请教430_5438 ks0108_12864
1672|2
枯木雨生花|  楼主 | 2011-6-28 15:28 | 显示全部楼层 |阅读模式
求助各路高手请教用430驱动12864(OCM12864-3_ks0108)
#include"msp430x54x.h"
#define uint  unsigned  int
#define uchar unsigned char
//LED配置
#define   LED1       (1<<0)
#define   LED1_H     P1DIR|= LED1,P1OUT|= LED1
#define   LED1_L     P1DIR|= LED1,P1OUT&= ~LED1
//KS0108配置引脚
#define   KS0108_RET       (1<<6)
#define   KS0108_RET_H     P5DIR|= KS0108_RET,P5OUT|= KS0108_RET
#define   KS0108_RET_L     P5DIR|= KS0108_RET,P5OUT&= ~KS0108_RET
#define   KS0108_RW       (1<<4)
#define   KS0108_RW_H     P5DIR|= KS0108_RW,P5OUT|= KS0108_RW
#define   KS0108_RW_L     P5DIR|= KS0108_RW,P5OUT&= ~KS0108_RW
#define   KS0108_EN       (1<<5)
#define   KS0108_EN_H     P5DIR|= KS0108_EN,P5OUT|= KS0108_EN
#define   KS0108_EN_L     P5DIR|= KS0108_EN,P5OUT&= ~KS0108_EN
#define   KS0108_CS1       (1<<4)
#define   KS0108_CS1_H     P9DIR|= KS0108_CS1,P9OUT|= KS0108_CS1
#define   KS0108_CS1_L     P9DIR|= KS0108_CS1,P9OUT&= ~KS0108_CS1
#define   KS0108_CS2       (1<<5)
#define   KS0108_CS2_H     P9DIR|= KS0108_CS2,P9OUT|= KS0108_CS2
#define   KS0108_CS2_L     P9DIR|= KS0108_CS2,P9OUT&= ~KS0108_CS2
#define   KS0108_RS       (1<<6)
#define   KS0108_RS_H     P9DIR|= KS0108_RS,P9OUT|= KS0108_RS
#define   KS0108_RS_L     P9DIR|= KS0108_RS,P9OUT&= ~KS0108_RS
#define   KS0108_LCD       (1<<7)
#define   KS0108_LCD_H     P9DIR|= KS0108_LCD,P9OUT|= KS0108_LCD
#define   KS0108_LCD_L     P9DIR|= KS0108_LCD,P9OUT&= ~KS0108_LCD
//KS0108配置 ,指令宏定义
#define Display_On     0x3f //显示开指令
#define Display_Off    0x3e //显示关指令
#define Y_Col_Addr     0x40 //定位到第0列指令(列起始地址)(0-63)
#define X_Page_Addr    0xb8 //定位到第0页指令(页起始地址)(0-7)
#define Start_Line    0xc0 //定位从DDROM中的第0行开始往屏幕上显示
void Init_Clk(void);
void delay(int n);
void delay1 (uint ms);
//函数声明
void LCD_pos(unsigned char x, unsigned char y); //液晶定位(8*8)
void SetStartLine(unsigned char startline);
void init_ks0108(void);
void Lcd_clear(void) ;
void AllScreen(void) ;
void Write_command(unsigned char command) ;
void Write_data(unsigned char data) ;
void main()
  WDTCTL = WDTPW + WDTHOLD; //停止看门狗定时器
  //P11DIR |= BIT2 + BIT1 + BIT0; //P11:012设为输出模式
  //P11SEL |= BIT2 + BIT1 + BIT0; //设为第二功能作为频率输出
  Init_Clk(); //时钟初始化
  init_ks0108();
  while(1)
    LED1_H;
    //LCD_pos(5, 2);
    Write_command(0xb8);
    Write_command(0x40);
    Write_data(0xff);
    AllScreen();
    LED1_L;
    delay1(400);
//delay
void delay(int n)
    while(n--);
  uint i,j;
  for(i=0;i<ms;i++)
  for(j=0;j<1000;j++)
//时钟初始化
void Init_Clk(void)
  P7SEL |= 0x03;                       // Port select XT1
  UCSCTL6 &= ~(XT1OFF);                // Set XT1 On
  UCSCTL6 |= XCAP_3;                        // Internal load cap
  UCSCTL3 |= SELREF_0;                      // 选 FLL 时钟源
  UCSCTL4 = SELA_0 + SELM_4 +  + SELS_4;    //选时钟源:ACLK = XT1 = 32768Hz, MCLK = SMCLK = 8MHz
  UCSCTL5 = DIVPA_0 + DIVA_0 + DIVM_0 + DIVS_0;
  __bis_SR_register(SCG0);                  // Disable the FLL control loop
  UCSCTL0 = 0x0000;                         // Set lowest possible DCOx, MODx
