发新帖本帖赏金 0.10元(功能说明)我要提问
返回列表
[C语言]
CRC16校验
1750|10
山东电子小菜鸟|  楼主 | 2018-4-16 21:08 | 显示全部楼层 |阅读模式
/* CRC  High */
unsigned char   auchCRCHi[] = {
        0x00, 0xC1, 0x81, 0x40, 0x01, 0xC0, 0x80, 0x41, 0x01, 0xC0,
        0x80, 0x41, 0x00, 0xC1, 0x81, 0x40, 0x01, 0xC0, 0x80, 0x41,
        0x00, 0xC1, 0x81, 0x40, 0x00, 0xC1, 0x81, 0x40, 0x01, 0xC0,
        0x80, 0x41, 0x01, 0xC0, 0x80, 0x41, 0x00, 0xC1, 0x81, 0x40,
        0x00, 0xC1, 0x81, 0x40, 0x01, 0xC0, 0x80, 0x41, 0x00, 0xC1,
        0x81, 0x40, 0x01, 0xC0, 0x80, 0x41, 0x01, 0xC0, 0x80, 0x41,
        0x81, 0x40, 0x00, 0xC1, 0x81, 0x40, 0x01, 0xC0, 0x80, 0x41,
        0x80, 0x41, 0x00, 0xC1, 0x81, 0x40, 0x00, 0xC1, 0x81, 0x40,
        0x01, 0xC0, 0x80, 0x41, 0x01, 0xC0, 0x80, 0x41, 0x00, 0xC1,
        0x81, 0x40, 0x01, 0xC0, 0x80, 0x41, 0x00, 0xC1, 0x81, 0x40,
        0x01, 0xC0, 0x80, 0x41, 0x00, 0xC1, 0x81, 0x40, 0x01, 0xC0,
/* CRC Low*/
unsigned char  auchCRCLo[] = {
        0x00, 0xC0, 0xC1, 0x01, 0xC3, 0x03, 0x02, 0xC2, 0xC6, 0x06,
        0x07, 0xC7, 0x05, 0xC5, 0xC4, 0x04, 0xCC, 0x0C, 0x0D, 0xCD,
        0x0F, 0xCF, 0xCE, 0x0E, 0x0A, 0xCA, 0xCB, 0x0B, 0xC9, 0x09,
        0x08, 0xC8, 0xD8, 0x18, 0x19, 0xD9, 0x1B, 0xDB, 0xDA, 0x1A,
        0x1E, 0xDE, 0xDF, 0x1F, 0xDD, 0x1D, 0x1C, 0xDC, 0x14, 0xD4,
        0xD5, 0x15, 0xD7, 0x17, 0x16, 0xD6, 0xD2, 0x12, 0x13, 0xD3,
        0x11, 0xD1, 0xD0, 0x10, 0xF0, 0x30, 0x31, 0xF1, 0x33, 0xF3,
        0xF2, 0x32, 0x36, 0xF6, 0xF7, 0x37, 0xF5, 0x35, 0x34, 0xF4,
        0x3C, 0xFC, 0xFD, 0x3D, 0xFF, 0x3F, 0x3E, 0xFE, 0xFA, 0x3A,
        0x3B, 0xFB, 0x39, 0xF9, 0xF8, 0x38, 0x28, 0xE8, 0xE9, 0x29,
        0xEB, 0x2B, 0x2A, 0xEA, 0xEE, 0x2E, 0x2F, 0xEF, 0x2D, 0xED,
        0xEC, 0x2C, 0xE4, 0x24, 0x25, 0xE5, 0x27, 0xE7, 0xE6, 0x26,
        0x22, 0xE2, 0xE3, 0x23, 0xE1, 0x21, 0x20, 0xE0, 0xA0, 0x60,
        0x61, 0xA1, 0x63, 0xA3, 0xA2, 0x62, 0x66, 0xA6, 0xA7, 0x67,
        0xA5, 0x65, 0x64, 0xA4, 0x6C, 0xAC, 0xAD, 0x6D, 0xAF, 0x6F,
        0x6E, 0xAE, 0xAA, 0x6A, 0x6B, 0xAB, 0x69, 0xA9, 0xA8, 0x68,
        0x78, 0xB8, 0xB9, 0x79, 0xBB, 0x7B, 0x7A, 0xBA, 0xBE, 0x7E,
        0x7F, 0xBF, 0x7D, 0xBD, 0xBC, 0x7C, 0xB4, 0x74, 0x75, 0xB5,
        0x77, 0xB7, 0xB6, 0x76, 0x72, 0xB2, 0xB3, 0x73, 0xB1, 0x71,
        0x70, 0xB0, 0x50, 0x90, 0x91, 0x51, 0x93, 0x53, 0x52, 0x92,
