DSP28335控制MLX90614
1083|9
混子黄|  楼主 | 2018-4-9 16:49 | 显示全部楼层
头文件
#ifndef DSP28_MLX90614_H
#define DSP28_MLX90614_H
#define input_90614()    {EALLOW;GpioCtrlRegs.GPAMUX2.bit.GPIO16=0;GpioCtrlRegs.GPADIR.bit.GPIO16=0;EDIS;}
#define output_90614()   {EALLOW;GpioCtrlRegs.GPAMUX2.bit.GPIO16=0;GpioCtrlRegs.GPADIR.bit.GPIO16=1;EDIS;}
#define SDA_90614_in     GpioDataRegs.GPADAT.bit.GPIO16
#define SDA_90614_OUT_H   {output_90614();GpioDataRegs.GPADAT.bit.GPIO16=1;}
#define SDA_90614_OUT_L   {output_90614();GpioDataRegs.GPADAT.bit.GPIO16=0;}
#define SCLK_90614_H      {EALLOW;GpioCtrlRegs.GPADIR.bit.GPIO17=1;EDIS;GpioDataRegs.GPADAT.bit.GPIO17=1;}
#define SCLK_90614_L      {EALLOW;GpioCtrlRegs.GPADIR.bit.GPIO17=1;EDIS;GpioDataRegs.GPADAT.bit.GPIO17=0;}
#define EEPROM_90614     0x20
#define ROM_90614        0x00
extern void delay_90614(void);
extern unsigned char get_ack(void);
extern void delay_90614us(u_long datax);
extern void start_90614(void);
extern void init_90614(void);
extern void write_90614_slave(u_char address);
extern void stop_90614(void);
extern void set_90614_slave( u_char old_slave,u_char new_slave);
extern unsigned int get_90614_temp(u_char slave,u_char command);
extern void write_90614_process(unsigned char slave,unsigned char command,unsigned char DATA_H,unsigned char DATA_L);
extern unsigned char readbyte_90614(void);
extern void set_90614_emissivity(u_char slave,u_int emissivity);
extern void write_90614_byte( unsigned char data_byte);
extern unsigned char get_pec(unsigned char *par, unsigned char len);
#endif
混子黄|  楼主 | 2018-4-9 16:51 | 显示全部楼层
C文件
   #include "DSP2833x_Device.h"
   unsigned char pecdata[5]={0};
   static const unsigned char crc_table[]=
         0x00,0x07,0x0e,0x09,0x1c,0x1b,0x12,0x15,
         0x38,0x3f,0x36,0x31,0x24,0x23,0x2a,0x2d,
         0x70,0x77,0x7e,0x79,0x6c,0x6b,0x62,0x65,
         0x48,0x4f,0x46,0x41,0x54,0x53,0x5a,0x5d,
         0xe0,0xe7,0xee,0xe9,0xfc,0xfb,0xf2,0xf5,
         0xd8,0xdf,0xd6,0xd1,0xc4,0xc3,0xca,0xcd,
         0x90,0x97,0x9e,0x99,0x8c,0x8b,0x82,0x85,
         0xa8,0xaf,0xa6,0xa1,0xb4,0xb3,0xba,0xbd,
         0xc7,0xc0,0xc9,0xce,0xdb,0xdc,0xd5,0xd2,
         0xff,0xf8,0xf1,0xf6,0xe3,0xe4,0xed,0xea,
         0xb7,0xb0,0xb9,0xbe,0xab,0xac,0xa5,0xa2,
         0x8f,0x88,0x81,0x86,0x93,0x94,0x9d,0x9a,
         0x27,0x20,0x29,0x2e,0x3b,0x3c,0x35,0x32,
         0x1f,0x18,0x11,0x16,0x03,0x04,0x0d,0x0a,
         0x57,0x50,0x59,0x5e,0x4b,0x4c,0x45,0x42,
         0x6f,0x68,0x61,0x66,0x73,0x74,0x7d,0x7a,
         0x89,0x8e,0x87,0x80,0x95,0x92,0x9b,0x9c,
         0xb1,0xb6,0xbf,0xb8,0xad,0xaa,0xa3,0xa4,
         0xf9,0xfe,0xf7,0xf0,0xe5,0xe2,0xeb,0xec,
         0xc1,0xc6,0xcf,0xc8,0xdd,0xda,0xd3,0xd4,
         0x69,0x6e,0x67,0x60,0x75,0x72,0x7b,0x7c,
         0x51,0x56,0x5f,0x58,0x4d,0x4a,0x43,0x44,
         0x19,0x1e,0x17,0x10,0x05,0x02,0x0b,0x0c,
         0x21,0x26,0x2f,0x28,0x3d,0x3a,0x33,0x34,
         0x4e,0x49,0x40,0x47,0x52,0x55,0x5c,0x5b,
         0x76,0x71,0x78,0x7f,0x6a,0x6d,0x64,0x63,
         0x3e,0x39,0x30,0x37,0x22,0x25,0x2c,0x2b,
         0x06,0x01,0x08,0x0f,0x1a,0x1d,0x14,0x13,
         0xae,0xa9,0xa0,0xa7,0xb2,0xb5,0xbc,0xbb,
         0x96,0x91,0x98,0x9f,0x8a,0x8d,0x84,0x83,
         0xde,0xd9,0xd0,0xd7,0xc2,0xc5,0xcc,0xcb,
         0xe6,0xe1,0xe8,0xef,0xfa,0xfd,0xf4,0xf3
