DDR MAP pack 1107
1556|3
aaaaaaddaw|  楼主 | 2018-3-21 12:20 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
DDR, AC, ck, IO, TI
Pack:1107 - Pack was unable to combine the symbols listed below into a
   single IOBM component because the site type selected is not compatible.
   Further explanation:
   The component type is determined by the types of logic and the properties and
   configuration of the logic it contains. In this case an IO component of type
   IOBM was chosen because the IO contains symbols and/or properties consistent
   with differential master usage. Please double check that the types of logic
   elements and all of their relevant properties and configuration options are
   compatible with the physical site type of the constraint.
   Summary:
   Symbols involved:
           PAD symbol "cntr0_ddr_ck" (Pad Signal = cntr0_ddr_ck)
           BUFINV symbol
   "XLXI_5/top_00/iobs_00/infrastructure_iobs_00/gen_clk[0].obufds_clk/OBUFDS"
   (Output Signal = cntr0_ddr_ck)
   Component type involved: IOBM
   Site Location involved: A10
   Site Type involved: LOWCAPIOB
ERROR:Pack:1107 - Pack was unable to combine the symbols listed below into a
   single IOBS component because the site type selected is not compatible.
   IOBS was chosen because the IO contains symbols and/or properties consistent
   with differential slave usage. Please double check that the types of logic
   Summary:
   Symbols involved:
           PAD symbol "cntr0_ddr_ck_n" (Pad Signal = cntr0_ddr_ck_n)
           SlaveBuffer symbol
   "XLXI_5/top_00/iobs_00/infrastructure_iobs_00/gen_clk[0].obufds_clk/SLAVEBUF.
   DIFFOUT" (Output Signal = cntr0_ddr_ck_n)
   Component type involved: IOBS
   Site Location involved: B10
Mapping completed.
See MAP report file "top_map.mrp" for details.
Problem encountered during the packing phase.
Design Summary
Number of errors   :   2
Number of warnings :   1
希望大佬们可以解释一下如何改正,最近在学ddr的过程中遇到的,多谢
aaaaaaddaw|  楼主 | 2018-3-21 12:25 | 只看该作者
`timescale 1ns / 1ps
`include "../rtl/ddr_parameters_0.v"
module ddr_infrastructure_iobs_0
   input      clk,
   output  [`CLK_WIDTH-1:0]   ddr_ck,
   output  [`CLK_WIDTH-1:0]   ddr_ck_n
   wire [`CLK_WIDTH-1:0]      ddr_ck_q;
   wire                       vcc;
   wire                       gnd;
   assign vcc         = 1'b1;
   assign gnd         = 1'b0;
   // Memory clock generation
   genvar clk_i;
   generate
   for (clk_i = 0; clk_i < `CLK_WIDTH; clk_i = clk_i+1) begin : gen_clk
       ODDR #
          .SRTYPE       ("SYNC"),
          .DDR_CLK_EDGE ("OPPOSITE_EDGE")
      oddr_clk
         .Q(ddr_ck_q[clk_i]),
         .C(clk),
         .CE(vcc),
         .D1(gnd),
         .D2(vcc),
         .R(gnd),
         .S(gnd)
     OBUFDS obufds_clk
         .I(ddr_ck_q[clk_i]),
         .O(ddr_ck[clk_i]),
         .OB(ddr_ck_n[clk_i])
   end
   endgenerate
endmodule
aaaaaaddaw|  楼主 | 2018-3-21 12:30 | 只看该作者
希望有大佬回复
aaaaaaddaw|  楼主 | 2018-3-25 20:50 | 只看该作者
解决了
