[UNO] AD8232心率脉搏传感器的arduino程序
1273|2
 楼主 | 2018-5-7 22:16 | 显示全部楼层 |阅读模式
各位大佬,请问AD8232心率脉搏传感器的arduino程序怎么写呀
| 2018-5-23 12:28 | 显示全部楼层
Heart_Rate_Display.ino
Demo Program for AD8232 Heart Rate sensor.
Casey Kuhns @ SparkFun Electronics
6/27/2014
https://github.com/sparkfun/AD8232_Heart_Rate_Monitor
The AD8232 Heart Rate sensor is a low cost EKG/ECG sensor.  This example shows
how to create an ECG with real time display.  The display is using Processing.
This sketch is based heavily on the Graphing Tutorial provided in the Arduino
IDE. http://www.arduino.cc/en/Tutorial/Graph
Resources:
This program requires a Processing sketch to view the data in real time.
Development environment specifics:
        IDE: Arduino 1.0.5
        Hardware Platform: Arduino Pro 3.3V/8MHz
        AD8232 Heart Monitor Version: 1.0
This code is beerware. If you see me (or any other SparkFun employee) at the
local pub, and you've found our code helpful, please buy us a round!
Distributed as-is; no warranty is given.
void setup() {
  // initialize the serial communication:
  Serial.begin(9600);
  pinMode(10, INPUT); // Setup for leads off detection LO +
  pinMode(11, INPUT); // Setup for leads off detection LO -
void loop() {
  if((digitalRead(10) == 1)||(digitalRead(11) == 1)){
    Serial.println('!');
  else{
    // send the value of analog input 0:
      Serial.println(analogRead(A0));
  //Wait for a bit to keep serial data from saturating
  delay(20);
使用道具
扫描二维码,随时随地手机跟帖
我要发帖 投诉建议 创建版块 申请版主
快速回复
您需要登录后才可以回帖
登录 | 注册
高级模式
论坛热帖
热门推荐上一条 /5 下一条
快速回复 返回顶部 返回列表
