[技术问答]
N76E003如何用串口发字符串?
2545|10
lansefeiyang|  楼主 | 2018-1-24 16:54 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
请问如何用串口发字符串?
huangcunxiake| | 2018-1-24 18:40 | 只看该作者
发送数字是:
/* Copyright(c) 2017 Nuvoton Technology Corp. All rights reserved.                                         */
//  Nuvoton Technoledge Corp.
//  Website: http://www.nuvoton.com
//  E-Mail : MicroC-8bit@nuvoton.com
//  Date   : Apr/21/2017
//  File Function: N76E003 UART-0 Mode1 demo code
#include "N76E003.h"
#include "Common.h"
#include "Delay.h"
#include "SFR_Macro.h"
#include "Function_define.h"
* FUNCTION_PURPOSE: Serial interrupt, echo received data.
* FUNCTION_INPUTS : P0.7(RXD) serial input
* FUNCTION_OUTPUTS: P0.6(TXD) serial output
* Following setting in Common.c
#if 0
//void InitialUART0_Timer1(UINT32 u32Baudrate)    //T1M = 1, SMOD = 1
//                P06_Quasi_Mode;
//                P07_Quasi_Mode;
//    SCON = 0x52;     //UART0 Mode1,REN=1,TI=1
//    TMOD |= 0x20;    //Timer1 Mode1
//    set_SMOD;        //UART0 Double Rate Enable
//    set_T1M;
//    clr_BRCK;        //Serial port 0 baud rate clock source = Timer1
//#ifdef FOSC_160000
//    TH1 = 256 - (1000000/u32Baudrate+1);               /*16 MHz */
//#endif
//    set_TR1;
//void InitialUART0_Timer3(UINT32 u32Baudrate) //use timer3 as Baudrate generator
//                P06_Quasi_Mode;
//                P07_Quasi_Mode;
//    T3CON &= 0xF8;   //T3PS2=0,T3PS1=0,T3PS0=0(Prescale=1)
//    set_BRCK;        //UART0 baud rate clock source = Timer3
//        RH3    = HIBYTE(65536 - (1000000/u32Baudrate)-1);                  /*16 MHz */
//  RL3    = LOBYTE(65536 - (1000000/u32Baudrate)-1);                        /*16 MHz */
//#endif
//    set_TR3;         //Trigger Timer3
#endif
* FUNCTION_PURPOSE: Main function
void main (void)
#if 0
    InitialUART0_Timer1(9600);           //UART0 Baudrate initial,T1M=0,SMOD=0
    while(1)
    Send_Data_To_UART0(0x55);
#else
                InitialUART0_Timer3(115200);
    while(1)
#endif
huangcunxiake| | 2018-1-24 18:42 | 只看该作者
字符串用printf函数
//  File Function: N76E003 ADC demo code
#include "Common.h"
#include "Delay.h"
//*****************  The Following is in define in Fucntion_define.h  ***************************
//****** Always include Function_define.h call the define you want, detail see main(void) *******
#if 0
//#define Enable_ADC_AIN0                        ADCCON0&=0xF0;P17_Input_Mode;AINDIDS=0x00;AINDIDS|=SET_BIT0;ADCCON1|=SET_BIT0        //P17
//#define Enable_ADC_AIN1                        ADCCON0&=0xF0;ADCCON0|=0x01;P30_Input_Mode;AINDIDS=0x00;AINDIDS|=SET_BIT1;ADCCON1|=SET_BIT0                //P30
//#define Enable_ADC_AIN2                        ADCCON0&=0xF0;ADCCON0|=0x02;P07_Input_Mode;AINDIDS=0x00;AINDIDS|=SET_BIT2;ADCCON1|=SET_BIT0                //P07
//#define Enable_ADC_AIN3                        ADCCON0&=0xF0;ADCCON0|=0x03;P06_Input_Mode;AINDIDS=0x00;AINDIDS|=SET_BIT3;ADCCON1|=SET_BIT0                //P06
//#define Enable_ADC_AIN4                        ADCCON0&=0xF0;ADCCON0|=0x04;P05_Input_Mode;AINDIDS=0x00;AINDIDS|=SET_BIT4;ADCCON1|=SET_BIT0                //P05
//#define Enable_ADC_AIN5                        ADCCON0&=0xF0;ADCCON0|=0x05;P04_Input_Mode;AINDIDS=0x00;AINDIDS|=SET_BIT5;ADCCON1|=SET_BIT0                //P04
