把dsp程序写入flash
2947|6
17302259960|  楼主 | 2018-3-19 16:41 | 显示全部楼层 |阅读模式
Description        Resource        Path        Location        Type
#10263 RAML5 memory range has already been        F28069.cmd        /rotated        line 104        C/C++ Problem
#10264 RAML5 memory range overlaps existing        F28069.cmd        /rotated        line 104        C/C++ Problem
#10263 RAML6 memory range has already been        F28069.cmd        /rotated        line 105        C/C++ Problem
#10264 RAML6 memory range overlaps existing        F28069.cmd        /rotated        line 105        C/C++ Problem
#10263 RAML7 memory range has already been        F28069.cmd        /rotated        line 106        C/C++ Problem
#10264 RAML7 memory range overlaps existing        F28069.cmd        /rotated        line 106        C/C++ Problem
#10263 RAML8 memory range has already been        F28069.cmd        /rotated        line 107        C/C++ Problem
#10264 RAML8 memory range overlaps existing        F28069.cmd        /rotated        line 107        C/C++ Problem
#10263 RAML4 memory range has already been        F28069.cmd        /rotated        line 103        C/C++ Problem
#10264 RAML4 memory range overlaps existing        F28069.cmd        /rotated        line 103        C/C++ Problem
#10263 RAMM1 memory range has already been        F28069.cmd        /rotated        line 100        C/C++ Problem
#10264 RAMM1 memory range overlaps existing        F28069.cmd        /rotated        line 100        C/C++ Problem
#10263 BOOT_RSVD memory range has already been        F28069.cmd        /rotated        line 98        C/C++ Problem
#10264 BOOT_RSVD memory range overlaps        F28069.cmd        /rotated        line 98        C/C++ Problem
#10263 RESET memory range has already been        F28069.cmd        /rotated        line 91        C/C++ Problem
#10264 RESET memory range overlaps existing        F28069.cmd        /rotated        line 91        C/C++ Problem
#10264 IQTABLES3 memory range overlaps        F28069.cmd        /rotated        line 88        C/C++ Problem
#10264 ROM memory range overlaps existing        F28069.cmd        /rotated        line 90        C/C++ Problem
#10264 IQTABLES2 memory range overlaps        F28069.cmd        /rotated        line 87        C/C++ Problem
#10263 IQTABLES3 memory range has already been        F28069.cmd        /rotated        line 88        C/C++ Problem
#10264 IQTABLES memory range overlaps existing        F28069.cmd        /rotated        line 86        C/C++ Problem
#10263 IQTABLES2 memory range has already been        F28069.cmd        /rotated        line 87        C/C++ Problem
#10264 FPUTABLES memory range overlaps        F28069.cmd        /rotated        line 85        C/C++ Problem
#10263 IQTABLES memory range has already been        F28069.cmd        /rotated        line 86        C/C++ Problem
#10263 FPUTABLES memory range has already been        F28069.cmd        /rotated        line 85        C/C++ Problem
#10263 BEGIN memory range has already been        F28069.cmd        /rotated        line 82        C/C++ Problem
#10264 RAML1 memory range overlaps existing        F28069.cmd        /rotated        line 71        C/C++ Problem
#10264 RAML0 memory range overlaps existing        F28069.cmd        /rotated        line 70        C/C++ Problem
该配置的文件我都配置了,这问题是啥意思呢
zhangmangui| | 2018-3-19 22:37 | 显示全部楼层
真心看不懂这是什么问题  什么错误
17302259960|  楼主 | 2018-3-22 15:00 | 显示全部楼层
zhangmangui 发表于 2018-3-19 22:37
真心看不懂这是什么问题  什么错误
就是我想把程序写入flash,配置了F28069.cmd文件之后,编译出现问题 。如上
zhangmangui| | 2018-3-22 22:17 | 显示全部楼层
看看是否工程中调用了两个cmd文件    或者就是cmd有问题
17302259960|  楼主 | 2018-3-23 21:08 | 显示全部楼层
解决了谢谢
zhangmangui| | 2018-3-25 23:13 | 显示全部楼层
有时间分享一下
赵阿客| | 2018-11-30 19:21 | 显示全部楼层
您好楼主,我也是遇到了相同的问题,请问您是怎么解决的?
