关于串行口打印在调试程序中的应用的问题
576|4
zhouhuanの|  楼主 | 2018-3-18 22:41 | 显示全部楼层 |阅读模式
#include <reg52.h>                //52单片机头文件
#include <intrins.h>
#include<stdio.h>
#define uchar unsigned char                //宏定义
#define uint unsigned int
sbit dula=P2^6;
sbit wela=P2^7;
sbit wr=P3^6;
sbit rd=P3^7;
uchar flag,ad;
uchar flag_uart,flag_time,flag_on,a,i,t0_num,ad_val;
float ad_vo;
uchar code tab[]={
0x3f,0x06,0x5b,0x4f,
0x66,0x6d,0x7d,0x07,
0x7f,0x6f,0x77,0x7c,
0x39,0x5e,0x79,0x71};
void delay (uint z)                                //延时函数,x的值为延时的时间(ms)
                uint c, d;
                for(c = z; c>0;c--)
                        for(d=113;d>0;d--);
void init()
        TMOD=0x21;
        TH0=(65536-45872)/256;
        TL0=(65536-45872)%256;
        TH1=0xfd;
        TL1=0xfd;
        TR1=1;
        ET0=1;
        SM0=0;
        SM1=1;
        REN=1;
        EA=1;
        ES=1;
void display(uchar val)
        uchar b,s,g;
        b=val/100;
        s=val%100/10;
        g=val%10;
        dula=1;
        P0=tab[b];
        dula=0;
        P0=0xff;
        wela=1;
        P0=0x7e;
        wela=0;
        delay(5);
        dula=1;
        P0=tab[s];
        dula=0;
        P0=0xff;
        wela=1;
        P0=0x7d;
        wela=0;
        delay(5);
        dula=1;
        P0=tab[g];
        dula=0;
        P0=0xff;
        wela=1;
        P0=0x7b;
        wela=0;
        delay(5);
uchar get_ad()
        uchar adval;
        wr=1;
        _nop_();
        wr=0;
        _nop_();
        wr=1;
        P1=0xff;
        rd=1;
        _nop_();
        rd=0;
        _nop_();
        adval=P1;
        rd=1;
        return adval;
void main(void)
        init();
        wela=1;
        P0=0x7f;
        _nop_();
        wela=0;
        while(1)
                if(flag_uart==1)
                        flag_uart=0;
                        ES=0;
                        TI=1;
                        switch(flag_on)
                                case 0:
                                puts("Turn on ad!\n");
                                TR0=1;
                                break;
                                case 1:
                                printf("Turn off ad!\n");
                                TR0=0;
                                break;
                                case 2:
                                puts("ERROR!\n");
                                break;
                                default:break;
                        while(!TI);
                        TI=0;
                        ES=1;
                if(flag_time==1)
                        flag_time=0;
                        ad_val=get_ad;
                        ad_vo=(float)ad*5.0/256.0;
                        ES=0;
                        TI=1;
                        printf("The voltage is %f V\n",ad_vo);
                        while(!TI);
                        TI=0;
                        ES=1;
                display(ad_val);
void timer_0() interrupt 1
        TH0 = (65536 -45872)/256;        //重装初值
        TL0 = (65536 - 45872)%256;
    t0_num++;
        if(t0_num==20)
                t0_num=0;
                flag_time=1;
void ser() interrupt 4
        RI=0;
        a=SBUF;
        flag_uart=1;
        if(a==1)
        flag_on=0;
        else if(a==2)
                flag_on=1;
                else
                flag_on=2;
zhouhuanの|  楼主 | 2018-3-18 22:42 | 显示全部楼层
无论如何调节ADC0804旁的电位器都一样,求解??
handleMessage| | 2018-3-18 22:43 | 显示全部楼层
我覺得這裡:ad_vo=(float)ad*5.0/256.0; 可能是 ad_vo=(float)ad_val*5.0/256.0;
bbapple| | 2018-3-18 22:46 | 显示全部楼层
uchar get_ad() 函數 中..或許 rd之前需要加適當的延時 ....(需等待ADC轉換完成...在讀取DATA )
wanglaojii| | 2018-3-18 22:48 | 显示全部楼层
不知道为什么我的程序是对的,可是调节单片机上的所有电位器都不改变数值!
