[资料分享]
TI采用无线振动传感器的电机监控参考设计
828|3
xyz549040622|  楼主 | 2017-12-27 07:08 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
描述
This reference design is a low-power wireless subsystem solution that monitors motors using vibration sensing to determine if preventative maintenance is necessary. An FFT of the vibration data can be sent out to another device using either Bluetooth low energy or sub-1GHz wireless protocols. The low power usage and wireless capabilities of this subsystem solution enables it to run on a single coin cell battery, which allows for the device to be small, inexpensive and placed in difficult-to-reach locations. This makes this reference design an ideal alternative to both expensive maintenance that could have been preventatively avoided, as well as larger, more expensive monitors that require a wired connection.
特性
  • Ultra-low-power design resulting in 10-year battery life from single CR2032 coin cell
  • Offers mechanical vibration (20ksps) and termperature sensing
  • Local computation of 2K FFT for vibration spectral analysis
  • Programmable wake-up intervals for motor diagnostics
  • Designed for SimpleLink sub-1GHz and Bluetooth Low Energy Wireless Connectivity LaunchPad (LAUNCHXL-CC1350)
xyz549040622|  楼主 | 2017-12-27 07:10 | 只看该作者
TIDA-01469 Schematic and Block Diagram.pdf (290.52 KB)
采用无线振动传感器并支持预防性维护的电机监控参考设计.pdf (4.13 MB)
xyz549040622|  楼主 | 2017-12-27 07:11 | 只看该作者
TIDA-01469 BOM.pdf (65.08 KB)
个人签名:qq群: 嵌入式系统arm初学者 224636155←← +→→点击-->小 i 精品课全集,21ic公开课~~←←→→点击-->小 i 精品课全集,给你全方位的技能策划~~←←
2696
