[STM8]
iarstm8 STM8L101F3访问EEPROM
3829|2
CC2530|  楼主 | 2011-6-19 12:45 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#include "stm8l10x.h"
#include "periph_io.h"
#include "delay.h"
extern __no_init volatile __eeprom  char  eep_u8;
extern __no_init volatile __eeprom  short eep_u16;
extern __no_init volatile __eeprom  long  eep_u32;
volatile  char   ram_u8;
volatile  short  ram_u16;
volatile  long   ram_u32;
void main( void )
  ram_u8=eep_u8;
  ram_u16=eep_u16;
  ram_u32=eep_u32;
  eep_u8=1;
  eep_u16=2;
  eep_u32=3;
  ram_u8=eep_u8;
  ram_u16=eep_u16;
  ram_u32=eep_u32;
  while(1);
#include "stm8l10x_conf.h"
void __eeprom_write_8(unsigned short addr_eep,unsigned char data)
  FLASH_WaitForLastOperation();
  FLASH_Unlock(FLASH_MemType_Data);
  FLASH_ProgramByte(addr_eep, data);
  FLASH_Lock(FLASH_MemType_Data);
void __eeprom_write_16(unsigned short addr_eep,unsigned short data)
  FLASH_ProgramByte(addr_eep,   data/256);
  FLASH_ProgramByte(addr_eep+1, data%256);
void __eeprom_write_32(unsigned short addr_eep,unsigned long data)
  FLASH_ProgramByte(addr_eep,   (unsigned char)(data>>24));
  FLASH_ProgramByte(addr_eep+1, (unsigned char)(data>>16));
  FLASH_ProgramByte(addr_eep+2,   (unsigned char)(data>>8));
  FLASH_ProgramByte(addr_eep+3, (unsigned char)(data>>0));
void __eeprom_write_many(unsigned short addr_eep,unsigned short size,unsigned short dummy,unsigned short addr_ram)
  for(unsigned short i=0;i<size;i++)
     FLASH_ProgramByte(addr_eep+i,   *((unsigned char *)(addr_ram)+i));
        public  eep_u8
        public  eep_u16
        public  eep_u32
        SECTION `.eeprom.text`:CONST:REORDER:ROOT(0)
eep_u8:
        DC8 0x12
eep_u16:
        DC16 0x3456
eep_u32:
        DC32 0x789ABCEE
        END
//      Example ILINK command file for
//      STM8 IAR C/C++ Compiler and Assembler.
//      Copyright 2010 IAR Systems AB.
//      $Revision$
define memory with size = 16M;
define region TinyData = [from 0x00 to 0xFF];
define region NearData = [from 0x0000 to 0x05FF];
define region NearFuncCode = [from 0x8000 to 0x9FFF];
define region FarFuncCode = [from 0x8000 to 0x9FFF];
define region HugeFuncCode = [from 0x8000 to 0x9FFF];
define region Eeprom = [from 0x9800 to 0x9FFF];
define block CSTACK with size = _CSTACK_SIZE  {};
define block HEAP  with size = _HEAP_SIZE {};
define block INTVEC with size = 0x80 { ro section .intvec };
// Initialization
initialize by copy { rw section .far.bss,
                     rw section .far.data,
                     rw section .far_func.textrw,
                     rw section .huge.bss,
                     rw section .huge.data,
                     rw section .huge_func.textrw,
                     rw section .iar.dynexit,
                     rw section .near.bss,
                     rw section .near.data,
                     rw section .near_func.textrw,
                     rw section .tiny.bss,
                     rw section .tiny.data,
                     ro section .tiny.rodata };
do not initialize  { rw section .far.noinit,
                     rw section .huge.noinit,
                     rw section .near.noinit,
                     rw section .tiny.noinit,
                     rw section .vregs };
// Placement
place at start of TinyData      { rw section .vregs };
place in TinyData               { rw section .tiny.bss,
                                  rw section .tiny.rodata };
place at end of NearData        { block CSTACK };
place in NearData               { block HEAP,
                                  rw section .near_func.textrw };
place at start of NearFuncCode  { block INTVEC };
place in NearFuncCode           { ro section .far.data_init,
                                  ro section .far_func.textrw_init,
           ro section .huge.data_init,
                                  ro section .huge_func.textrw_init,
  ro section .iar.init_table,
  ro section .init_array,
                                  ro section .near.data_init,
                                  ro section .near.rodata,
  ro section .near_func.text,
  ro section .near_func.textrw_init,
                                  ro section .tiny.data_init,
                                  ro section .tiny.rodata_init };
place in FarFuncCode            { ro section .far.rodata,
                                  ro section .far_func.text };
place in HugeFuncCode           { ro section .huge.rodata,
                                  ro section .huge_func.text };
place at end of Eeprom          { rw section .eeprom.noinit ,
                                  ro section .eeprom.text,
                                  ro section .eeprom.textrw_init };
stm8l101_demo.rar
480.08 KB
bili| | 2011-6-20 09:47 | 只看该作者
标记!好贴!
lwylwy1| | 2019-6-26 14:41 | 只看该作者
好贴,学习了;
