[DemoCode下载]
M051的I2C唤醒演示
1844|11
643757107|  楼主 | 2018-2-27 18:34 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
* [url=home.php?mod=space&uid=288409]@file[/url]     main.c
* [url=home.php?mod=space&uid=895143]@version[/url]  V3.00
* $Revision: 5 $
* $Date: 15/05/22 2:41p $
* [url=home.php?mod=space&uid=247401]@brief[/url]    M051 Series I2C Driver Sample Code for Wake-up (Master)
* @note
* Copyright (C) 2014 Nuvoton Technology Corp. All rights reserved.
#include <stdio.h>
#include "M051Series.h"
#define PLLCON_SETTING      SYSCLK_PLLCON_50MHz_XTAL
#define PLL_CLOCK           50000000
/* Global variables        */
volatile uint8_t g_u8DeviceAddr;
volatile uint8_t g_au8MstTxData[3];
volatile uint8_t g_u8MstRxData;
volatile uint8_t g_u8MstDataLen;
volatile uint8_t g_u8MstEndFlag = 0;
typedef void (*I2C_FUNC)(uint32_t u32Status);
static volatile I2C_FUNC s_I2C0HandlerFn = NULL;
/*  I2C0 IRQ Handler        */
void I2C0_IRQHandler(void)
    uint32_t u32Status;
    u32Status = I2C_GET_STATUS(I2C0);
    if(I2C_GET_TIMEOUT_FLAG(I2C0))
        /* Clear I2C0 Timeout Flag */
        I2C_ClearTimeoutFlag(I2C0);
    else
        if(s_I2C0HandlerFn != NULL)
            s_I2C0HandlerFn(u32Status);
/*  I2C Master Tx Wake Up Callback Function        */
void I2C_MasterTxWakeup(uint32_t u32Status)
    if(u32Status == 0x08)                       /* START has been transmitted */
        I2C_SET_DATA(I2C0, (g_u8DeviceAddr << 1));    /* Write SLA+W to Register I2CDAT */
        I2C_SET_CONTROL_REG(I2C0, I2C_I2CON_SI);
    else if(u32Status == 0x18)                  /* SLA+W has been transmitted and ACK has been received */
        I2C_SET_CONTROL_REG(I2C0, I2C_I2CON_STO_SI);
        g_u8MstEndFlag = 1;
    else if(u32Status == 0x20)                  /* SLA+W has been transmitted and NOT ACK has been received */
        I2C_STOP(I2C0);
        g_u8MstEndFlag = 1;
    else
        /* TO DO */
        printf("Status 0x%x is NOT processed\n", u32Status);
/*  I2C Rx Callback Function        */
void I2C_MasterRx(uint32_t u32Status)
    if(u32Status == 0x08)                       /* START has been transmitted and prepare SLA+W */
        I2C_SET_DATA(I2C0, g_au8MstTxData[g_u8MstDataLen++]);
    else if(u32Status == 0x20)                  /* SLA+W has been transmitted and NACK has been received */
        I2C_STOP(I2C0);
        I2C_START(I2C0);
    else if(u32Status == 0x28)                  /* DATA has been transmitted and ACK has been received */
        if(g_u8MstDataLen != 2)
        else
            I2C_SET_CONTROL_REG(I2C0, I2C_I2CON_STA_SI);
    else if(u32Status == 0x10)                  /* Repeat START has been transmitted and prepare SLA+R */
        I2C_SET_DATA(I2C0, ((g_u8DeviceAddr << 1) | 0x01)); /* Write SLA+R to Register I2CDAT */
    else if(u32Status == 0x40)                  /* SLA+R has been transmitted and ACK has been received */
