[PIC®/AVR®/dsPIC®产品]
目标器件未准备好调试。请在继续进行之前检查你的配置位设置然后编程器件
3340|7
atchboy|  楼主 | 2018-2-11 14:23 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
目标器件未准备好调试。请在继续进行之前检查你的配置位设置然后编程器件。配置位应该没有问题啊。
#pragma config FOSC = INTOSC    // Oscillator Selection (INTOSC oscillator: I/O function on CLKIN pin)
#pragma config WDTE = OFF       // Watchdog Timer Enable (WDT disabled)
#pragma config PWRTE = OFF      // Power-up Timer Enable (PWRT disabled)
#pragma config MCLRE = ON       // MCLR Pin Function Select (MCLR/VPP pin function is MCLR)
#pragma config CP = OFF         // Flash Program Memory Code Protection (Program memory code protection is disabled)
#pragma config CPD = OFF        // Data Memory Code Protection (Data memory code protection is disabled)
#pragma config BOREN = OFF      // Brown-out Reset Enable (Brown-out Reset disabled)
#pragma config CLKOUTEN = OFF   // Clock Out Enable (CLKOUT function is disabled. I/O or oscillator function on the CLKOUT pin)
#pragma config IESO = OFF       // Internal/External Switchover (Internal/External Switchover mode is disabled)
#pragma config FCMEN = OFF       // Fail-Safe Clock Monitor Enable (Fail-Safe Clock Monitor is enabled)
// CONFIG2
#pragma config WRT = OFF        // Flash Memory Self-Write Protection (Write protection off)
#pragma config PLLEN = OFF      // PLL Enable (4x PLL disabled)
#pragma config STVREN = ON      // Stack Overflow/Underflow Reset Enable (Stack Overflow or Underflow will cause a Reset)
#pragma config BORV = LO        // Brown-out Reset Voltage Selection (Brown-out Reset Voltage (Vbor), low trip point selected.)
#pragma config LVP = OFF        // Low-Voltage Programming Enable (High-voltage on MCLR/VPP must be used for programming)
cawyai23| | 2019-7-23 10:24 | 只看该作者
楼主,你怎么解决这个问题的?我也遇到了
ThinkIC| | 2019-7-27 16:45 | 只看该作者
我也遇到了,不能DEBUG!
cdyyabc| | 2019-7-29 14:10 | 只看该作者
什么型号?什么IDE?硬件如何连接的?
锵才才| | 2019-7-29 14:59 | 只看该作者
检查一下芯片是不是一定需要专门的仿真头
wanduzi| | 2019-7-31 23:12 | 只看该作者
没法编译吗
wanduzi| | 2019-7-31 23:13 | 只看该作者
能烧录运行不,还是只不能调试?难道调试需要一个特殊位?
pascal116| | 2020-10-11 17:38 | 只看该作者
请问这个怎么解决的,我从3.26版本升级到5.35就不能在线调试了
