[51单片机]
LED点阵重影问题?
1549|14
慧剑温情|  楼主 | 2018-4-19 22:37 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
用4个点阵做成的16X16点阵,显示一个汉字向上移动时会有重影,请问如何解决?
以下为代码及原理图
#include<reg52.h>
sbit DS=P0^0;
sbit SH=P0^1;
sbit ST=P0^2;
unsigned char code LED1[]={0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x40,0x37,0x10,0x80,0x60,0x20,0x0B,0x10,0x20,0xE0,0x20,0x20,0x20,0x2F,0x20,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,};
unsigned char code LED2[]={0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x08,0xFC,0x40,0x40,0x40,0x48,0xFC,0x40,0x40,0x40,0x40,0x40,0x44,0xFE,0x00,
unsigned char code LED3[]={0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x40,0x37,0x10,0x80,0x60,0x20,0x0B,0x10,0x20,0xE0,0x20,0x20,0x20,0x2F,0x20,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00};
unsigned char code LED4[]={0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x08,0xFC,0x40,0x40,0x40,0x48,0xFC,0x40,0x40,0x40,0x40,0x40,0x44,0xFE,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
#define  Timer  2500
void hc595_in(unsigned char dat)
        unsigned char z;
        for(z=0;z<8;z++)
                if((dat&0x80)==0x80)
                        DS=1;
                else
                        DS=0;
                dat=dat<<1;
                SH=0;
                SH=1;
void hc595_out()
        ST=0;
        ST=1;
void main()
         TMOD=0x01;
         TH0=(65536-Timer)/256;
         TL0=(65536-Timer)%256;
         ET0=1;
         TR0=1;
         EA=1;
         P2 = 0xFF;
         while(1);
void interrupttimer0() interrupt 1
    static unsigned char numhang=0;
        static unsigned char cnt=0;
        static unsigned char t=0;
        P2 = 0xFF;
        switch(numhang)
                case 0:
                        hc595_in(LED4[numhang+cnt]);
                        hc595_in(LED3[numhang+cnt]);
                        hc595_in(LED2[numhang+cnt]);
                        hc595_in(LED1[numhang+cnt]);
                        hc595_out();
                        P2=0x7F;
                  numhang++;
                        break;
                case 1:
                        hc595_out();
                        P2=0xBF;
                  numhang++;
                        break;
                case 2:
                        hc595_out();
                        P2=0xDF;
                  numhang++;;
                        break;
                case 3:
                        hc595_out();
                        P2=0xEF;
                  numhang++;
                        break;
                case 4:
                        hc595_out();
                        P2=0xF7;
                  numhang++;
                        break;
                case 5:
                        hc595_out();
                        P2=0xFB;
                  numhang++;
                        break;
                case 6:
                        hc595_out();
                        P2=0xFD;
                  numhang++;;
                        break;
                case 7:
                        hc595_out();
                        P2=0xFE;
                  numhang=0;
                        break;
                        default:
                        break;
        t++;
        if(t>=20)
                t=0;
                cnt++;
                if(cnt>=32)
                        cnt=0;
xyz549040622| | 2018-4-19 23:33 | 只看该作者
论坛的消息真不方便。直接@xyz549040622更方便
xyz549040622| | 2018-4-19 23:34 | 只看该作者
上传你的工程包,我看看。
慧剑温情|  楼主 | 2018-4-20 07:49 | 只看该作者
xyz549040622 发表于 2018-4-19 23:34
上传你的工程包,我看看。
昨晚睡的早,晚上发给你,马上去上班了,谢谢!@xyz549040622
coody| | 2018-4-20 11:32 | 只看该作者
视觉暂留造成的吧?消除不了的,只能减弱。
慧剑温情|  楼主 | 2018-4-20 18:56 | 只看该作者
上传你的工程包,我看看。
@xyz549040622
点阵16x16.rar
103.98 KB
xyz549040622| | 2018-4-20 22:37 | 只看该作者
我感觉是你的算法不对引起的,你把固定显示的一个字的字符编码贴上来。比如显示一个汉字,把这个固定的编码发上来。
慧剑温情|  楼主 | 2018-4-20 22:59 | 只看该作者
xyz549040622 发表于 2018-4-20 22:37
我感觉是你的算法不对引起的,你把固定显示的一个字的字符编码贴上来。比如显示一个汉字,把这个固定的编 ...
@xyz549040622
程序16x16固定-一个字.rar
32.33 KB
xyz549040622| | 2018-4-21 10:13 | 只看该作者
固定一个字也是看见有闪烁的,程序是没有问题的,只能归结于仿真的缺陷了。
慧剑温情|  楼主 | 2018-4-21 12:55 | 只看该作者
xyz549040622 发表于 2018-4-21 10:13
固定一个字也是看见有闪烁的,程序是没有问题的,只能归结于仿真的缺陷了。 ...
行,谢谢你!
xch| | 2018-4-22 17:14 | 只看该作者
你这程序表示图形显示每20周期位移一行。 不知你刷新周期是多少,你可以试试每当t =19时输出消隐帧(全黑)看看是不是改善了。
xch| | 2018-4-22 17:20 | 只看该作者
你这程序表示图形显示每扫描显示20行位移一行。实际上没有显示完整一帧图像。一帧是扫描8行。
所以,改成 每扫描24行位移一行为好。
另外,每次位移前插入一黑帧。
xch 2018-4-22 17:21 回复TA
if(t>=20) 改成 if(t>=24)
13
慧剑温情|  楼主 | 2018-4-23 13:35 | 只看该作者
所以,改成  ...
插入一黑帧怎么弄?
xch| | 2018-4-23 15:11 | 只看该作者
慧剑温情 发表于 2018-4-23 13:35
插入一黑帧怎么弄?
if ( t<24)switch(numhang)
if (t>=25)
t=0;
改两地方
25次中断显示24次,另外一次消隐