//#define Enable_ADC_AIN6                        ADCCON0&=0xF0;ADCCON0|=0x06;P03_Input_Mode;AINDIDS=0x00;AINDIDS|=SET_BIT6;ADCCON1|=SET_BIT0                //P03
//#define Enable_ADC_AIN7                        ADCCON0&=0xF0;ADCCON0|=0x07;P11_Input_Mode;AINDIDS=0x00;AINDIDS|=SET_BIT7;ADCCON1|=SET_BIT0                //P11
//#define Enable_ADC_BandGap        ADCCON0|=SET_BIT3;ADCCON0&=0xF8;        //Band-gap 1.22V
//#define PWM0_FALLINGEDGE_TRIG_ADC                ADCCON0&=~SET_BIT5;ADCCON0&=~SET_BIT4;ADCCON1&=~SET_BIT3;ADCCON1&=~SET_BIT2;ADCCON1|=SET_BIT1
//#define PWM2_FALLINGEDGE_TRIG_ADC                ADCCON0&=~SET_BIT5;ADCCON0|=SET_BIT4;ADCCON1&=~SET_BIT3;ADCCON1&=~SET_BIT2;ADCCON1|=SET_BIT1
//#define PWM4_FALLINGEDGE_TRIG_ADC                ADCCON0|=SET_BIT5;ADCCON0&=~SET_BIT4;ADCCON1&=~SET_BIT3;ADCCON1&=~SET_BIT2;ADCCON1|=SET_BIT1
//#define PWM0_RISINGEDGE_TRIG_ADC                ADCCON0&=~SET_BIT5;ADCCON0&=~SET_BIT4;ADCCON1&=~SET_BIT3;ADCCON1|=SET_BIT2;ADCCON1|=SET_BIT1
//#define PWM2_RISINGEDGE_TRIG_ADC                ADCCON0&=~SET_BIT5;ADCCON0|=SET_BIT4;ADCCON1&=~SET_BIT3;ADCCON1|=SET_BIT2;ADCCON1|=SET_BIT1
//#define PWM4_RISINGEDGE_TRIG_ADC                ADCCON0|=SET_BIT5;ADCCON0&=~SET_BIT4;ADCCON1&=~SET_BIT3;ADCCON1|=SET_BIT2;ADCCON1|=SET_BIT1
//#define P04_FALLINGEDGE_TRIG_ADC                ADCCON0|=0x30;ADCCON1&=0xF3;ADCCON1|=SET_BIT1;ADCCON1&=~SET_BIT6
//#define P13_FALLINGEDGE_TRIG_ADC                ADCCON0|=0x30;ADCCON1&=0xF3;ADCCON1|=SET_BIT1;ADCCON1|=SET_BIT6
//#define P04_RISINGEDGE_TRIG_ADC                        ADCCON0|=0x30;ADCCON1&=~SET_BIT3;ADCCON1|=SET_BIT2;ADCCON1|=SET_BIT1;ADCCON1&=~SET_BIT6
//#define P13_RISINGEDGE_TRIG_ADC                        ADCCON0|=0x30;ADCCON1&=~SET_BIT3;ADCCON1|=SET_BIT2;ADCCON1|=SET_BIT1;ADCCON1|=SET_BIT6
#endif
The main C function.  Program execution starts
here after stack initialization.
void main (void)
                InitialUART0_Timer1(115200);
                Enable_ADC_AIN3;                                                // Enable AIN0 P1.7 as ADC input, Find in "Function_define.h" - "ADC INIT"
                while(1)
                        clr_ADCF;
                        set_ADCS;        // ADC start trig signal
      while(ADCF == 0);
                        printf ("\n Value = 0x%bx",ADCRH);
                        printf ("\n Value = 0x%bx",ADCRL);
                        Timer0_Delay1ms(100);
下载这个文件
N76E003_BSP_Keil_C51_V1.0.4
去官网下载。
lansefeiyang|  楼主 | 2018-1-25 14:03 | 只看该作者
我想知道发送字符串的
lansefeiyang|  楼主 | 2018-1-25 14:19 | 只看该作者
huangcunxiake 发表于 2018-1-24 18:42
下载这个文件
去官网下载。
我有,这里是字符的,和字符串应该不一样
heisexingqisi| | 2018-1-26 10:12 | 只看该作者
发送一个数字都行,你直接添加个string发送的函数调用这个发送数字的不就行了吗
heisexingqisi| | 2018-1-26 10:15 | 只看该作者
Send_String_to_UART0(string a)
while(*a!=''\0'')
Send_Data_To_UART0(a++);
差不多就是这么写的。
lansefeiyang|  楼主 | 2018-2-2 15:14 | 只看该作者
这个不是003的代码吧,003没看到有字符串类型。
我用电脑串口软件发送字符串可以控制模组,但是用003发送就失败,基本可以确定是字符串的问题。
gugogol| | 2018-3-5 15:07 | 只看该作者
**void Uart_SendString(u8 *data , u8 strlen)
**发送多个字符
**入口:u8 *data   ,  u8 strlen
**返回:无
void Uart_SendString(uint8_t *datas , uint8_t strlen)
  unsigned char datalen;
  for(datalen = 0 ; datalen < strlen ; datalen++)
    Send_Data_To_UART0(datas[datalen]);
void Send_Data_To_UART0 (UINT8 c)
    TI = 0;
    SBUF = c;
    while(TI==0);
gugogol| | 2018-3-5 15:11 | 只看该作者
如果要发送:datasheet,则Uart_SendString("datasheet" ,9);
