(TI MCU分享)关于TMS320f2812的串口中断的问题
2714|2
gaochy1126|  楼主 | 2011-7-20 12:19 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
(TI MCU分享)开始学习DSP的时候,在串口使用时,不通过中断接收和发送信息使用了下面的例程可以实现信息的发送与接收,但是使用了中断以后,程序不执行。
    Send_Flag = 0;
    #if SCIA_INT
/*设置中断服务程序入口地址*/
EALLOW; // This is needed to write to EALLOW protected registers
PieVectTable.TXAINT = &SCITXINTA_ISR;
PieVectTable.RXAINT = &SCIRXINTA_ISR;
EDIS;   // This is needed to disable write to EALLOW protected registers
/*开中断*/
IER |= M_INT9;
#endif
EINT;   // Enable Global interrupt INTM
ERTM; // Enable Global realtime interrupt DBGM
for(;;)
  if((SciaTx_Ready() == 1) && (Send_Flag == 1))
   SciaRegs.SCITXBUF = Sci_VarRx;
   Send_Flag = 0;
   i++;
   if(i == j)
    i = 0;
    j = 0;
  #if !SCIA_INT
  if(SciaRx_Ready() == 1)
   Sci_VarRx[j] = SciaRegs.SCIRXBUF.all;
   Send_Flag = 1;
   j++;
   if(j == 100)
    j = 0;
  #endif
所写的串口中断程序如下:
#include "DSP28_Device.h"
unsigned int Sci_VarRx[100];
unsigned int i,j;
unsigned int Send_Flag;
unsigned int * Led8  = (unsigned int *) 0x4100;
//#define SCIA_INT 1
interrupt void SCITXINTA_ISR1(void);
interrupt void SCIRXINTA_ISR1(void);
void main(void)
/*初始化系统*/
InitSysCtrl();
/*关中断*/
DINT;
IER = 0x0000;
IFR = 0x0000;
/*初始化PIE中断*/
InitPieCtrl();
/*初始化PIE中断矢量表*/
InitPieVectTable();
/*初始化SCIA寄存器*/
    InitSci();
    for(i = 0; i < 100; i++)
     Sci_VarRx = 0;
    i = 0;
    j = 0;
    Send_Flag = 0;
   #if SCIA_INT
/*设置中断服务程序入口地址*/
PieVectTable.TXAINT = &SCITXINTA_ISR1;
PieVectTable.RXAINT = &SCIRXINTA_ISR1;
/*开中断*/
IER |= M_INT9;
#endif
for(;;)
  if(1 && (Send_Flag == 1))
   SciaRegs.SCITXBUF = Sci_VarRx[0];
   while(SciaRegs.SCICTL2.bit.TXRDY!=1);
   Send_Flag = 0;
   i++;
   if(i == j)
    i = 0;
    j = 0;
  #if !SCIA_INT
   Send_Flag = 1;
   j++;
   if(j == 100)
    j = 0;
  #endif
DINT;
PieCtrl.PIEACK.bit.ACK9=1;
Sci_VarRx[0] = SciaRegs.SCIRXBUF.all;
Send_Flag = 1;
j++;
// if(j == 100)
//  j = 0;
   *Led8=j;
SciaRegs.SCICTL1.bit.SWRESET =1;
PieCtrl.PIEIFR9.bit.INTx1=1;
EINT;
请问,该问题如何解决?谢谢!
米其林r| | 2011-8-25 23:42 | 只看该作者
你断点调试一下,看看问题出在哪
lisijun100| | 2011-8-25 23:56 | 只看该作者
学习一下
