ST MCU Finder
安装免费手机应用,
寻找理想的ST MCU
[STM32F1] stm32驱动带字库液晶屏问题
2006|11
 楼主 | 2018-2-13 12:59 | 显示全部楼层 |阅读模式
最近无聊想学一下stm单片机,手头有个开发板和带字库的12864液晶屏,液晶屏有个c51的参考驱动,想改成stm32的,编译后使用字库时显示不正确,用usb逻辑分/////析仪、、、测试,Rom_SCK, Rom_IN没输出。
请教下是哪里的问题?我感觉应该是gpio配置有问题。以下是我觉得可能有问题的代码:
#define RS_H   GPIOA->BSRR=GPIO_Pin_2
#define RS_L   GPIOA->BRR=GPIO_Pin_2
#define CS_H  GPIOA->BSRR=GPIO_Pin_4
#define CS_L  GPIOA->BRR=GPIO_Pin_4
#define SCLK_H  GPIOA->BSRR=GPIO_Pin_0
#define SCLK_L  GPIOA->BRR=GPIO_Pin_0
#define SID_H   GPIOA->BSRR=GPIO_Pin_1
#define SID_L   GPIOA->BRR=GPIO_Pin_1
#define REST_H   GPIOA->BSRR=GPIO_Pin_3
#define REST_L   GPIOA->BRR=GPIO_Pin_3
#define Rom_IN_H   GPIOA->BSRR=GPIO_Pin_5
#define Rom_IN_L   GPIOA->BRR=GPIO_Pin_5
#define Rom_OUT  GPIO_ReadInputDataBit(GPIOA, GPIO_Pin_6)
#define Rom_SCK_H  GPIOA->BSRR=GPIO_Pin_7
#define Rom_SCK_L  GPIOA->BRR=GPIO_Pin_7
#define Rom_CS_H   GPIOB->BSRR=GPIO_Pin_0
#define Rom_CS_L   GPIOB->BRR=GPIO_Pin_0
//gpio配置
  void GPIO_Config(void)
// SPI_InitTypeDef  SPI_InitStructure;
    RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA, ENABLE);
    RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB, ENABLE);
/*PC4-A0*/
// GPIO_SetBits(GPIOC, GPIO_Pin_12);//预置为高
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3|GPIO_Pin_4|GPIO_Pin_5|GPIO_Pin_7;
    GPIO_InitStructure.GPIO_Speed = GPIO_Speed_10MHz;
    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
    GPIO_Init(GPIOA, &GPIO_InitStructure);
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0;
    GPIO_Init(GPIOB, &GPIO_InitStructure);
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6;
    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
//从晶联讯字库 IC 中取汉字或字符数据(1 个字节)
static uchar get_data_from_ROM( )
uchar i;
uchar ret_data=0;
for(i=0;i<8;i++)
//Rom_OUT=1;
GPIO_SetBits(GPIOA,GPIO_Pin_6);
Rom_SCK_L;
//delay_us(1);
ret_data=ret_data<<1;
if( GPIOA->IDR&GPIO_Pin_6<<6 )
ret_data=ret_data+1;
else
ret_data=ret_data+0;
Rom_SCK_H;
//delay_us(1);
return(ret_data);
您需要 登录 才可以下载或查看,没有帐号?注册
x
 楼主 | 2018-2-13 21:35 | 显示全部楼层
忘了上传液晶屏资料了。。
x
| 2018-2-13 22:00 | 显示全部楼层
读数据时未将GPIOA-GPIO_Pin_6配置成输入状态。
 楼主 | 2018-2-13 22:17 | 显示全部楼层
具体要怎么改?c语言也是刚开始学,还不大熟。
| 2018-2-14 10:07 | 显示全部楼层
读数据时应该配置成输入模式:
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;
读完再设置回输出模式
楼主直接用PDF说明书里的代码移植到STM32就OK了。
| 2018-2-14 15:50 | 显示全部楼层
这个是有特定接口还是时序操作
 楼主 | 2018-2-14 22:56 | 显示全部楼层
sky.sun.zz 发表于 2018-2-14 10:07
读数据时应该配置成输入模式:
GPIO_InitStructure.GPIO_Pin = GPI ...
试过了,还是不行,字库的几个引脚信号全部不正常
 楼主 | 2018-2-17 13:04 | 显示全部楼层
奇怪了,是不是程序跑飞了,字库ic输入一直有信号输入,用软件仿真程序也没循环执行啊
x
| 2018-2-22 17:46 | 显示全部楼层
似乎显示屏后面有个选择工作模式的电阻
| 2018-2-23 14:01 | 显示全部楼层
| 2018-2-23 16:16 | 显示全部楼层
为了防止被山寨,我准备学几个淘汰的单片机开发产品
 楼主 | 2018-2-23 20:00 | 显示全部楼层
改了下gpio配置就正常了,有个问题是rom_out我同时配置为推挽输出和浮空输入,为什么不会出错?
  /*PC4-A0*/
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3|GPIO_Pin_4|GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7|GPIO_Pin_8;
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_5;
    //GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;
    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_OD;
扫描二维码,随时随地手机跟帖
快速回复
您需要登录后才可以回帖
登录 | 注册
高级模式
我要创建版块 申请成为版主
论坛热帖
快速回复 返回顶部 返回列表