    else if(u32Status == 0x58)                  /* DATA has been received and NACK has been returned */
        g_u8MstRxData = (unsigned char) I2C_GET_DATA(I2C0);
        g_u8MstEndFlag = 1;
    else
        /* TO DO */
/*  I2C Tx Callback Function        */
void I2C_MasterTx(uint32_t u32Status)
        I2C_SET_DATA(I2C0, g_u8DeviceAddr << 1);    /* Write SLA+W to Register I2CDAT */
        I2C_STOP(I2C0);
        I2C_START(I2C0);
        if(g_u8MstDataLen != 3)
        else
            g_u8MstEndFlag = 1;
    else
        /* TO DO */
void SYS_Init(void)
    /* Init System Clock        */
    /* Enable Internal RC 22.1184MHz clock */
    CLK_EnableXtalRC(CLK_PWRCON_OSC22M_EN_Msk);
    /* Waiting for Internal RC clock ready */
    CLK_WaitClockReady(CLK_CLKSTATUS_OSC22M_STB_Msk);
    /* Switch HCLK clock source to Internal RC and HCLK source divide 1 */
    CLK_SetHCLK(CLK_CLKSEL0_HCLK_S_HIRC, CLK_CLKDIV_HCLK(1));
    /* Enable external XTAL 12MHz clock */
    CLK_EnableXtalRC(CLK_PWRCON_XTL12M_EN_Msk);
    /* Waiting for external XTAL clock ready */
    CLK_WaitClockReady(CLK_CLKSTATUS_XTL12M_STB_Msk);
    /* Set core clock as PLL_CLOCK from PLL */
    CLK_SetCoreClock(PLL_CLOCK);
    /* Enable UART & I2C0 module clock */
    CLK_EnableModuleClock(UART0_MODULE);
    CLK_EnableModuleClock(I2C0_MODULE);
    /* Select UART module clock source */
    CLK_SetModuleClock(UART0_MODULE, CLK_CLKSEL1_UART_S_HXT, CLK_CLKDIV_UART(1));
    /* Init I/O Multi-function        */
    /* Set P3 multi-function pins for UART0 RXD and TXD */
    SYS->P3_MFP &= ~(SYS_MFP_P30_Msk | SYS_MFP_P31_Msk);
    SYS->P3_MFP |= SYS_MFP_P30_RXD0 | SYS_MFP_P31_TXD0;
    /* Configure the SDA0 & SCL0 of I2C0 pins */
    SYS->P3_MFP &= ~(SYS_MFP_P34_Msk | SYS_MFP_P35_Msk);
    SYS->P3_MFP |= SYS_MFP_P34_SDA0 | SYS_MFP_P35_SCL0;
void UART0_Init()
    /* Init UART        */
    /* Reset IP */
    SYS_ResetModule(UART0_RST);
    /* Configure UART0 and set UART0 Baudrate */
    UART_Open(UART0, 115200);
void I2C0_Init(void)
    /* Open I2C module and set bus clock */
    I2C_Open(I2C0, 100000);
    /* Get I2C0 Bus Clock */
    printf("I2C clock %d Hz\n", I2C_GetBusClockFreq(I2C0));
    /* Set I2C 4 Slave Addresses */
    I2C_SetSlaveAddr(I2C0, 0, 0x15, 0);   /* Slave Address : 0x15 */
    I2C_SetSlaveAddr(I2C0, 1, 0x35, 0);   /* Slave Address : 0x35 */
    I2C_SetSlaveAddr(I2C0, 2, 0x55, 0);   /* Slave Address : 0x55 */
    I2C_SetSlaveAddr(I2C0, 3, 0x75, 0);   /* Slave Address : 0x75 */
    /* Enable I2C interrupt */
    I2C_EnableInt(I2C0);
    NVIC_EnableIRQ(I2C0_IRQn);
void I2C0_Close(void)
    /* Disable I2C0 interrupt and clear corresponding NVIC bit */
    I2C_DisableInt(I2C0);
    NVIC_DisableIRQ(I2C0_IRQn);
    /* Disable I2C0 and close I2C0 clock */
    I2C_Close(I2C0);
    CLK_DisableModuleClock(I2C0_MODULE);
int32_t I2C0_Read_Write_SLAVE(uint8_t slvaddr)
