[技术问答]
N76E003的管脚中断问题
3814|5
302702801|  楼主 | 2018-2-2 10:20 | 显示全部楼层 |阅读模式
如题,请问应该在何时清除标志位,如果按键需要软件消抖应该怎么编写程序呢?
heisexingqisi| | 2018-2-2 19:37 | 显示全部楼层
按键如果只有一种状态,那就用松手检测做按键。
按下后就等待松手,用while。
mintspring| | 2018-2-3 16:26 | 显示全部楼层
#define clr_P00                        P00                =                0
#define clr_P01                        P01                =                0
#define clr_P02                        P02                =                0
/* Copyright(c) 2017 Nuvoton Technology Corp. All rights reserved.                                         */
//  Nuvoton Technoledge Corp.
//  Website: http://www.nuvoton.com
//  E-Mail : MicroC-8bit@nuvoton.com
//  Date   : Apr/21/2017
//  File Function: N76E003 I/O Interrupt demo code
#include "N76E003.h"
#include "SFR_Macro.h"
#include "Function_define.h"
#include "Common.h"
#include "Delay.h"
#if 0
//Following setting in Function_define.h
//   Enable INT port 0~3
//#define         Enable_INT_Port0                                        PICON &= 0xFB;
//#define                Enable_INT_Port1                                        PICON |= 0x01;
//#define                Enable_INT_Port2                                        PICON |= 0x02;
//#define                Enable_INT_Port3                                        PICON |= 0x03;
// Enable each bit low level trig mode
//#define                Enable_BIT7_LowLevel_Trig                        PICON&=0x7F;PINEN|=0x80;PIPEN&=0x7F
//#define                Enable_BIT6_LowLevel_Trig                        PICON&=0x7F;PINEN|=0x40;PIPEN&=0xBF
//#define                Enable_BIT5_LowLevel_Trig                        PICON&=0xBF;PINEN|=0x20;PIPEN&=0xDF
//#define                Enable_BIT4_LowLevel_Trig                        PICON&=0xBF;PINEN|=0x10;PIPEN&=0xEF
//#define                Enable_BIT3_LowLevel_Trig                        PICON&=0xDF;PINEN|=0x08;PIPEN&=0xF7
//#define                Enable_BIT2_LowLevel_Trig                        PICON&=0xEF;PINEN|=0x04;PIPEN&=0xFB
//#define                Enable_BIT1_LowLevel_Trig                        PICON&=0xF7;PINEN|=0x02;PIPEN&=0xFD
//#define                Enable_BIT0_LowLevel_Trig                        PICON&=0xFD;PINEN|=0x01;PIPEN&=0xFE
// Enable each bit high level trig mode
//#define                Enable_BIT7_HighLevel_Trig                        PICON&=0x7F;PINEN&=0x7F;PIPEN|=0x80
//#define                Enable_BIT6_HighLevel_Trig                        PICON&=0x7F;PINEN&=0xBF;PIPEN|=0x40
//#define                Enable_BIT5_HighLevel_Trig                        PICON&=0xBF;PINEN&=0xDF;PIPEN|=0x20
//#define                Enable_BIT4_HighLevel_Trig                        PICON&=0xBF;PINEN&=0xEF;PIPEN|=0x10
//#define                Enable_BIT3_HighLevel_Trig                        PICON&=0xDF;PINEN&=0xF7;PIPEN|=0x08
//#define                Enable_BIT2_HighLevel_Trig                        PICON&=0xEF;PINEN&=0xFB;PIPEN|=0x04
//#define                Enable_BIT1_HighLevel_Trig                        PICON&=0xF7;PINEN&=0xFD;PIPEN|=0x02
//#define                Enable_BIT0_HighLevel_Trig                        PICON&=0xFD;PINEN&=0xFE;PIPEN|=0x01
// Enable each bit falling edge trig mode
//#define                Enable_BIT7_FallEdge_Trig                        PICON|=0x80;PINEN|=0x80;PIPEN&=0x7F
//#define                Enable_BIT6_FallEdge_Trig                        PICON|=0x80;PINEN|=0x40;PIPEN&=0xBF
//#define                Enable_BIT5_FallEdge_Trig                        PICON|=0x40;PINEN|=0x20;PIPEN&=0xDF
//#define                Enable_BIT4_FallEdge_Trig                        PICON|=0x40;PINEN|=0x10;PIPEN&=0xEF
