EK-TM4C123G 串口UART0-UART7串口小练阻塞方式
1719|10
看到有人最基本的串口环境都搭不起来,基于EK-TM4C123G的开发板,抽空写了UART0-UART7串口阻塞方式发送的基本例程,仅供大家参考。
EK-TM4C123G占用串口IO的资源如下所示:
dirtwillfly 2018-5-31 09:50 回复TA
一言不合就分享,点个赞
xyz549040622|  楼主 | 2018-5-31 08:43 | 只看该作者
串口0的例程,没有使用第三方的库
#include <stdint.h>
#include <stdbool.h>
#include "inc/hw_memmap.h"
#include "inc/hw_types.h"
#include "driverlib/debug.h"
#include "driverlib/gpio.h"
#include "driverlib/fpu.h"
#include "driverlib/pin_map.h"
#include "driverlib/sysctl.h"
#include "driverlib/systick.h"
#include "driverlib/rom.h"
#include "driverlib/uart.h"
#include "utils/uartstdio.h"
//! \addtogroup example_list
//! <h1>Bit-Banding (bitband)</h1>
//! This example application demonstrates the use of the bit-banding
//! capabilities of the Cortex-M4F microprocessor.  All of SRAM and all of the
//! peripherals reside within bit-band regions, meaning that bit-banding
//! operations can be applied to any of them.  In this example, a variable in
//! SRAM is set to a particular value one bit at a time using bit-banding
//! operations (it would be more efficient to do a single non-bit-banded write;
//! this simply demonstrates the operation of bit-banding).
// The value that is to be modified via bit-banding.
static volatile uint32_t g_ui32Value;
// The error routine that is called if the driver library encounters an error.
#ifdef DEBUG
void
__error__(char *pcFilename, uint32_t ui32Line)
    while(1)
        // Hang on runtime error.
#endif
// Configure the UART and its pins.  This must be called before UARTprintf().
void
ConfigureUART(void)
    // Enable the GPIO Peripheral used by the UART.
    ROM_SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOA);
    // Enable UART0
    ROM_SysCtlPeripheralEnable(SYSCTL_PERIPH_UART0);
    // Configure GPIO Pins for UART mode.
    ROM_GPIOPinConfigure(GPIO_PA0_U0RX);
    ROM_GPIOPinConfigure(GPIO_PA1_U0TX);
    ROM_GPIOPinTypeUART(GPIO_PORTA_BASE, GPIO_PIN_0 | GPIO_PIN_1);
    // Use the internal 16MHz oscillator as the UART clock source.
    UARTClockSourceSet(UART0_BASE, UART_CLOCK_PIOSC);
    UARTConfigSetExpClk(UART0_BASE,16000000,115200,UART_CONFIG_PAR_NONE|UART_CONFIG_STOP_ONE|UART_CONFIG_WLEN_8);
    UARTEnable(UART0_BASE);
// This example demonstrates the use of bit-banding to set individual bits
// within a word of SRAM.
int
main(void)
    // Set the clocking to run directly from the crystal.
    ROM_SysCtlClockSet(SYSCTL_SYSDIV_1 | SYSCTL_USE_OSC | SYSCTL_OSC_MAIN |
                       SYSCTL_XTAL_16MHZ);
    // Initialize the UART interface.
    ConfigureUART();
    // Loop forever.
    while(1)
        UARTCharPut(UART0_BASE,0xAA);
xyz549040622|  楼主 | 2018-5-31 08:44 | 只看该作者
串口0的例程,使用第三方的库
#include <stdint.h>
#ifdef DEBUG
void
    while(1)
#endif
void
ConfigureUART(void)
    // Enable UART0
    // Initialize the UART for console I/O.
    UARTStdioConfig(0, 115200, 16000000);
int
main(void)
                       SYSCTL_XTAL_16MHZ);
    ConfigureUART();
    UARTprintf("Hello this is TM4C123H6PM USART0!\n");
    UARTprintf("USART0 by stdio.h!\n");
    // Loop forever.
    while(1)
xyz549040622|  楼主 | 2018-5-31 08:45 | 只看该作者
串口1的例程,使用的是PB0和PB1引脚
// bitband.c - Bit-band manipulation example.
// Copyright (c) 2012-2017 Texas Instruments Incorporated.  All rights reserved.
// Software License Agreement
// Texas Instruments (TI) is supplying this software for use solely and
// exclusively on TI's microcontroller products. The software is owned by
// TI and/or its suppliers, and is protected under applicable copyright
// laws. You may not combine this software with "viral" open-source
// software in order to form a larger program.
// THIS SOFTWARE IS PROVIDED "AS IS" AND WITH ALL FAULTS.
