[DemoCode下载]
M0518读写闪存操作方式
2390|15
小明的同学|  楼主 | 2018-2-25 13:56 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
* [url=home.php?mod=space&uid=288409]@file[/url]     main.c
* [url=home.php?mod=space&uid=895143]@version[/url]  V3.00
* $Revision: 2 $
* $Date: 14/12/25 10:24a $
* [url=home.php?mod=space&uid=247401]@brief[/url]    Show how to read/program embedded flash by ISP function.
* @note
* Copyright (C) 2014 Nuvoton Technology Corp. All rights reserved.
#include <stdio.h>
#include "M0518.h"
#define PLLCON_SETTING      CLK_PLLCON_50MHz_HXT
#define PLL_CLOCK           50000000
#define APROM_TEST_BASE             0x3000
#define APROM_TEST_END              0xF000
#define DATA_FLASH_TEST_BASE        0xF000
#define DATA_FLASH_TEST_END         0x11000
#define TEST_PATTERN                0x5A5A5A5A
#define CONFIG0_DFEN                0x01
#define CONFIG0_DFVSEN              0x04
void SYS_Init(void)
    /* Init System Clock        */
    /* Enable Internal RC 22.1184MHz clock */
    CLK_EnableXtalRC(CLK_PWRCON_OSC22M_EN_Msk);
    /* Waiting for Internal RC clock ready */
    CLK_WaitClockReady(CLK_CLKSTATUS_OSC22M_STB_Msk);
    /* Switch HCLK clock source to Internal RC and HCLK source divide 1 */
    CLK_SetHCLK(CLK_CLKSEL0_HCLK_S_HIRC, CLK_CLKDIV_HCLK(1));
    /* Enable external XTAL 12MHz clock */
    CLK_EnableXtalRC(CLK_PWRCON_XTL12M_EN_Msk);
    /* Waiting for external XTAL clock ready */
    CLK_WaitClockReady(CLK_CLKSTATUS_XTL12M_STB_Msk);
    /* Set core clock as PLL_CLOCK from PLL */
    CLK_SetCoreClock(PLL_CLOCK);
    /* Enable UART module clock */
    CLK_EnableModuleClock(UART0_MODULE);
    /* Select UART module clock source */
    CLK_SetModuleClock(UART0_MODULE, CLK_CLKSEL1_UART_S_HXT, CLK_CLKDIV_UART(1));
    /* Init I/O Multi-function        */
    /* Set GPB multi-function pins for UART0 RXD and TXD */
    SYS->GPB_MFP = SYS_GPB_MFP_PB0_UART0_RXD | SYS_GPB_MFP_PB1_UART0_TXD;
void UART_Init()
    /* Init UART        */
    UART_Open(UART0, 115200);
static int  SetDataFlashBase(uint32_t u32DFBA)
    uint32_t au32Config[2];
    /* Read current User Configuration */
    FMC_ReadConfig(au32Config, 1);
    /* Just return when Data Flash has been enabled */
    if(!(au32Config[0] & 0x1))
        return 0;
    /* Enable User Configuration Update */
    FMC_EnableConfigUpdate();
    /* Erase User Configuration */
    FMC_Erase(FMC_CONFIG_BASE);
    /* Write User Configuration to Enable Data Flash */
    /* Note: DFVSEN = 1, DATA Flash Size is 4K bytes
             DFVSEN = 0, DATA Flash Size is based on CONFIG1 */
    au32Config[0] &= ~(CONFIG0_DFEN | CONFIG0_DFVSEN);
    au32Config[1] = u32DFBA;
    if(FMC_WriteConfig(au32Config, 2))
        return -1;
    printf("\nSet Data Flash base as 0x%x.\n", FMC_ReadDataFlashBaseAddr());
    /* Perform chip reset to make new User Config take effect */
    SYS->IPRSTC1 |= SYS_IPRSTC1_CHIP_RST_Msk;
    return 0;
int32_t FillDataPattern(uint32_t u32StartAddr, uint32_t u32EndAddr, uint32_t u32Pattern)
    uint32_t u32Addr;
    for(u32Addr = u32StartAddr; u32Addr < u32EndAddr; u32Addr += 4)
        FMC_Write(u32Addr, u32Pattern);
    return 0;
int32_t  VerifyData(uint32_t u32StartAddr, uint32_t u32EndAddr, uint32_t u32Pattern)
    uint32_t    u32Addr;
    uint32_t    u32Data;
        u32Data = FMC_Read(u32Addr);
        if(u32Data != u32Pattern)
            printf("\nFMC_Read data verify failed at address 0x%x, read=0x%x, expect=0x%x\n", u32Addr, u32Data, u32Pattern);
            return -1;
    return 0;
int32_t  FlashTest(uint32_t u32StartAddr, uint32_t u32EndAddr, uint32_t u32Pattern)
    uint32_t    u32Addr;
    for(u32Addr = u32StartAddr; u32Addr < u32EndAddr; u32Addr += FMC_FLASH_PAGE_SIZE)
        printf("    Flash test address: 0x%x    \r", u32Addr);
        // Erase page
        FMC_Erase(u32Addr);
        // Verify if page contents are all 0xFFFFFFFF
        if(VerifyData(u32Addr, u32Addr + FMC_FLASH_PAGE_SIZE, 0xFFFFFFFF) < 0)
            printf("\nPage 0x%x erase verify failed!\n", u32Addr);
            return -1;
        // Write test pattern to fill the whole page
        if(FillDataPattern(u32Addr, u32Addr + FMC_FLASH_PAGE_SIZE, u32Pattern) < 0)
            printf("Failed to write page 0x%x!\n", u32Addr);
            return -1;
        // Verify if page contents are all equal to test pattern
        if(VerifyData(u32Addr, u32Addr + FMC_FLASH_PAGE_SIZE, u32Pattern) < 0)
            printf("\nData verify failed!\n ");
            return -1;
        FMC_Erase(u32Addr);
            return -1;
    printf("\r    Flash Test Passed.          \n");
    return 0;
int main()
    uint32_t i, u32Data;
    /* Unlock protected registers */
    SYS_UnlockReg();
    SYS_Init();
    UART_Init();
        This sample code is used to show how to use StdDriver API to implement ISP functions.