//#define                Enable_BIT3_FallEdge_Trig                        PICON|=0x20;PINEN|=0x08;PIPEN&=0xF7
//#define                Enable_BIT2_FallEdge_Trig                        PICON|=0x10;PINEN|=0x04;PIPEN&=0xFB
//#define                Enable_BIT1_FallEdge_Trig                        PICON|=0x08;PINEN|=0x02;PIPEN&=0xFD
//#define                Enable_BIT0_FallEdge_Trig                        PICON|=0x04;PINEN|=0x01;PIPEN&=0xFE
// Enable each bit rasing edge trig mode
//#define                Enable_BIT7_RasingEdge_Trig                        PICON|=0x80;PINEN&=0x7F;PIPEN|=0x80
//#define                Enable_BIT6_RasingEdge_Trig                        PICON|=0x80;PINEN&=0xBF;PIPEN|=0x40
//#define                Enable_BIT5_RasingEdge_Trig                        PICON|=0x40;PINEN&=0xDF;PIPEN|=0x20
//#define                Enable_BIT4_RasingEdge_Trig                        PICON|=0x40;PINEN&=0xEF;PIPEN|=0x10
//#define                Enable_BIT3_RasingEdge_Trig                        PICON|=0x20;PINEN&=0xF7;PIPEN|=0x08
//#define                Enable_BIT2_RasingEdge_Trig                        PICON|=0x10;PINEN&=0xFB;PIPEN|=0x04
//#define                Enable_BIT1_RasingEdge_Trig                        PICON|=0x08;PINEN|=0xFD;PIPEN&=0x02
//#define                Enable_BIT0_RasingEdge_Trig                        PICON|=0x04;PINEN|=0xFE;PIPEN&=0x01
#endif
* FUNCTION_PURPOSE: I/O Pin interrupt Service Routine
void EXT_INT0(void) interrupt 0
                                clr_GPIO1;
                        Timer0_Delay1ms(100);
                        set_GPIO1;
                        clr_GPIO1;
                        set_GPIO1;
                        clr_GPIO1;
                        set_GPIO1;
                        clr_GPIO1;
                        set_GPIO1;
                                clr_GPIO1;
                        set_GPIO1;
                        clr_GPIO1;
                        set_GPIO1;
                        clr_GPIO1;
                        set_GPIO1;
                        clr_GPIO1;
                        set_GPIO1;
void PinInterrupt_ISR (void) interrupt 7
        if(PIF == 0x01)
    PIF = 0x00;                             //clear interrupt flag
                        clr_GPIO1;
                        Timer1_Delay10ms(10);
                        set_GPIO1;
                        clr_GPIO1;
                        set_GPIO1;
        else if (PIF == 0x80)
                        clr_GPIO1;
                        set_GPIO1;
                        clr_GPIO1;
                        set_GPIO1;
                        clr_GPIO1;
                        set_GPIO1;
                        clr_GPIO1;
                        set_GPIO1;
The main C function.  Program execution starts
here after stack initialization.
void main (void)
    P07_Input_Mode;
                set_P0S_7;
                P00_Input_Mode;
                P01_Input_Mode;
                set_P0S_1;
                P12_PushPull_Mode;
                P30_PushPull_Mode;
                P05_PushPull_Mode;
//        P0.5 set as highlevel trig pin interrupt function
//  Keep P0.5 connect to VDD LED will tickle
//  otherwise, MCU into power down mode.
                Enable_INT_Port2;
//                Enable_BIT7_LowLevel_Trig;
                Enable_BIT0_LowLevel_Trig;
                P30 =1;
                P05 = 0;
    set_EPI;                                                        // Enable pin interrupt
                set_EX0;
    set_EA;        // global enable bit
    while(1)
                        P01=0;
                        P30=0;
                        P01=1;
                        P30=1;
xinpian101| | 2018-2-4 12:56 | 显示全部楼层
直接清零啊,按下后等待,如果还是原来检测到的那就继续确认。