       void init_90614(void){
//        MUXB  = 0x00;//      GpioCtrlRegs.GPAMUX2.bit./
//        MUXC  = 0x00;//      GpioCtrlRegs.GPAMUX2.bit.GPIO17
    GpioCtrlRegs.GPAMUX2.bit.GPIO16 = 0x00;
    GpioCtrlRegs.GPADIR.bit.GPIO16 = 0x01;
    GpioCtrlRegs.GPAMUX2.bit.GPIO17 = 0x00;
    GpioCtrlRegs.GPADIR.bit.GPIO17 = 0x01;
    SCLK_90614_H;
    SDA_90614_OUT_H;
C文件
////delay1us
        u_long i;
        i=7;
        while(i--);
      u_long i;
      i=datax;
      while(i--)
      delay_90614();
        output_90614();
     delay_90614us(8);
         SDA_90614_OUT_H;
         delay_90614us(1);
        SCLK_90614_H;
        // delay_90614us(1);
//        SDA_90614_OUT_H;
        delay_90614us(10);
    SDA_90614_OUT_L;
        delay_90614us(10);
        SCLK_90614_L;
   output_90614();
   SCLK_90614_H;
   SDA_90614_OUT_L;
   delay_90614us(10);
   SDA_90614_OUT_H;
   delay_90614us(10);
   SCLK_90614_L;
   delay_90614us(10);
混子黄|  楼主 | 2018-4-9 16:52 | 显示全部楼层
C文件
    u_char slave_address=0;
    u_char i;
    slave_address = address;
    SCLK_90614_L;
    output_90614();
        delay_90614us(2);
    for(i=0;i<8;i++)
    if((slave_address & 0x80) == 0x80)
               { SDA_90614_OUT_H;}
    else   SDA_90614_OUT_L;
    delay_90614us(20);
    slave_address <<=1;
    SCLK_90614_H;
    delay_90614us(20);
    SCLK_90614_L;
    unsigned char i,crc,data;
    crc=0x00;
   // data=*par++;
    while(len--){
        crc = crc_table[crc ^ *par++];
//        data =  ;
    return (crc);
C文件
         u_char i;
    slave_address = data_byte;
    SCLK_90614_L;
    output_90614();
//        delay_90614us(2);
    for(i=0;i<8;i++)
               { SDA_90614_OUT_H;}
    delay_90614us(20);
    slave_address <<=1;
    SCLK_90614_H;
    delay_90614us(20);
    SCLK_90614_L;
        //         input_90614();
        //         return (SDA_90614_in);
delay_90614us(3);
                 u_char ack;
        //         SDA_90614_OUT_L;
                 input_90614();
        //         SCLK_90614_L;
                 delay_90614us(20);
                 if(SDA_90614_in ==1)
                 ack = 1;
                 else ack = 0;
                 SCLK_90614_H;
                 delay_90614us(20);
        SCLK_90614_L;
                 return ack;
混子黄|  楼主 | 2018-4-9 16:53 | 显示全部楼层
C文件
                  unsigned char data,i;
                                  data = 0;
                                  input_90614();
                //                  delay_90614us(10);
                                  SCLK_90614_L;
                  for(i=0;i<8;i++)
                                  data<<=1;
                                  if(SDA_90614_in == 1)
                                  data|=0x01;
                                  else data|=0x00;
                     SCLK_90614_L;
                  delay_90614us(10);
                      SCLK_90614_H;
                                  delay_90614us(20);
                                    SCLK_90614_L;
                  delay_90614us(10);
                                  SCLK_90614_L;
                        //          output_90614();
                                  SDA_90614_OUT_L;
                                  delay_90614us(20);
                                   SCLK_90614_H;
                                  delay_90614us(20);