    printf("\n\n");
    printf("+----------------------------------------+\n");
    printf("|          M0518 FMC Sample Code        |\n");
    //SYS_UnlockReg();
    /* Enable FMC ISP function */
    FMC_Open();
    if(SetDataFlashBase(DATA_FLASH_TEST_BASE) < 0)
        printf("Failed to set Data Flash base address!\n");
        goto lexit;
    /* Read BS */
    printf("  Boot Mode ............................. ");
    if(FMC_GetBootSource() == 0)
        printf("[APROM]\n");
    else
        printf("[LDROM]\n");
        printf("  WARNING: The driver sample code must execute in AP mode!\n");
        goto lexit;
    u32Data = FMC_ReadCID();
    printf("  Company ID ............................ [0x%08x]\n", u32Data);
    u32Data = FMC_ReadDID();
    printf("  Device ID ............................. [0x%08x]\n", u32Data);
    u32Data = FMC_ReadPID();
    printf("  Product ID ............................ [0x%08x]\n", u32Data);
    for(i = 0; i < 3; i++)
        u32Data = FMC_ReadUID(i);
        printf("  Unique ID %d ........................... [0x%08x]\n", i, u32Data);
    for(i = 0; i < 4; i++)
        u32Data = FMC_ReadUCID(i);
        printf("  Unique Customer ID %d .................. [0x%08x]\n", i, u32Data);
    /* Read User Configuration */
    printf("  User Config 0 ......................... [0x%08x]\n", FMC_Read(FMC_CONFIG_BASE));
    printf("  User Config 1 ......................... [0x%08x]\n", FMC_Read(FMC_CONFIG_BASE + 4));
    /* Read Data Flash base address */
    u32Data = FMC_ReadDataFlashBaseAddr();
    printf("  Data Flash Base Address ............... [0x%08x]\n", u32Data);
    printf("\n\nLDROM test =>\n");
    FMC_EnableLDUpdate();
    if(FlashTest(FMC_LDROM_BASE, FMC_LDROM_BASE + FMC_LDROM_SIZE, TEST_PATTERN) < 0)
        printf("\n\nLDROM test failed!\n");
        goto lexit;
    FMC_DisableLDUpdate();
    printf("\n\nAPROM test =>\n");
    FMC_EnableAPUpdate();
    if(FlashTest(APROM_TEST_BASE, APROM_TEST_END, TEST_PATTERN) < 0)
        printf("\n\nAPROM test failed!\n");
        goto lexit;
    FMC_DisableAPUpdate();
    printf("\n\nData Flash test =>\n");
    if(FlashTest(DATA_FLASH_TEST_BASE, DATA_FLASH_TEST_END, TEST_PATTERN) < 0)
        printf("\n\nUHB test failed!\n");
        goto lexit;
lexit:
    /* Disable FMC ISP function */
    FMC_Close();
    /* Lock protected registers */
    SYS_LockReg();
    printf("\nFMC Sample Code Completed.\n");
    while(1);
/*** (C) COPYRIGHT 2014 Nuvoton Technology Corp. ***/
小明的同学|  楼主 | 2018-2-25 14:12 | 只看该作者
用这个方法,可以利用上用不完的flash
huahuagg| | 2018-2-25 15:17 | 只看该作者
省了一个EEPROM芯片。
xuanhuanzi| | 2018-2-25 19:57 | 只看该作者
看着不简单啊
21mengnan| | 2018-2-25 22:50 | 只看该作者
地址标记,地址读写
xinxianshi| | 2018-2-26 13:33 | 只看该作者
FMC是什么
yiy| | 2018-2-26 19:18 | 只看该作者
读写闪存看来是需要解除保护的。
xixi2017| | 2018-2-26 20:24 | 只看该作者
出错的时候返回负一
dongnanxibei| | 2018-2-26 21:03 | 只看该作者
每个新唐的好像都是可以的
稳稳の幸福| | 2018-2-26 21:45 | 只看该作者
也可以做IAP应用。
734774645| | 2018-2-26 21:51 | 只看该作者
如果使能外部晶振后,外部没有晶振会有什么
会停机吗
734774645| | 2018-2-27 08:30 | 只看该作者
用开发板试了一下,非常好用,一次成功。
yiyigirl2014| | 2018-2-27 13:20 | 只看该作者
比ST的库函数好懂。
643757107| | 2018-2-27 18:22 | 只看该作者
比操作外部EEPROM复杂点啊。
jiekou001| | 2018-2-27 19:08 | 只看该作者
默认的串口使用最简单了,闪存的读写操作要会指针。