// NO WARRANTIES, WHETHER EXPRESS, IMPLIED OR STATUTORY, INCLUDING, BUT
// NOT LIMITED TO, IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
// A PARTICULAR PURPOSE APPLY TO THIS SOFTWARE. TI SHALL NOT, UNDER ANY
// CIRCUMSTANCES, BE LIABLE FOR SPECIAL, INCIDENTAL, OR CONSEQUENTIAL
// DAMAGES, FOR ANY REASON WHATSOEVER.
// This is part of revision 2.1.4.178 of the EK-TM4C123GXL Firmware Package.
#include <stdint.h>
#ifdef DEBUG
void
    while(1)
#endif
void
ConfigureUART(void)
    // Enable GPIOC
    ROM_SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOB);
    while(!(SysCtlPeripheralReady(SYSCTL_PERIPH_GPIOB)));
    // Enable UART1
    ROM_SysCtlPeripheralEnable(SYSCTL_PERIPH_UART1);
    while(!(SysCtlPeripheralReady(SYSCTL_PERIPH_UART1)));
    ROM_GPIOPinConfigure(GPIO_PB0_U1RX);
    ROM_GPIOPinConfigure(GPIO_PB1_U1TX);
    ROM_GPIOPinTypeUART(GPIO_PORTB_BASE, GPIO_PIN_0 | GPIO_PIN_1);
    UARTClockSourceSet(UART1_BASE, UART_CLOCK_PIOSC);
    UARTConfigSetExpClk(UART1_BASE,16000000,115200,UART_CONFIG_PAR_NONE|UART_CONFIG_STOP_ONE|UART_CONFIG_WLEN_8);
    UARTEnable(UART1_BASE);
int
main(void)
                       SYSCTL_XTAL_16MHZ);
    ConfigureUART();
    // Loop forever.
    while(1)
        UARTCharPut(UART1_BASE,0xAA);
xyz549040622|  楼主 | 2018-5-31 08:47 | 只看该作者
串口1的例程,使用的是PC4、PC5
#include <stdint.h>
#ifdef DEBUG
void
    while(1)
#endif
void
ConfigureUART(void)
    // Enable GPIOC
    ROM_SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOC);
    while(!(SysCtlPeripheralReady(SYSCTL_PERIPH_GPIOC)));
    // Enable UART1
    ROM_GPIOPinConfigure(GPIO_PC4_U1RX);
    ROM_GPIOPinConfigure(GPIO_PC5_U1TX);
    ROM_GPIOPinTypeUART(GPIO_PORTC_BASE, GPIO_PIN_4 | GPIO_PIN_5);
int
main(void)
                       SYSCTL_XTAL_16MHZ);
    ConfigureUART();
    // Loop forever.
    while(1)
xyz549040622|  楼主 | 2018-5-31 08:48 | 只看该作者
串口2的例程,没有使用第三方的库
#include <stdint.h>
#include "inc/hw_gpio.h"
#ifdef DEBUG
void
    while(1)
#endif
void
ConfigureUART(void)
    // Enable GPIOC
    ROM_SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOD);
    while(!(SysCtlPeripheralReady(SYSCTL_PERIPH_GPIOD)));
    // Enable UART1
    ROM_SysCtlPeripheralEnable(SYSCTL_PERIPH_UART2);
    while(!(SysCtlPeripheralReady(SYSCTL_PERIPH_UART2)));
        //ulock PD7
    HWREG(GPIO_PORTD_BASE + GPIO_O_LOCK) = GPIO_LOCK_KEY;
    HWREG(GPIO_PORTD_BASE + GPIO_O_CR) = 0xFF;
    ROM_GPIOPinConfigure(GPIO_PD6_U2RX);
    ROM_GPIOPinConfigure(GPIO_PD7_U2TX);
    ROM_GPIOPinTypeUART(GPIO_PORTD_BASE, GPIO_PIN_6 | GPIO_PIN_7);
    UARTClockSourceSet(UART2_BASE, UART_CLOCK_PIOSC);
    UARTConfigSetExpClk(UART2_BASE,16000000,115200,UART_CONFIG_PAR_NONE|UART_CONFIG_STOP_ONE|UART_CONFIG_WLEN_8);
    UARTEnable(UART2_BASE);
int
main(void)
                       SYSCTL_XTAL_16MHZ);
    ConfigureUART();
    // Loop forever.
    while(1)
        UARTCharPut(UART2_BASE,0xAA);
xyz549040622|  楼主 | 2018-5-31 08:49 | 只看该作者
串口2的例程,使用第三方的库
#include <stdint.h>
#ifdef DEBUG
void
    while(1)
#endif
void
ConfigureUART2(void)
    // Enable GPIOC
    // Enable UART1
        //ulock PD7
    UARTStdioConfig(2, 115200, 16000000);
int
main(void)
                       SYSCTL_XTAL_16MHZ);
    ConfigureUART2();
    UARTprintf("Hello this is TM4C123H6PM USART2!\n");
    UARTprintf("USART2 by stdio.h!\n");
    // Loop forever.
    while(1)
xyz549040622|  楼主 | 2018-5-31 09:01 | 只看该作者
串口3、串口4、串口5、串口7
#include <stdint.h>
#ifdef DEBUG
void
    while(1)
#endif
//void
//ConfigureUART3(void)
//    // Enable GPIOC
//    ROM_SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOC);
//    while(!(SysCtlPeripheralReady(SYSCTL_PERIPH_GPIOC)));
//    // Enable UART1
//    ROM_SysCtlPeripheralEnable(SYSCTL_PERIPH_UART3);
//    while(!(SysCtlPeripheralReady(SYSCTL_PERIPH_UART3)));
//    // Configure GPIO Pins for UART mode.
