- #include "vsf.h"
- #include "usrapp.h"
- struct usrapp_t usrapp;
- void usrapp_on_timer1S(void *param)
-     struct usrapp_t *app = (struct usrapp_t *)param;
-     if (app->toggle)
-         vsfhal_gpio_set(0, 1 << 1);
-     else
-         vsfhal_gpio_clear(0, 1 << 1);
-     app->toggle = !app->toggle;
- void usrapp_srt_init(struct usrapp_t *app)
-     vsfhal_gpio_init(0);
-     vsfhal_gpio_config_pin(0, 1, GPIO_OUTPP);
-     usrapp_on_timer1S(app);
-     vsftimer_create_cb(1000, -1, usrapp_on_timer1S, app);
2. 事件驱动构架:
- #include "vsf.h"
- struct vsfsm_state_t*
- usrapp_led_evt_handler(struct vsfsm_t *sm, vsfsm_evt_t evt);
- struct usrapp_t usrapp =
-     .sm.init_state.evt_handler      = usrapp_led_evt_handler,
-     .sm.user_data                   = &usrapp,
- #define USRAPP_EVT_ON1S                 VSFSM_EVT_USER
-     struct usrapp_t *app = (struct usrapp_t *)sm->user_data;
-     switch (evt)
-     case VSFSM_EVT_INIT:
-         vsftimer_create(sm, 1000, -1, USRAPP_EVT_ON1S);
-         // fall through
-     case USRAPP_EVT_ON1S:
-         if (app->toggle)
-         else
-         break;
-     return NULL;
-     vsfsm_init(&app->sm);
3. 原状态机(msm):
- #include "vsf.h"
- enum
-     STATE_INIT = 0,
-     STATE_ON,
-     STATE_OFF,
- int usrapp_do_init(struct vsfsm_msm_t *msm);
- int usrapp_do_on(struct vsfsm_msm_t *msm);
- int usrapp_do_off(struct vsfsm_msm_t *msm);
-     .msm.entry_num              = dimof(usrapp.trans_tbl),
-     .msm.trans_tbl              = usrapp.trans_tbl,
-     .msm.user_data              = &usrapp,
-     .msm.state                  = STATE_INIT,
-     .trans_tbl[0]               = {STATE_INIT, VSFSM_EVT_INIT, NULL, usrapp_do_init},
-     .trans_tbl[1]               = {STATE_ON, USRAPP_EVT_ON1S, NULL, usrapp_do_off},
-     .trans_tbl[2]               = {STATE_OFF, USRAPP_EVT_ON1S, NULL, usrapp_do_on},
-     vsfhal_gpio_set(1, 1 << 1);
-     return STATE_ON;
-     vsfhal_gpio_clear(1, 1 << 1);
-     return STATE_OFF;
-     vsfhal_gpio_init(1);
-     vsfhal_gpio_config_pin(1, 1, GPIO_OUTPP);
-     vsftimer_create(msm->sm, 1000, -1, USRAPP_EVT_ON1S);
-     return usrapp_do_off(msm);
-     vsfsm_msm_init(&app->sm, &app->msm);
4. PT协程:
- #include "vsf.h"
- vsf_err_t usrapp_led_thread(struct vsfsm_pt_t *pt, vsfsm_evt_t evt);
-     .pt.thread                      = usrapp_led_thread,
-     .pt.user_data                   = &usrapp,
-     struct usrapp_t *app = (struct usrapp_t *)pt->user_data;
-     vsfsm_pt_begin(pt);
-     vsftimer_create(pt->sm, 1000, -1, USRAPP_EVT_ON1S);
-     while (1)
-         if (app->toggle)
-         else
-         vsfsm_pt_wfe(pt, USRAPP_EVT_ON1S);
-     vsfsm_pt_end(pt);
-     return VSFERR_NONE;
-     vsfsm_pt_init(&app->sm, &app->pt);
5. setjmp方式:
- #include "vsf.h"
- void usrapp_led_thread(struct vsfsm_ljmp_t *ljmp);
-     .ljmp.thread        = usrapp_led_thread,
-     .ljmp.user_data     = &usrapp,
-     .ljmp.stack         = usrapp.stack + sizeof(usrapp.stack),
-     struct usrapp_t *app = (struct usrapp_t *)ljmp->user_data;
-     vsftimer_create(ljmp->sm, 1000, -1, USRAPP_EVT_ON1S);
-     while (1)
-         if (app->toggle)
-         else
-         vsfsm_ljmp_wfe(ljmp, USRAPP_EVT_ON1S);
-     vsfsm_ljmp_init(&app->sm, &app->ljmp);