    uint32_t i;
    g_u8DeviceAddr = slvaddr;
    for(i = 0; i < 0x100; i++)
        g_au8MstTxData[0] = (uint8_t)((i & 0xFF00) >> 8);
        g_au8MstTxData[1] = (uint8_t)(i & 0x00FF);
        g_au8MstTxData[2] = (uint8_t)(g_au8MstTxData[1] + 3);
        g_u8MstDataLen = 0;
        g_u8MstEndFlag = 0;
        /* I2C function to write data to slave */
        s_I2C0HandlerFn = (I2C_FUNC)I2C_MasterTx;
        /* I2C as master sends START signal */
        I2C_SET_CONTROL_REG(I2C0, I2C_I2CON_STA);
        /* Wait I2C Tx Finish */
        while(g_u8MstEndFlag == 0);
        g_u8MstEndFlag = 0;
        /* I2C function to read data from slave */
        s_I2C0HandlerFn = (I2C_FUNC)I2C_MasterRx;
        g_u8MstDataLen = 0;
        /* Wait I2C Rx Finish */
        /* Compare data */
        if(g_u8MstRxData != g_au8MstTxData[2])
            printf("I2C Byte Write/Read Failed, Data 0x%x\n", g_u8MstRxData);
            return -1;
    printf("Master Access Slave (0x%X) Test OK\n", slvaddr);
    return 0;
/*  Main Function        */
int32_t main(void)
    /* Unlock protected registers */
    SYS_UnlockReg();
    /* Init System, IP clock and multi-function I/O */
    SYS_Init();
    /* Init UART0 for printf */
    UART0_Init();
    /* Lock protected registers */
    SYS_LockReg();
        This sample code sets I2C bus clock to 100kHz. After wake-up, then accesses Slave with Byte
        Write and Byte Read operations, and check if the read data is equal to the programmed data.
    printf("+-----------------------------------------------------------------------+\n");
    printf("| M05xx I2C Driver Sample Code (Master) for wake-up & access Slave test |\n");
    printf("|        |\n");
    printf("| I2C Master (I2C0) <---> I2C Slave(I2C0)                               |\n");
    printf("Configure I2C0 as a master.\n");
    printf("The I/O connection for I2C0:\n");
    printf("I2C0_SDA(P3.4), I2C0_SCL(P3.5)\n");
    /* Init I2C0 to access Slave */
    I2C0_Init();
    printf("\n");
    printf("Check I2C slave at power down status.\n");
    printf("Press any key to Wake up slave.\n");
    getchar();
    /* Set the Slave address to wake-up*/
    g_u8DeviceAddr = 0x15;
    /* I2C function to wake-up slave*/
    s_I2C0HandlerFn = (I2C_FUNC)I2C_MasterTxWakeup;
    /* Send a START condition to bus */
    /*Access to the corresponding address Slave*/
    printf("\n");
    printf(" == No Mask Address ==\n");
    I2C0_Read_Write_SLAVE(0x15);
    I2C0_Read_Write_SLAVE(0x35);
    I2C0_Read_Write_SLAVE(0x55);
    I2C0_Read_Write_SLAVE(0x75);
    printf("SLAVE Address test OK.\n");
    /* Access Slave with address mask */
    printf("\n");
    printf(" == Mask Address ==\n");
    I2C0_Read_Write_SLAVE(0x15 & ~0x01);
    I2C0_Read_Write_SLAVE(0x35 & ~0x04);
    I2C0_Read_Write_SLAVE(0x55 & ~0x01);
    I2C0_Read_Write_SLAVE(0x75 & ~0x04);