                                   return data;
void write_90614_process(unsigned char slave,unsigned char command,unsigned char DATA_L,unsigned char DATA_H)
                u_char pec_data,ack_data,i,new_slave,new_command;
                output_90614();
                new_slave = slave;
                new_slave<<=1;
                new_command = command;
                new_command = new_command | 0x20 ;
                pecdata[0] = new_slave;
                pecdata[1] = new_command;
                pecdata[2] = DATA_L;
                pecdata[3] = DATA_H;
                pecdata[4] = 0x00;
                i=10;
                pec_data = get_pec(pecdata,4);
                while(i>0)
                start_90614();
                write_90614_byte(new_slave);
                ack_data = get_ack();
                if(ack_data == 0)
                write_90614_byte(new_command);
                if(ack_data == 0)
                write_90614_byte(DATA_L);
                  if(ack_data == 0)
                   write_90614_byte(DATA_H);
                      if(ack_data == 0)
                          write_90614_byte(pec_data);
                             if(ack_data == 0)
                                  i=0;
                                  stop_90614();
                                  else
                                  i--;
                                  stop_90614();
                          else
                          i--;
                          stop_90614();
                   else
                   i--;
                   stop_90614();
                else
                i--;
                stop_90614();
            else
            i--;
                stop_90614();
C文件
      u_char old_slave1,new_slave1;
       old_slave1 = old_slave;
      new_slave1 = new_slave;
     write_90614_process(old_slave1,0x0e,0x00,0x00);
     delay_90614us(10000);
     write_90614_process(old_slave1,0x0e,new_slave1,0x00);
         u_char data_L,data_H,new_slave;
         data_L = emissivity & 0x00ff;
         data_H = (emissivity>>8) & 0x00ff;
         write_90614_process(new_slave,0x04,0x00,0x00);
         write_90614_process(new_slave,0x04,data_L,data_H);
        u_char TEMP_H,TEMP_L,pec_data,ack_data,i,new_slave;
         int TEMP_90614 = 10;
        unsigned int data_temp;
        i=10;
        while(i>0)
        new_slave = slave;
        start_90614();
        new_slave <<=1;
        if(ack_data == 0 )
        write_90614_byte(command);
        if(ack_data == 0 )
        start_90614();
        new_slave = slave;
        new_slave <<=1;
        new_slave +=1;
        if(ack_data == 0 )
        TEMP_L = readbyte_90614();
        TEMP_H = readbyte_90614();
        pec_data = readbyte_90614();
        stop_90614();
        i = 0;
    TEMP_90614 = (TEMP_H << 8) | TEMP_L ;
        TEMP_90614 = TEMP_90614 * 2 - 27315;
        else
        i--;
        stop_90614();
        else
        i--;
        stop_90614();
        else
        i--;
        stop_90614();
        if(TEMP_90614 > 100)
        data_temp = TEMP_90614;
        else
    data_temp = ~ (TEMP_90614 - 1);
    data_temp = data_temp | 0x80;
        return (data_temp);
混子黄|  楼主 | 2018-4-9 17:14 | 显示全部楼层
混子黄|  楼主 | 2018-4-9 20:34 | 显示全部楼层
111111111
90614.h.pdf
28.83 KB
90614c.pdf
43.71 KB
