1920;
                 __lvds_vsync.v_active_len = 1080;
#endif
#endif
                 __mipi_vsync.h_active_len = 1920;
                 __mipi_vsync.v_active_len = 1080;
#endif
#endif
#endif
/* end add */
#endif
/* end add */
这个函数根据uboot传递过来的lcdtype选择对应屏幕的设置,这里主要是修改屏幕的分辨率,刷新率,如果使用其它屏幕,修改对应的分辨率就可以了。
关于屏幕的设置主要就是修改上面的文件
修一明| | 2017-12-18 17:24 | 显示全部楼层
感谢分享  学习。。。
1470432022| | 2017-12-25 09:33 | 显示全部楼层
学习了,好贴,多谢分享内容
冥月33| | 2018-1-9 09:54 | 显示全部楼层
首先是修改uboot,学习了,赞
476143805| | 2018-1-17 09:42 | 显示全部楼层
多谢分享内容,学习了,赞
如疯如醉| | 2018-2-27 09:50 | 显示全部楼层
多谢分享内容,学习了