        0x96, 0x56, 0x57, 0x97, 0x55, 0x95, 0x94, 0x54, 0x9C, 0x5C,
        0x5D, 0x9D, 0x5F, 0x9F, 0x9E, 0x5E, 0x5A, 0x9A, 0x9B, 0x5B,
        0x99, 0x59, 0x58, 0x98, 0x88, 0x48, 0x49, 0x89, 0x4B, 0x8B,
        0x8A, 0x4A, 0x4E, 0x8E, 0x8F, 0x4F, 0x8D, 0x4D, 0x4C, 0x8C,
        0x44, 0x84, 0x85, 0x45, 0x87, 0x47, 0x46, 0x86, 0x82, 0x42,
        0x43, 0x83, 0x41, 0x81, 0x80, 0x40
//程序名:uint CRC16(uchar *puchMsg, uchar usDataLen)
//入口参数:*puchMsg:需要计算校验码的数组     usDataLen:需要计算校验码的长度
//出口参数:uint型数据,为计算的crc16校验码
//程序说明:本校验码的生成方式和上位机的生成方式有区别,其高低位正好相反
/* CRC Check ---- A Table-Driven  Implementation-----*///auchCRCHi
ushort CRC16(uchar *puchMsg,uchar usDataLen)
    uchar uchCRCHi=0xFF;
    uchar uchCRCLo=0xFF;
    unsigned long uIndex;
    while(usDataLen--)
                uIndex=uchCRCHi^*puchMsg++;
        uchCRCHi=uchCRCLo^auchCRCHi[uIndex];
        uchCRCLo=auchCRCLo[uIndex];
    return (uchCRCHi<<8|uchCRCLo);
airwill| | 2018-4-17 07:13 | 显示全部楼层
不能说你的程序有问题, 不过保存这么大的表格, 太浪费 ROM 空间了
有些系统不一定能承受的
还有优化的办法么
打赏榜单
山东电子小菜鸟 打赏了 0.10 元 2018-04-17
877049204| | 2018-4-17 14:30 | 显示全部楼层
有些系统不一定能承受的
还有优化的办法 ...
这是查表的方法,用的比较多,以前做MODBUS的时候用的这种。好像有其他的方法,但是没用过
nuaabob| | 2018-4-17 14:33 | 显示全部楼层
CRC-16,要么费ROM空间,要么费CPU资源,鱼与熊掌不可兼得。
airwill| | 2018-4-17 15:30 | 显示全部楼层
你可能太武断了点
coody| | 2018-4-17 17:35 | 显示全部楼层
记得十几年前,我狠狠的研究了MODBUS的CRC16的表,然后简化成4个小的表,一个小的表16字节,总共64字节,这样就兼顾了速度和容量。
nuaabob 2019-1-21 13:09 回复TA
你牛,如果方便的话分享来看看,让我也学习学习,谢谢!
CreatorLv 2018-4-17 20:14 回复TA
老哥 那两个表是怎么产生的
linqing171| | 2018-4-17 21:22 | 显示全部楼层
确实见过半表的。 @hotpower
以前教通讯原理的老师,讲异或,就是不带进位的减法。而整个CRC,则是一种除以一个称为多项式的二进制数来求余数的计算过程。
A/B = C ......D
如果B为固定的多项式,已知A,可以求D;反过来只知道B和D来求A是不行的。
二进制一位一位的除,和8位8位的除(需要一个类似小九九的表格),又或者4位4位的除,都是可以的。
不过硬件计算的话可以加速很多,鱼和熊掌可以兼得。
不过对CRC研究最深的,当属老Hot大叔。
@hotpower , 大叔网站怎么卖给别人了? 我京东搜索 hotpower,和 http://www.hotpower.org/HotAjax/HotPower_HotAjax.html 都成了一家做某商品的了?
linqing171| | 2018-4-17 21:25 | 显示全部楼层
网站虽然卖了,但是江湖上还是 踏雪留痕。
http://blog.sina.com.cn/s/blog_5f17741f0100lbkq.html
http://www.**.com/HotPower/blog/12-09/285633_a1fcf.html
hotpower| | 2018-12-30 00:31 | 显示全部楼层
晕,是网页不要了,被别人占了。现在是
http://www.hotpage.com.cn/hotcrc
发新帖 本帖赏金 0.10元(功能说明)我要提问
个人签名:qq:641208111;技术交流群:377640799 大学电子竞赛预热赛开赛啦~千元大奖等你来拿火热进行中!!点击参加活动 欢迎加个人QQ:641208111一起交流合作
140
