程序中的数组单片机只能识别前8个元素
263|5
huanghuac|  楼主 | 2018-2-8 19:30 | 显示全部楼层 |阅读模式
程序中的数组单片机只能识别前8个元素
huanghuac|  楼主 | 2018-2-8 19:32 | 显示全部楼层
code unsigned char   Data1=[12][32]
0x08,0x20,0x08,0x24,0xFF,0xFE,0x08,0x20,0x0A,0x20,0x02,0x10,0x3F,0xF8,0x02,0x10,
0x02,0x10,0x22,0x18,0x24,0x16,0x44,0x12,0x08,0x10,0x10,0x10,0x20,0x50,0x40,0x20,//su
0x10,0x04,0x10,0x84,0x10,0x84,0x10,0x84,0x54,0xA4,0x52,0x94,0x52,0x94,0x90,0x84,
0x10,0x84,0x10,0x84,0x10,0x84,0x10,0x84,0x20,0x84,0x20,0x84,0x40,0x04,0x00,0x04,//zhou
0x02,0x00,0x42,0x08,0x33,0xFC,0x14,0x00,0x8B,0xF8,0x62,0x88,0x22,0x48,0x0A,0x08,
0x1F,0xFE,0x24,0x88,0xE4,0x48,0x24,0x08,0x27,0xFC,0x20,0x08,0x20,0x28,0x20,0x10,//hai
0x20,0x50,0x20,0x48,0x2F,0xFE,0x20,0x40,0x27,0xFC,0xFC,0x44,0x27,0xFC,0x24,0x44,
0x27,0xFC,0x24,0x44,0x20,0x10,0x2F,0xFE,0x22,0x10,0x21,0x10,0x20,0x50,0x20,0x20,//bo
0x20,0x00,0x22,0x04,0x3F,0x7E,0x48,0x44,0x08,0x44,0xFF,0xC4,0x10,0x44,0x14,0x7C,
0x22,0x44,0x42,0x10,0x9F,0xF8,0x10,0x10,0x1F,0xF0,0x10,0x10,0x1F,0xF0,0x10,0x10,//zhi
0x10,0x80,0x10,0x88,0x24,0x98,0x44,0xA0,0xFE,0xC0,0x02,0x84,0x7C,0x84,0x44,0x7C,
0x7C,0x00,0x44,0x88,0x44,0x98,0x7C,0xA0,0x44,0xC0,0x44,0x82,0x54,0x82,0x48,0x7E //neng
编译都没有错误,但是以显示到Data1=[9][32]就开始乱码了,程序确保没有问题,用的是STC89C52RC单片机,一直找不到原因...
bqyj| | 2018-2-8 19:36 | 显示全部楼层
8*32 正好是 256.
看来和编译后生成的代码有关.
wenfen| | 2018-2-8 19:39 | 显示全部楼层
MOVC A,@A+DPTR, 如果以 A 为偏移, 只能寻址 256字节.
huanghuac|  楼主 | 2018-2-8 19:43 | 显示全部楼层
好像是这样的
ayb_ice| | 2018-2-9 10:32 | 显示全部楼层
C不存在这个问题,应该是索引变量是u8型导致的,改为u16即可
