[应用相关]
硬件数据传输
814|18
Listate|  楼主 | 2018-3-3 20:56 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
用169做主机发送数据,然后用5529接收数据,现在发现169在发送数据,但是在5529中怎么也进不了接收数据的中断,上拉电阻也加了,大神们给点意见啊,附上代码:169主机的代码:#include <studio.h>/file:///C:\Users\ADMINI~1\AppData\Local\Temp\)QN1UH78VKP2T7)IA]ZM(FW.gifar TXData = 0;
int main (void)
  WDTCTL = WDTPW + WDTHOLD;                 // Stop WDT
  P3SEL |= 0x0A;                            // Select I2C pins
  P1OUT |= 0x00;
  U0CTL |= I2C + SYNC;                      // Recommended init procedure
  U0CTL &= ~I2CEN;                          // Recommended init procedure
  I2CTCTL |= I2CSSEL1;                      // SMCLK
  I2CNDAT = 0x01;                           // Write one byte
  I2CSA = 0x0048;                           // Slave Address is 048h
  I2CIE = TXRDYIE;                          // Enable RXRDYIFG interrupt
  U0CTL |= I2CEN;                           // Enable I2C
//  I2CDCTL |=0x00;
  __enable_interrupt();                     // Enable interrupts
  while (1)
    U0CTL |= MST;                           // Master mode
    I2CTCTL |= I2CSTT + I2CSTP + I2CTRX;    // Initiate transfer
    __bis_SR_register(CPUOFF);              // Enter LPM0
// Common ISR for I2C Module
#if defined(__TI_COMPILER_VERSION__) || defined(__IAR_SYSTEMS_ICC__)
#pragma vector=USART0TX_VECTOR
__interrupt void I2C_ISR(void)
#elif defined(__GNUC__)
void __attribute__ ((interrupt(USART0TX_VECTOR))) I2C_ISR (void)
#else
#error Compiler not supported!
#endif
     I2CDRB = 0x5A;                         // TX data
     while (I2CBUSY & I2CDCTL);             // I2C ready?
     P1OUT |= 0x01;
     P1DIR |= 0x01;
     __bic_SR_register_on_exit(CPUOFF);     // Clear LPM0
5529从机的代码:
#include <msp430.h>
volatile unsigned char RXData;
int main(void)
  P3SEL |= 0x03;                            // Assign I2C pins to USCI_B0
  P1OUT = 0;
  UCB0CTL1 |= UCSWRST;                      // Enable SW reset
  UCB0CTL0 = UCMODE_3 + UCSYNC;             // I2C Slave, synchronous mode
  UCB0I2COA = 0x48;                         // Own Address is 048h
  UCB0CTL1 &= ~UCSWRST;                     // Clear SW reset, resume operation
  UCB0IE |= UCRXIE;                         // Enable RX interrupt
  while (1)
    __bis_SR_register(LPM0_bits + GIE);     // Enter LPM0, enable interrupts(就停在这里了)
    __no_operation();                       // Set breakpoint >>here<< and read
  }                                         // RXData
// USCI_B0 Data ISR
#pragma vector = USCI_B0_VECTOR
__interrupt void USCI_B0_ISR(void)
void __attribute__ ((interrupt(USCI_B0_VECTOR))) USCI_B0_ISR (void)
#else
#endif
{                                  // Vector 10: RXIFG
    RXData = UCB0RXBUF;                     // Get RX data
    P1DIR |= 0X01;
    P1OUT =0x01;
    __bic_SR_register_on_exit(LPM0_bits);   // Exit LPM0
Mozarts| | 2018-3-3 21:00 | 只看该作者
是不是 在调试中,还是独立运行中发现的问题?
_gege| | 2018-3-3 21:01 | 只看该作者
应该是没有进去中断,所以没有退出睡眠
Edisons| | 2018-3-3 21:05 | 只看该作者
建议先用逻辑分*析仪观察一下时序。
laozhongyi| | 2018-3-3 21:07 | 只看该作者
其他的中断能够执行吗?
硬件电路的问题。
wanglaojii| | 2018-3-3 21:11 | 只看该作者
这个软件和硬件都检查了吗?
zhouhuanの| | 2018-3-3 21:12 | 只看该作者
查看一下 硬件的IIC一直没有配置成功。
handleMessage| | 2018-3-3 21:17 | 只看该作者
测试一下其他的中断信号源。
bbapple| | 2018-3-3 21:18 | 只看该作者
只适用于某些对速率要求不高的场所
sourceInsight| | 2018-3-3 21:22 | 只看该作者
ack信号时间很短暂,一旦错过了这个短暂的ACK信号,就挂了
boy1990| | 2018-3-3 21:22 | 只看该作者
模拟iic,可以使用外部中断发送读取新。
CallReceiver| | 2018-3-3 21:26 | 只看该作者
不好判断是软件还是硬件的问题
hfdy01| | 2018-3-3 21:27 | 只看该作者
正常来说都是软件造成的。
xia00| | 2018-3-3 21:31 | 只看该作者
示波器测量一下IO电平信号
feiqi1| | 2018-3-3 21:31 | 只看该作者
也有可能是代码配置的问题。
androidbus| | 2018-3-3 21:35 | 只看该作者
这个是iic硬件接受中断接受不了。
litengg| | 2018-3-3 21:36 | 只看该作者
或者捕获一下IIC的电平试试吧。
huangcunxiake| | 2018-3-4 15:44 | 只看该作者
你发错版块了吧,这个430呀
430是不是内置的有上拉电阻,我记得有个寄存器叫:REN
