[技术问答]
N76E003的ADC是这样的吗?
4091|10
dontium|  楼主 | 2018-1-11 12:09 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
因为用到N76E003的ADC,在调试时,以为自己的程序有问题,最后发现是ADC结果不对,随后用万用表测量ADC的输入端电压,与输出的数据作比较,大概地画了如下图:
ADC在输入电压为0时,也是很小的数值。
ADC的端口已设置成Input_Mode,并且使用了AINDIDS禁止了数据口的连接
gejigeji521| | 2018-1-11 20:49 | 只看该作者
跑一下官方的例子试试看有没有问题。
gejigeji521| | 2018-1-11 20:50 | 只看该作者
/* Copyright(c) 2017 Nuvoton Technology Corp. All rights reserved.                                         */
//  Nuvoton Technoledge Corp.
//  Website: http://www.nuvoton.com
//  E-Mail : MicroC-8bit@nuvoton.com
//  Date   : Apr/21/2017
//  File Function: N76E003 ADC demo code
#include "N76E003.h"
#include "SFR_Macro.h"
#include "Function_define.h"
#include "Common.h"
#include "Delay.h"
//*****************  The Following is in define in Fucntion_define.h  ***************************
//****** Always include Function_define.h call the define you want, detail see main(void) *******
#if 0
//#define Enable_ADC_AIN0                        ADCCON0&=0xF0;P17_Input_Mode;AINDIDS=0x00;AINDIDS|=SET_BIT0;ADCCON1|=SET_BIT0        //P17
//#define Enable_ADC_AIN1                        ADCCON0&=0xF0;ADCCON0|=0x01;P30_Input_Mode;AINDIDS=0x00;AINDIDS|=SET_BIT1;ADCCON1|=SET_BIT0                //P30
//#define Enable_ADC_AIN2                        ADCCON0&=0xF0;ADCCON0|=0x02;P07_Input_Mode;AINDIDS=0x00;AINDIDS|=SET_BIT2;ADCCON1|=SET_BIT0                //P07
//#define Enable_ADC_AIN3                        ADCCON0&=0xF0;ADCCON0|=0x03;P06_Input_Mode;AINDIDS=0x00;AINDIDS|=SET_BIT3;ADCCON1|=SET_BIT0                //P06
//#define Enable_ADC_AIN4                        ADCCON0&=0xF0;ADCCON0|=0x04;P05_Input_Mode;AINDIDS=0x00;AINDIDS|=SET_BIT4;ADCCON1|=SET_BIT0                //P05
//#define Enable_ADC_AIN5                        ADCCON0&=0xF0;ADCCON0|=0x05;P04_Input_Mode;AINDIDS=0x00;AINDIDS|=SET_BIT5;ADCCON1|=SET_BIT0                //P04
//#define Enable_ADC_AIN6                        ADCCON0&=0xF0;ADCCON0|=0x06;P03_Input_Mode;AINDIDS=0x00;AINDIDS|=SET_BIT6;ADCCON1|=SET_BIT0                //P03
//#define Enable_ADC_AIN7                        ADCCON0&=0xF0;ADCCON0|=0x07;P11_Input_Mode;AINDIDS=0x00;AINDIDS|=SET_BIT7;ADCCON1|=SET_BIT0                //P11
//#define Enable_ADC_BandGap        ADCCON0|=SET_BIT3;ADCCON0&=0xF8;        //Band-gap 1.22V
//#define PWM0_FALLINGEDGE_TRIG_ADC                ADCCON0&=~SET_BIT5;ADCCON0&=~SET_BIT4;ADCCON1&=~SET_BIT3;ADCCON1&=~SET_BIT2;ADCCON1|=SET_BIT1
//#define PWM2_FALLINGEDGE_TRIG_ADC                ADCCON0&=~SET_BIT5;ADCCON0|=SET_BIT4;ADCCON1&=~SET_BIT3;ADCCON1&=~SET_BIT2;ADCCON1|=SET_BIT1
//#define PWM4_FALLINGEDGE_TRIG_ADC                ADCCON0|=SET_BIT5;ADCCON0&=~SET_BIT4;ADCCON1&=~SET_BIT3;ADCCON1&=~SET_BIT2;ADCCON1|=SET_BIT1
//#define PWM0_RISINGEDGE_TRIG_ADC                ADCCON0&=~SET_BIT5;ADCCON0&=~SET_BIT4;ADCCON1&=~SET_BIT3;ADCCON1|=SET_BIT2;ADCCON1|=SET_BIT1
//#define PWM2_RISINGEDGE_TRIG_ADC                ADCCON0&=~SET_BIT5;ADCCON0|=SET_BIT4;ADCCON1&=~SET_BIT3;ADCCON1|=SET_BIT2;ADCCON1|=SET_BIT1
//#define PWM4_RISINGEDGE_TRIG_ADC                ADCCON0|=SET_BIT5;ADCCON0&=~SET_BIT4;ADCCON1&=~SET_BIT3;ADCCON1|=SET_BIT2;ADCCON1|=SET_BIT1
//#define P04_FALLINGEDGE_TRIG_ADC                ADCCON0|=0x30;ADCCON1&=0xF3;ADCCON1|=SET_BIT1;ADCCON1&=~SET_BIT6
//#define P13_FALLINGEDGE_TRIG_ADC                ADCCON0|=0x30;ADCCON1&=0xF3;ADCCON1|=SET_BIT1;ADCCON1|=SET_BIT6
//#define P04_RISINGEDGE_TRIG_ADC                        ADCCON0|=0x30;ADCCON1&=~SET_BIT3;ADCCON1|=SET_BIT2;ADCCON1|=SET_BIT1;ADCCON1&=~SET_BIT6
//#define P13_RISINGEDGE_TRIG_ADC                        ADCCON0|=0x30;ADCCON1&=~SET_BIT3;ADCCON1|=SET_BIT2;ADCCON1|=SET_BIT1;ADCCON1|=SET_BIT6
#endif
The main C function.  Program execution starts
here after stack initialization.
void main (void)
                InitialUART0_Timer1(115200);
                Enable_ADC_AIN3;                                                // Enable AIN0 P1.7 as ADC input, Find in "Function_define.h" - "ADC INIT"
                while(1)
                        clr_ADCF;
                        set_ADCS;        // ADC start trig signal
      while(ADCF == 0);
                        printf ("\n Value = 0x%bx",ADCRH);
                        printf ("\n Value = 0x%bx",ADCRL);
                        Timer0_Delay1ms(100);
dontium|  楼主 | 2018-1-11 22:16 | 只看该作者
谢谢您。
程序看了
598330983| | 2018-1-12 19:43 | 只看该作者
这个是啥原因造成的那一段不稳?
玛尼玛尼哄| | 2018-1-13 19:25 | 只看该作者
之前看到有人发同样的问题,不过目前还没遇到这种。
dontium|  楼主 | 2018-1-13 22:24 | 只看该作者
电源电压变引起的
huangcunxiake| | 2018-1-14 12:53 | 只看该作者
dontium 发表于 2018-1-13 22:24
是电源电压变化引起的
?电源不稳定?那怎么就那一段有问题,用的什么电源?建议以后这种用电池供电测试,防止直流电源不稳定。
xixi2017| | 2018-1-14 16:17 | 只看该作者
看来每个细节出错都很危险。
heisexingqisi| | 2018-1-14 17:03 | 只看该作者
看来电源不稳影响地方太多了。
643757107| | 2018-1-15 14:36 | 只看该作者
电源肯定很重要,不稳定的话,好多外设都会失灵。
个人签名:官向官来民向民,穷人向的是穷人
143