    printf("SLAVE Address Mask test OK.\n");
    /* Close I2C0 */
    I2C0_Close();
    while(1);
643757107|  楼主 | 2018-2-27 18:35 | 只看该作者
* @file     main.c
* @version  V3.00
* $Revision: 5 $
* $Date: 14/11/14 11:19a $
* @brief    M051 Series I2C Driver Sample Code for Wake-up (Slave)
* @note
#include <stdio.h>
uint32_t slave_buff_addr;
uint8_t g_au8SlvData[256];
uint8_t g_au8SlvRxData[3];
uint8_t g_u8SlvPWRDNWK, g_u8SlvI2CWK;
volatile uint8_t g_u8SlvDataLen;
static I2C_FUNC s_I2C0HandlerFn = NULL;
    uint32_t u32Status;
    /* Check I2C Wake-up interrupt flag set or not */
    if(I2C_GET_WAKEUP_FLAG(I2C0))
        /* Clear I2C Wake-up interrupt flag */
        I2C_CLEAR_WAKEUP_FLAG(I2C0);
        g_u8SlvI2CWK = 1;
        return;
    else
/*  Power Wake-up IRQ Handler        */
void PWRWU_IRQHandler(void)
    /* Check system power down mode wake-up interrupt flag */
    if(((CLK->PWRCON) & CLK_PWRCON_PD_WU_STS_Msk) != 0)
        /* Clear system power down wake-up interrupt flag */
        CLK->PWRCON |= CLK_PWRCON_PD_WU_STS_Msk;
                          g_u8SlvPWRDNWK = 1;
/*  I2C Slave Transmit/Receive Callback Function        */
void I2C_SlaveTRx(uint32_t u32Status)
    if(u32Status == 0x60)                       /* Own SLA+W has been receive; ACK has been return */
        g_u8SlvDataLen = 0;
        I2C_SET_CONTROL_REG(I2C0, I2C_I2CON_SI_AA);
    else if(u32Status == 0x80)                 /* Previously address with own SLA address
                                                   Data has been received; ACK has been returned*/
        g_au8SlvRxData[g_u8SlvDataLen] = (unsigned char)I2C_GET_DATA(I2C0);
        g_u8SlvDataLen++;
        if(g_u8SlvDataLen == 2)
            slave_buff_addr = (g_au8SlvRxData[0] << 8) + g_au8SlvRxData[1];
        if(g_u8SlvDataLen == 3)
            g_au8SlvData[slave_buff_addr] = g_au8SlvRxData[2];
            g_u8SlvDataLen = 0;
    else if(u32Status == 0xA8)                  /* Own SLA+R has been receive; ACK has been return */
        I2C_SET_DATA(I2C0, g_au8SlvData[slave_buff_addr]);
        slave_buff_addr++;
    else if(u32Status == 0xC0)                 /* Data byte or last data in I2CDAT has been transmitted
                                                   Not ACK has been received */
    else if(u32Status == 0x88)                 /* Previously addressed with own SLA address; NOT ACK has
                                                   been returned */
        g_u8SlvDataLen = 0;
    else if(u32Status == 0xA0)                 /* A STOP or repeated START has been received while still
                                                   addressed as Slave/Receiver*/
        g_u8SlvDataLen = 0;
    else
        /* TO DO */
void SYS_Init(void)
void UART0_Init()
    /* Init UART        */
    /* Reset IP */
    /* Set I2C 4 Slave Addresses Mask */
