[技术问答]
N76E003可以使用几个外部中断?
2731|10
abin88|  楼主 | 2018-5-7 15:31 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
在管脚图上只看到INT0  INT1 ?难道没有其他的外部中断可以用了?
yiy| | 2018-5-7 22:03 | 只看该作者
基本上每个IO都可以,你说的这个是兼容传统8051的中断,另外其他的GPIO还支持GPIO类中断,这些中断是共用中断入口的,而INT0,INT1是独立中断入口。
yiy| | 2018-5-7 22:10 | 只看该作者
/* Copyright(c) 2017 Nuvoton Technology Corp. All rights reserved.                                         */
//  Nuvoton Technoledge Corp.
//  Website: http://www.nuvoton.com
//  E-Mail : MicroC-8bit@nuvoton.com
//  Date   : Apr/21/2017
//  File Function: N76E003 I/O Interrupt demo code
#include "N76E003.h"
#include "SFR_Macro.h"
#include "Function_define.h"
#include "Common.h"
#include "Delay.h"
#if 0
//Following setting in Function_define.h
//   Enable INT port 0~3
//#define         Enable_INT_Port0                                        PICON &= 0xFB;
//#define                Enable_INT_Port1                                        PICON |= 0x01;
//#define                Enable_INT_Port2                                        PICON |= 0x02;
//#define                Enable_INT_Port3                                        PICON |= 0x03;
// Enable each bit low level trig mode
//#define                Enable_BIT7_LowLevel_Trig                        PICON&=0x7F;PINEN|=0x80;PIPEN&=0x7F
//#define                Enable_BIT6_LowLevel_Trig                        PICON&=0x7F;PINEN|=0x40;PIPEN&=0xBF
//#define                Enable_BIT5_LowLevel_Trig                        PICON&=0xBF;PINEN|=0x20;PIPEN&=0xDF
//#define                Enable_BIT4_LowLevel_Trig                        PICON&=0xBF;PINEN|=0x10;PIPEN&=0xEF
//#define                Enable_BIT3_LowLevel_Trig                        PICON&=0xDF;PINEN|=0x08;PIPEN&=0xF7
//#define                Enable_BIT2_LowLevel_Trig                        PICON&=0xEF;PINEN|=0x04;PIPEN&=0xFB
//#define                Enable_BIT1_LowLevel_Trig                        PICON&=0xF7;PINEN|=0x02;PIPEN&=0xFD
//#define                Enable_BIT0_LowLevel_Trig                        PICON&=0xFD;PINEN|=0x01;PIPEN&=0xFE
// Enable each bit high level trig mode
//#define                Enable_BIT7_HighLevel_Trig                        PICON&=0x7F;PINEN&=0x7F;PIPEN|=0x80
//#define                Enable_BIT6_HighLevel_Trig                        PICON&=0x7F;PINEN&=0xBF;PIPEN|=0x40
//#define                Enable_BIT5_HighLevel_Trig                        PICON&=0xBF;PINEN&=0xDF;PIPEN|=0x20
//#define                Enable_BIT4_HighLevel_Trig                        PICON&=0xBF;PINEN&=0xEF;PIPEN|=0x10
//#define                Enable_BIT3_HighLevel_Trig                        PICON&=0xDF;PINEN&=0xF7;PIPEN|=0x08
//#define                Enable_BIT2_HighLevel_Trig                        PICON&=0xEF;PINEN&=0xFB;PIPEN|=0x04
//#define                Enable_BIT1_HighLevel_Trig                        PICON&=0xF7;PINEN&=0xFD;PIPEN|=0x02
//#define                Enable_BIT0_HighLevel_Trig                        PICON&=0xFD;PINEN&=0xFE;PIPEN|=0x01
// Enable each bit falling edge trig mode
//#define                Enable_BIT7_FallEdge_Trig                        PICON|=0x80;PINEN|=0x80;PIPEN&=0x7F
//#define                Enable_BIT6_FallEdge_Trig                        PICON|=0x80;PINEN|=0x40;PIPEN&=0xBF
//#define                Enable_BIT5_FallEdge_Trig                        PICON|=0x40;PINEN|=0x20;PIPEN&=0xDF
//#define                Enable_BIT4_FallEdge_Trig                        PICON|=0x40;PINEN|=0x10;PIPEN&=0xEF
//#define                Enable_BIT3_FallEdge_Trig                        PICON|=0x20;PINEN|=0x08;PIPEN&=0xF7
//#define                Enable_BIT2_FallEdge_Trig                        PICON|=0x10;PINEN|=0x04;PIPEN&=0xFB
//#define                Enable_BIT1_FallEdge_Trig                        PICON|=0x08;PINEN|=0x02;PIPEN&=0xFD