//    ROM_GPIOPinConfigure(GPIO_PC6_U3RX);
//    ROM_GPIOPinConfigure(GPIO_PC7_U3TX);
//    ROM_GPIOPinTypeUART(GPIO_PORTC_BASE, GPIO_PIN_6 | GPIO_PIN_7);
//    // Use the internal 16MHz oscillator as the UART clock source.
//    UARTClockSourceSet(UART3_BASE, UART_CLOCK_PIOSC);
//    UARTConfigSetExpClk(UART3_BASE,16000000,115200,UART_CONFIG_PAR_NONE|UART_CONFIG_STOP_ONE|UART_CONFIG_WLEN_8);
//    UARTEnable(UART3_BASE);
//void
//ConfigureUART4(void)
//    // Enable GPIOC
//    // Enable UART1
//    ROM_SysCtlPeripheralEnable(SYSCTL_PERIPH_UART4);
//    while(!(SysCtlPeripheralReady(SYSCTL_PERIPH_UART4)));
//    ROM_GPIOPinConfigure(GPIO_PC4_U4RX);
//    ROM_GPIOPinConfigure(GPIO_PC5_U4TX);
//    ROM_GPIOPinTypeUART(GPIO_PORTC_BASE, GPIO_PIN_4 | GPIO_PIN_5);
//    UARTClockSourceSet(UART4_BASE, UART_CLOCK_PIOSC);
//    UARTConfigSetExpClk(UART4_BASE,16000000,115200,UART_CONFIG_PAR_NONE|UART_CONFIG_STOP_ONE|UART_CONFIG_WLEN_8);
//    UARTEnable(UART4_BASE);
//void
//ConfigureUART5(void)
//    // Enable GPIOC
//    ROM_SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOE);
//    while(!(SysCtlPeripheralReady(SYSCTL_PERIPH_GPIOE)));
//    // Enable UART1
//    ROM_SysCtlPeripheralEnable(SYSCTL_PERIPH_UART5);
//    while(!(SysCtlPeripheralReady(SYSCTL_PERIPH_UART5)));
//    ROM_GPIOPinConfigure(GPIO_PE4_U5RX);
//    ROM_GPIOPinConfigure(GPIO_PE5_U5TX);
//    ROM_GPIOPinTypeUART(GPIO_PORTE_BASE, GPIO_PIN_4 | GPIO_PIN_5);
//    UARTClockSourceSet(UART5_BASE, UART_CLOCK_PIOSC);
//    UARTConfigSetExpClk(UART5_BASE,16000000,115200,UART_CONFIG_PAR_NONE|UART_CONFIG_STOP_ONE|UART_CONFIG_WLEN_8);
//    UARTEnable(UART5_BASE);
void
ConfigureUART7(void)
    // Enable GPIOC
    // Enable UART1
    ROM_SysCtlPeripheralEnable(SYSCTL_PERIPH_UART7);
    while(!(SysCtlPeripheralReady(SYSCTL_PERIPH_UART7)));
    ROM_GPIOPinConfigure(GPIO_PE0_U7RX);
    ROM_GPIOPinConfigure(GPIO_PE1_U7TX);
    ROM_GPIOPinTypeUART(GPIO_PORTE_BASE, GPIO_PIN_0 | GPIO_PIN_1);
    UARTClockSourceSet(UART7_BASE, UART_CLOCK_PIOSC);
    UARTConfigSetExpClk(UART7_BASE,16000000,115200,UART_CONFIG_PAR_NONE|UART_CONFIG_STOP_ONE|UART_CONFIG_WLEN_8);
    UARTEnable(UART7_BASE);
int
main(void)
                       SYSCTL_XTAL_16MHZ);
    ConfigureUART7();
    // Loop forever.
    while(1)
        UARTCharPut(UART7_BASE,0xAA);
dirtwillfly| | 2018-5-31 09:50 | 只看该作者
hellosdc| | 2018-6-3 16:49 | 只看该作者
跟着学习了。
个人签名:qq群: 嵌入式系统arm初学者 224636155←← +→→点击-->小 i 精品课全集,21ic公开课~~←←→→点击-->小 i 精品课全集,给你全方位的技能策划~~←←
2673