  UCSCTL1 = DCORSEL_5;                      // Select DCO range 16MHz operation
  UCSCTL2 = FLLD_1 + 243;                   // Set DCO Multiplier for 8MHz
                                            // (N + 1) * FLLRef = Fdco
                                            // (243 + 1) * 32768 = 8MHz
                                            // Set FLL Div = fDCOCLK/2
  __bic_SR_register(SCG0);                  // Enable the FLL control loop
  // Loop until XT1,XT2 & DCO stabilizes
  do
    UCSCTL7 &= ~(XT2OFFG + XT1LFOFFG + XT1HFOFFG + DCOFFG);
                                            // Clear XT2,XT1,DCO fault flags
    SFRIFG1 &= ~OFIFG;                      // Clear fault flags
  while (SFRIFG1&OFIFG);                    // Test oscillator fault flag
//KS0108
//检查忙标志位
void chk_busy (void)
  unsigned char lcd_status;
  P10OUT = 0XFF;
  P10DIR= 0x00;//设为输入口
  KS0108_RS_L;
  KS0108_RW_H;
  do
    KS0108_EN_H;
    delay1(10);
    KS0108_EN_L;
    lcd_status = P10IN;
    //delay1(10);
    //KS0108_EN_L;
  while((lcd_status&0x80)!=0);
  P10DIR= 0xFF;
//写命令
  chk_busy ();
  KS0108_RS_L;
  KS0108_RW_L;
  P10DIR|= 0xFF,
  P10OUT = command;
  KS0108_EN_H;
  delay1(10);
  KS0108_EN_L;
//写数据
  chk_busy ();
  KS0108_RS_H;
  KS0108_RW_L;
  P10DIR|= 0xFF,
  P10OUT = data;
  KS0108_EN_H;
  delay1(10);
  KS0108_EN_L;
//设定行地址(页)--X 0-7
void SetLine(unsigned char line)
   line=(line&0x07);         // 0<=line<=7
   line=(line|0xb8);            //1011 1xxx
   Write_command(line);
//设定列地址--Y 0-63
void SetColumn(unsigned char column)
   column=(column&0x3f);   // 0=<column<=63
   column=(column|0x40);   //01xx xxxx
   Write_command(column);
//设定显示开始行--XX
void SetStartLine(unsigned char startline) //0--63
   startline=(startline&0x3f);              //??0x3f
   startline=(startline|0xc0);   //1100 0000
   Write_command(startline);
void SetOnOff(unsigned char onoff)
   onoff=(0x3e | onoff); //0011 111x
   Write_command(onoff);
//清屏
  unsigned char j,k;
  SetLine(0);
  SetColumn(0);
  for(k=0;k<8;k++)
    SetLine(k);       //第K页
    delay1(1);
    for(j=0;j<64;j++)
      Write_data(0x00);
      delay1(10);
//全屏显示
  unsigned char j,k;
  SetLine(0);
  SetColumn(0);
  for(k=0;k<8;k++)
    SetLine(k);       //第K页
    delay1(1);
    for(j=0;j<64;j++)
      Write_data(0xff);
      delay1(10);
  Write_command(0x3f);
//初始化
  KS0108_CS1_L;
  KS0108_CS2_L;
  KS0108_RET_L;
  delay(1000);
  KS0108_RET_H;
  Write_command(0x3e);
  delay1(1000);
    SetLine(0x00);    // 设定页
        delay1(100);
  SetStartLine(0x00);
        delay1(100);
  SetColumn(0x00);
        delay1(100);
  delay1(1000);
//液晶定位(8*8)
//液晶规划:
//x: 0 - 7 (行)
//y: 0 -15 (列)
if(y < 8)
         //左半屏
          KS0108_CS1_L;
          KS0108_CS2_H;
else
          y -= 8;
          KS0108_CS1_H;
          KS0108_CS2_L;
        } //右半屏
Write_command(X_Page_Addr + x); //页地址
Write_command(Y_Col_Addr + (y * 8));//列地址
Peter_zb| | 2011-6-28 18:26 | 显示全部楼层
你有什么问题呢。。
msp430ing| | 2011-6-28 22:19 | 显示全部楼层
楼主说说你的问题啊
