[STM32L4]
帮忙看下,唤醒后就不能再次进入stop1模式了
1964|4
pegion1001|  楼主 | 2018-6-12 11:50 | 显示全部楼层 |阅读模式
ST, top, rc, ni, tc
  * File Name          : main.c
  * Description        : Main program body
/* Includes ------------------------------------------------------------------*/
#include "main.h"
#include "stm32l4xx_hal.h"
/* Private variables ---------------------------------------------------------*/
RTC_HandleTypeDef hrtc;
/* Private function prototypes -----------------------------------------------*/
void SystemClock_Config(void);
static void MX_GPIO_Init(void);
static void MX_RTC_Init(void);
/* USER CODE BEGIN PFP */
static void SYSCLKConfig_STOP(void);
/* USER CODE END PFP */
int main(void)
  /* MCU Configuration----------------------------------------------------------*/
  /* Reset of all peripherals, Initializes the Flash interface and the Systick. */
  HAL_Init();
  SystemClock_Config();
  MX_GPIO_Init();
  MX_RTC_Init();
  /* USER CODE BEGIN 2 */
  /* Enable Power Clock */
  __HAL_RCC_PWR_CLK_ENABLE();
  /* Ensure that MSI is wake-up system clock */
  __HAL_RCC_WAKEUPSTOP_CLK_CONFIG(RCC_STOP_WAKEUPCLOCK_HSI);
  /* USER CODE END 2 */
  /* Infinite loop */
  /* USER CODE BEGIN WHILE */
  while (1)
  /* USER CODE END WHILE */
        HAL_Delay(2000);
  /* USER CODE BEGIN 3 */
/* Disable all used wakeup source */
    HAL_RTCEx_DeactivateWakeUpTimer(&hrtc);
    HAL_RTCEx_SetWakeUpTimer_IT(&hrtc, 5, RTC_WAKEUPCLOCK_CK_SPRE_16BITS);
    /* Enter STOP 1 mode */
    HAL_PWREx_EnterSTOP1Mode(PWR_STOPENTRY_WFI);
    /* ... STOP 1 mode ... */
   SYSCLKConfig_STOP();
   HAL_GPIO_WritePin(RS232CTRL_GPIO_Port, RS232CTRL_Pin, GPIO_PIN_SET);
   HAL_Delay(1000);
   HAL_GPIO_WritePin(RS232CTRL_GPIO_Port, RS232CTRL_Pin, GPIO_PIN_RESET);
  /* USER CODE END 3 */
/** System Clock Configuration
  RCC_OscInitTypeDef RCC_OscInitStruct;
  RCC_ClkInitTypeDef RCC_ClkInitStruct;
  RCC_PeriphCLKInitTypeDef PeriphClkInit;
    /**Initializes the CPU, AHB and APB busses clocks    */
  RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSI|RCC_OSCILLATORTYPE_LSE;
  RCC_OscInitStruct.LSEState = RCC_LSE_BYPASS;
  RCC_OscInitStruct.HSIState = RCC_HSI_ON;
  RCC_OscInitStruct.HSICalibrationValue = 16;
  RCC_OscInitStruct.PLL.PLLState = RCC_PLL_NONE;
  if (HAL_RCC_OscConfig(&RCC_OscInitStruct) != HAL_OK)
    _Error_Handler(__FILE__, __LINE__);
  RCC_ClkInitStruct.ClockType = RCC_CLOCKTYPE_HCLK|RCC_CLOCKTYPE_SYSCLK
                              |RCC_CLOCKTYPE_PCLK1|RCC_CLOCKTYPE_PCLK2;
  RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_HSI;
  RCC_ClkInitStruct.AHBCLKDivider = RCC_SYSCLK_DIV1;
  RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV1;
  RCC_ClkInitStruct.APB2CLKDivider = RCC_HCLK_DIV1;
  if (HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_0) != HAL_OK)
  PeriphClkInit.PeriphClockSelection = RCC_PERIPHCLK_RTC;
  PeriphClkInit.RTCClockSelection = RCC_RTCCLKSOURCE_LSE;
  if (HAL_RCCEx_PeriphCLKConfig(&PeriphClkInit) != HAL_OK)
    /**Configure the main internal regulator output voltage     */
  if (HAL_PWREx_ControlVoltageScaling(PWR_REGULATOR_VOLTAGE_SCALE1) != HAL_OK)
    /**Configure the Systick interrupt time     */
  HAL_SYSTICK_Config(HAL_RCC_GetHCLKFreq()/1000);
    /**Configure the Systick     */
  HAL_SYSTICK_CLKSourceConfig(SYSTICK_CLKSOURCE_HCLK);
  /* SysTick_IRQn interrupt configuration */