    I2C_SetSlaveAddrMask(I2C0, 0, 0x01);
    I2C_SetSlaveAddrMask(I2C0, 1, 0x04);
    I2C_SetSlaveAddrMask(I2C0, 2, 0x01);
    I2C_SetSlaveAddrMask(I2C0, 3, 0x04);
    I2C_Close(I2C0);
/*  Main Function        */
int32_t main(void)
    uint32_t i;
    SYS_UnlockReg();
    SYS_Init();
    UART0_Init();
    SYS_LockReg();;
        This sample code is I2C SLAVE mode and it simulates EEPROM function
    printf("\n");
    printf("+----------------------------------------------------------------------+\n");
    printf("| M05xx I2C Driver Sample Code (Slave) for wake-up & access Slave test |\n");
    printf("|        |\n");
    printf("Configure I2C0 as a slave.\n");
    /* Init I2C0 */
    I2C0_Init();
        g_au8SlvData[i] = 0;
    /* I2C function to Transmit/Receive data as slave */
    s_I2C0HandlerFn = I2C_SlaveTRx;
    /* Set I2C0 enter Not Address SLAVE mode */
    SYS_UnlockReg();
    /* Enable power wake-up interrupt */
    CLK->PWRCON |= CLK_PWRCON_PD_WU_INT_EN_Msk;
    NVIC_EnableIRQ(PWRWU_IRQn);
    /* Enable I2C wake-up */
    I2C0-> I2CWKUPCON |= I2C_I2CWKUPCON_WKUPEN_Msk;
    /* Enable Chip enter power down mode */
    CLK->PWRCON |= CLK_PWRCON_PD_WAIT_CPU_Msk;
    /* Processor use deep sleep */
    SCB->SCR = SCB_SCR_SLEEPDEEP_Msk;
    /* System power down enable */
    CLK->PWRCON |= CLK_PWRCON_PWR_DOWN_EN_Msk;
    printf("\n");
    printf("Enter PD 0x%x 0x%x\n", I2C0->I2CON , I2C0->I2CSTATUS);
    printf("\n");
    printf("CHIP enter power down status.\n");
    /* Waiting for UART printf finish*/
    while(((UART0->FSR) & UART_FSR_TE_FLAG_Msk) == 0);
    if(((I2C0->I2CON)&I2C_I2CON_SI_Msk) != 0)
    /*  Use WFI instruction to idle the CPU. NOTE:
        If ICE is attached, system will wakeup immediately because ICE is a wakeup event. */
    __WFI();
    __NOP();
    __NOP();
    __NOP();
    while((g_u8SlvPWRDNWK & g_u8SlvI2CWK) == 0);
                printf("Power-down Wake-up INT 0x%x\n", ((CLK->PWRCON) & CLK_PWRCON_PD_WU_STS_Msk));
                printf("I2C0 WAKE INT 0x%x\n", I2C0->I2CWKUPSTS);
    /* Disable power wake-up interrupt */
    CLK->PWRCON &= ~CLK_PWRCON_PD_WU_INT_EN_Msk;
    NVIC_DisableIRQ(PWRWU_IRQn);
    SYS_LockReg();
    printf("\n");
    printf("Slave wake-up from power down status.\n");
    printf("\n");
    printf("Slave Waiting for receiving data.\n");
    while(1);
[em:21:]
我看了一下例子,只有I2C有这个功能,SPI的就没有。
643757107|  楼主 | 2018-2-27 18:36 | 只看该作者
I2C还是比SPI更强大的,虽然逻辑上比SPI更难理解,但是学会了,用处很大。
用更少的线实现更高效的通信。
jiekou001| | 2018-2-27 19:06 | 只看该作者
学会这些常用的接口,比什么都重要。
xinpian101| | 2018-2-27 19:20 | 只看该作者
注释很全面啊,很容易理解。
小明的同学| | 2018-2-27 23:34 | 只看该作者
没想到这个接口这么好用
幸福小强| | 2018-2-28 22:07 | 只看该作者
有没有中文版详细讲这个硬件使用教程的。
幸福小强| | 2018-2-28 22:17 | 只看该作者
看来我要好好研究一下这个了,好多人说I2C 不好用,那就是说,用好了,很容易加薪啊
捉虫天师| | 2018-2-28 22:29 | 只看该作者
看手册啊,每个厂家的外设结构不同,用的寄存器名字也不同,当然了,你要先掌握这个协议的套路
xujunyi3611| | 2018-2-28 22:40 | 只看该作者
楼主的代码很规范呀,赞一个。