//#define                Enable_BIT0_FallEdge_Trig                        PICON|=0x04;PINEN|=0x01;PIPEN&=0xFE
// Enable each bit rasing edge trig mode
//#define                Enable_BIT7_RasingEdge_Trig                        PICON|=0x80;PINEN&=0x7F;PIPEN|=0x80
//#define                Enable_BIT6_RasingEdge_Trig                        PICON|=0x80;PINEN&=0xBF;PIPEN|=0x40
//#define                Enable_BIT5_RasingEdge_Trig                        PICON|=0x40;PINEN&=0xDF;PIPEN|=0x20
//#define                Enable_BIT4_RasingEdge_Trig                        PICON|=0x40;PINEN&=0xEF;PIPEN|=0x10
//#define                Enable_BIT3_RasingEdge_Trig                        PICON|=0x20;PINEN&=0xF7;PIPEN|=0x08
//#define                Enable_BIT2_RasingEdge_Trig                        PICON|=0x10;PINEN&=0xFB;PIPEN|=0x04
//#define                Enable_BIT1_RasingEdge_Trig                        PICON|=0x08;PINEN|=0xFD;PIPEN&=0x02
//#define                Enable_BIT0_RasingEdge_Trig                        PICON|=0x04;PINEN|=0xFE;PIPEN&=0x01
#endif
* FUNCTION_PURPOSE: I/O Pin interrupt Service Routine
void EXT_INT0(void) interrupt 0
                                clr_GPIO1;
                        Timer0_Delay1ms(100);
                        set_GPIO1;
                        clr_GPIO1;
                        set_GPIO1;
                        clr_GPIO1;
                        set_GPIO1;
                        clr_GPIO1;
                        set_GPIO1;
                                clr_GPIO1;
                        set_GPIO1;
                        clr_GPIO1;
                        set_GPIO1;
                        clr_GPIO1;
                        set_GPIO1;
                        clr_GPIO1;
                        set_GPIO1;
void PinInterrupt_ISR (void) interrupt 7
        if(PIF == 0x01)
    PIF = 0x00;                             //clear interrupt flag
                        clr_GPIO1;
                        Timer1_Delay10ms(10);
                        set_GPIO1;
                        clr_GPIO1;
                        set_GPIO1;
        else if (PIF == 0x80)
                        clr_GPIO1;
                        set_GPIO1;
                        clr_GPIO1;
                        set_GPIO1;
                        clr_GPIO1;
                        set_GPIO1;
                        clr_GPIO1;
                        set_GPIO1;
The main C function.  Program execution starts
here after stack initialization.
void main (void)
    P07_Input_Mode;
                set_P0S_7;
                P00_Input_Mode;
                P01_Input_Mode;
                set_P0S_1;
                P12_PushPull_Mode;
                P30_PushPull_Mode;
                P05_PushPull_Mode;
//        P0.5 set as highlevel trig pin interrupt function
//  Keep P0.5 connect to VDD LED will tickle
//  otherwise, MCU into power down mode.
                Enable_INT_Port2;
//                Enable_BIT7_LowLevel_Trig;
                Enable_BIT0_LowLevel_Trig;
                P30 =1;
                P05 = 0;
    set_EPI;                                                        // Enable pin interrupt
                set_EX0;
    set_EA;        // global enable bit
    while(1)
                        P01=0;
                        P30=0;
                        P01=1;
                        P30=1;
yiy| | 2018-5-7 22:11 | 只看该作者
看上面的例子,PIN中断就是这个其他端口的中断。
yjgna| | 2018-5-9 09:23 | 只看该作者
每个IO口都可以作为中断, 但是同一时刻,只能开启一个端口.
dongnanxibei| | 2018-5-9 11:05 | 只看该作者
除了这两个外,其他的是共用中断源的, 中断发生后,进去判断识别是哪个端口的中断。
huangcunxiake| | 2018-5-9 23:48 | 只看该作者
你需要几个,这个芯片好像是20PIN,起码你可以用14个。
yiyigirl2014| | 2018-5-9 23:52 | 只看该作者
16个管脚都可以吧。
xinpian101| | 2018-5-11 18:33 | 只看该作者
一般应用的IO中断是够了。要求相应快,独立操作的,你可以用你说的那两个。
yiy| | 2018-5-11 23:31 | 只看该作者
好像是可以作为IO的都可以。应该是一共4个中断向量。你说的那两个各自占用一个。
xuanhuanzi| | 2018-5-12 11:04 | 只看该作者
玩起来没,你需要几个中断接口。
