[应用相关]
Azure IOT开发问题
950|7
kuais|  楼主 | 2018-5-7 17:00 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
最近我们公司买了P-NUCLEO-CLD1开发套件,并且下载了FP-CLD-AZURE1软件包。之后我们运行FP-CLD-AZURE1软件包里的范例却发现总是无法运行下去。请贵方帮我们解决这个问题.(未对源码做任何更改,只是配置了wifi参数和Azure连接字符串)。
日志如下:
UART Initialized
I2C  Initialized
STMicroelectronics Azure_DM:
        Version 3.2.2
        STM32F401RE-Nucleo board
        Azure SDK Version 1.1.16
IKS01A2 board
Ok Accelero Sensor
Ok Gyroscope Sensor
Ok Magneto Sensor
Ok Humidity Sensor
Ok Temperature Sensor1
Ok Temperature Sensor2
Ok Pressure Sensor
Enabled Accelero Sensor
Enabled Gyroscope Sensor
Enabled Magneto Sensor
Enabled Humidity Sensor
Enabled Temperature Sensor1
Enabled Temperature Sensor2
Enabled Pressure Sensor
        (HAL 1.7.1_0)
        Compiled Jan 19 2018 14:36:06 (KEIL)
Init Application's Timers
Init Random Number Generator
Enabled Free Fall
X-NUCLEO-NFC01A1 is present
Init WIFI's Timers
Init WIFI's UART1
|    WIFI Credential     |
Meta Data Manager read from Flash
Meta Data Manager version=0.8.0
        Generic Meta Data found:
                 WIFI Size=81 [bytes]
                 AZURE Size=256 [bytes]
        Saved SSID   : hldjsb
        Saved PassWd : jsb123456
        Saved EncMode: WPA2/WPA2-Personal
Wait 3 seconds for allowing User Button Control for changing it
|   Connection String    |
        Saved Connection String :
                HostName=AzureTest1.azure-devices.cn;DeviceId=1001;SharedAccessK
                          ey=x+Ekp67UrDAKM6YPnIGXoGoLd0P7BpTZCFmIth1G578=
wifi started and ready...
WIFI module Configured
WiFi MAC Address is: 00:80:E1:B9:78:BE
WiFi connected to AccessPoint
Init Real Time Clock 05-07-2018 06:19:50
Platform Init Done
Serializer Initialized
iotHubClientHandle Created
iotHubClientSetOption logtrace Ok
Model Instance Created
IoTHubClient_LL_SetMessageCallback...successful.
IoTHubClient_LL_SetDeviceMethodCallback...successful.
IoTHubClient_LL_SetOption(certificates)...successful.
IoTHubClient_LL_SetDeviceTwinCallback...successful.
WIFI closed =0
mmuuss586| | 2018-5-7 22:22 | 只看该作者
没买过这个套件,找谁买的,找他们技术支持就可以了;
代理商都有技术支持的
kuais|  楼主 | 2018-5-9 08:33 | 只看该作者
代理商都有技术支持的 ...
谢谢,代理商那边也发邮件了,不过现在还没回音,希望在这边也能得到一些指引
七颗咖啡豆| | 2018-5-9 11:49 | 只看该作者
发什么邮件管什么用,慢的死,作死的打电话
joketinnle| | 2018-5-9 13:56 | 只看该作者
和代理商 通電話把  我記得Azure的服務態度還蠻不錯的
xinpian101| | 2018-5-10 11:59 | 只看该作者
是下载不进去?先试试点灯。
icecut| | 2018-5-10 12:59 | 只看该作者
lz就不知道把你wifi密码不发帖子里???
ping AzureTest1.azure-devices.cn
据我验证,这个网站已被qiang...国内连不上.
zhuotuzi| | 2018-5-12 09:33 | 只看该作者
你买的国外的板子就不好讲了。
