golang 把http封装一下
1091|4
keer_zu|  楼主 | 2018-1-22 17:48 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
package api
import(
"io/ioutil"
    "net/http"
    "bytes"
    jsoniter "github.com/json-iterator/go"
    "fmt"
    "errors"
var http_url string = "http://10.10.1.20:8083"
type Error struct {
        Code         int                 `json:"code"`
        Message         string         `json:"message"`
type HttpCmd struct {
        //CmdPost(string) (string,error)
func (c *HttpCmd)CmdPost(jsonCmd string)([]byte,error) {
        body := jsonCmd
        res, err := http.Post(http_url, "application/json;charset=utf-8", bytes.NewBuffer([]byte(body)))
        if err != nil {
                fmt.Println("Fatal error ", err.Error())
                return nil,err
        defer res.Body.Close()
        content, err := ioutil.ReadAll(res.Body)
        if err != nil {
                return nil,err
        return content,nil
func (c *HttpCmd) CmdParse (res []byte,result interface{}) (ResultComm,error){
        var params ResultComm
        params.SetResult(result)
        if err := jsoniter.Unmarshal(res,&params); err != nil{
                return params, err
        if params.GetError() != nil{
                errMsg := fmt.Sprintf("%v", params.GetError())
                return params, errors.New(errMsg)
        return params, nil
type CmdResult interface {
        GetError()*Error
        GetId()int
        GetResult()interface{}
        SetResult(interface{})
type CmdAddAsset struct {
        HttpCmd
        ResultComm
type AddAssetResul struct {
type ResultComm struct {
        Err                 *Error                 `json:"error"`
        Result         interface{}         `json:"result"`
        Id                 int                         `json:"id"`
func (r *ResultComm)GetError()*Error{
        return r.Err
func (r *ResultComm)GetId()int {
        return r.Id
func (r *ResultComm)GetResult()interface{}{
        return r.Result
func (r *ResultComm)SetResult(result interface{}){
        r.Result = result
type CmdAddMarket struct {
        HttpCmd
        ResultComm
type CmdMarketSummary struct {
        HttpCmd
        ResultComm
type MarketSummaryResult struct {
        Name                 string                 `json:"name"`
        Ask_count         int                         `json:"ask_count"`
        Ask_amount         string                `json:"ask_amount"`
        Bid_count         int                         `json:"bid_count"`
        bid_amount         string                 `json:"bid_amount"`
type CommCommand struct {
        HttpCmd
        ResultComm
keer_zu|  楼主 | 2018-1-22 17:49 | 只看该作者
使用:
package main
import (
    "fmt"
    "./api"
var idCount int = 1
func BuildAssetAddCmd(name string,prec_save int,prec_show int) string {
    str := fmt.Sprintf("{\"method\": \"asset.add_new\",\"params\":[\"%s\",%d,%d],\"id\":%d}",name,prec_save,prec_show,idCount)
    idCount += 1
    return str
func main() {
    fmt.Printf("----")
    // cmdAddAsset := new(api.CmdAddAsset)
    // cmdStr := BuildAssetAddCmd("BBC",20,8)
    // fmt.Printf("@@     %s\n",cmdStr)
    // bd,e := cmdAddAsset.CmdPost(cmdStr)
    // if e != nil {
    //     fmt.Println(e)
    // fmt.Printf("bd:  %v\n",bd)
    // cmdAddAsset.CmdParse(bd)
    str := "{\"method\": \"market.summary\", \"params\": [\"EOSBTC\"], \"id\": 123}"
    cmdMarketSummary  := new(api.CmdMarketSummary)
    bs,es := cmdMarketSummary.CmdPost(str)
    if es != nil {
        fmt.Printf("err: %v \n",es)
        return
    fmt.Printf("bs:  %s\n",bs)
    var results  []*api.MarketSummaryResult
    //cmdMarketSummary.SetResult(&results)
    cmdMarketSummary.CmdParse(bs,&results)
    //fmt.Printf("result len: %d\n",len(results))
    fmt.Printf("name: %s\n",results[0].Name)
    fmt.Printf("Ask_count: %d\n",results[0].Ask_count)
    fmt.Printf("Ask_amount: %s\n",results[0].Ask_amount)
gujiamao12345| | 2018-1-22 17:58 | 只看该作者
版主搞的东西真多
keer_zu|  楼主 | 2018-1-23 11:01 | 只看该作者
这个做客户端勉强可以,做服务端还不行。尝试一下evio
keer_zu|  楼主 | 2018-1-23 15:37 | 只看该作者
加上http的get请求:
package api
import(
"io/ioutil"
    "net/http"
    "bytes"
    "fmt"
    "errors"
    "strings"
type Error struct {
type ApiError struct {
        Error_code         int                 `json:"error_code"`
        Result                 bool         `json:"result"`
//type ApiTicker
func TestGetResParse(ret []byte,res interface{}) error{
        var resApi ApiResComm
        resApi.SetRes(res)
        str :=  string(ret[1:len(ret)-1])  //需要正则
        strUn := strings.Replace("{\"res\":" + str + "}","\\","",-1)
        byteUn :=  []byte(strUn)
        fmt.Printf("byteUn: %s\n",byteUn)
        if err := jsoniter.Unmarshal(byteUn,&resApi); err != nil{
                fmt.Printf("parse error: %s\n",err.Error())
                return err
        return nil
        body := jsonCmd
        if err != nil {
                fmt.Println("http post error ", err.Error())
                return nil,err
        if err != nil {
                fmt.Println("post, read body error ", err.Error())
                return nil,err
        return content,nil
func (c *HttpCmd) CmdGet(getUrl string)([]byte,error) {
        resp, err := http.Get(getUrl)
        if err != nil {
                fmt.Println("http Get error ", err.Error())
                return nil,err
        defer resp.Body.Close()
        content, err := ioutil.ReadAll(resp.Body)
        if err != nil {
                fmt.Println("get, read body error ", err.Error())
                return nil,err
        return content,nil
                return params, err
        return params, nil
func (c *HttpCmd) ApiResParse(ret []byte,res interface{})(int,error){
         var apiError ApiError
        resApi.SetRes(res)
        strEt := strings.Replace(str,"\\","",-1)
        if err := jsoniter.Unmarshal([]byte(strEt),&apiError); err != nil{
                 fmt.Printf("api error parse error: %s\n",err.Error())
                 return 0,err
        //fmt.Printf("byteUn: %s\n",byteUn)
        if apiError.Error_code != 0 {
                return apiError.Error_code,nil
                fmt.Printf("api result parse error: %s\n",err.Error())
                return 0,err
        return 0,nil
        GetError()*Error
        GetId()int
type ApiRes interface {
        GetRes()interface{}
        SetRes(interface{})
        HttpCmd
        ResultComm
        Id                 int                         `json:"id"`
        return r.Err
        return r.Id
        return r.Result
        r.Result = result
type ApiResComm struct {
        Res         interface{}         `json:"res"`
func (r *ApiResComm)GetRes()interface{}{
        return r.Res
func (r *ApiResComm)SetRes(res interface{}){
        r.Res = res
        HttpCmd
        ResultComm
        HttpCmd
        ResultComm
        HttpCmd
        ResultComm
type ApiCommand struct {
        HttpCmd
        ApiResComm