  HAL_NVIC_SetPriority(SysTick_IRQn, 0, 0);
/* RTC init function */
  RTC_TimeTypeDef sTime;
  RTC_DateTypeDef sDate;
    /**Initialize RTC Only     */
  hrtc.Instance = RTC;
  hrtc.Init.HourFormat = RTC_HOURFORMAT_24;
  hrtc.Init.AsynchPrediv = 127;
  hrtc.Init.SynchPrediv = 255;
  hrtc.Init.OutPut = RTC_OUTPUT_DISABLE;
  hrtc.Init.OutPutRemap = RTC_OUTPUT_REMAP_NONE;
  hrtc.Init.OutPutPolarity = RTC_OUTPUT_POLARITY_HIGH;
  hrtc.Init.OutPutType = RTC_OUTPUT_TYPE_OPENDRAIN;
  if (HAL_RTC_Init(&hrtc) != HAL_OK)
    /**Initialize RTC and set the Time and Date     */
  if(HAL_RTCEx_BKUPRead(&hrtc, RTC_BKP_DR0) != 0x32F2){
  sTime.Hours = 0x0;
  sTime.Minutes = 0x0;
  sTime.Seconds = 0x0;
  sTime.DayLightSaving = RTC_DAYLIGHTSAVING_NONE;
  sTime.StoreOperation = RTC_STOREOPERATION_RESET;
  if (HAL_RTC_SetTime(&hrtc, &sTime, RTC_FORMAT_BCD) != HAL_OK)
  sDate.WeekDay = RTC_WEEKDAY_MONDAY;
  sDate.Month = RTC_MONTH_JANUARY;
  sDate.Date = 0x1;
  sDate.Year = 0x0;
  if (HAL_RTC_SetDate(&hrtc, &sDate, RTC_FORMAT_BCD) != HAL_OK)
    HAL_RTCEx_BKUPWrite(&hrtc,RTC_BKP_DR0,0x32F2);
    /**Enable the WakeUp     */
  if (HAL_RTCEx_SetWakeUpTimer(&hrtc, 0, RTC_WAKEUPCLOCK_RTCCLK_DIV16) != HAL_OK)
/** Configure pins as
        * Analog
        * Input
        * Output
        * EVENT_OUT
        * EXTI
  GPIO_InitTypeDef GPIO_InitStruct;
  /* GPIO Ports Clock Enable */
  __HAL_RCC_GPIOC_CLK_ENABLE();
  __HAL_RCC_GPIOA_CLK_ENABLE();
  /*Configure GPIO pin Output Level */
  /*Configure GPIO pin : RS232CTRL_Pin */
  GPIO_InitStruct.Pin = RS232CTRL_Pin;
  GPIO_InitStruct.Mode = GPIO_MODE_OUTPUT_PP;
  GPIO_InitStruct.Pull = GPIO_NOPULL;
  GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_LOW;
  HAL_GPIO_Init(RS232CTRL_GPIO_Port, &GPIO_InitStruct);
/* USER CODE BEGIN 4 */
  RCC_ClkInitTypeDef RCC_ClkInitStruct = {0};
  RCC_OscInitTypeDef RCC_OscInitStruct = {0};
  uint32_t pFLatency = 0;
  /* Enable Power Control clock */
  /* Get the Oscillators configuration according to the internal RCC registers */
  HAL_RCC_GetOscConfig(&RCC_OscInitStruct);
    Error_Handler();
  /* Get the Clocks configuration according to the internal RCC registers */
  HAL_RCC_GetClockConfig(&RCC_ClkInitStruct, &pFLatency);
  if (HAL_RCC_ClockConfig(&RCC_ClkInitStruct, pFLatency) != HAL_OK)
    Error_Handler();
/* USER CODE END 4 */
  * @brief  This function is executed in case of error occurrence.
  * @param  None
  * @retval None
void _Error_Handler(char * file, int line)
  /* USER CODE BEGIN Error_Handler_Debug */
  /* User can add his own implementation to report the HAL error return state */
  while(1)
  /* USER CODE END Error_Handler_Debug */
#ifdef USE_FULL_ASSERT
   * @brief Reports the name of the source file and the source line number
   * where the assert_param error has occurred.
   * @param file: pointer to the source file name
   * @param line: assert_param error line source number
   * @retval None
void assert_failed(uint8_t* file, uint32_t line)
  /* USER CODE BEGIN 6 */
  /* User can add his own implementation to report the file name and line number,
    ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
  /* USER CODE END 6 */
#endif
/************************ (C) COPYRIGHT STMicroelectronics *****END OF FILE****/
上来运行的时候可以进入stop1模式,但是唤醒后就一直进不去了,怎么回事?唤醒后还需要做什么工作吗?系统时钟已经恢复了呀
zhuotuzi| | 2018-6-13 14:55 | 显示全部楼层
可能需要重新初始化这个功能
香水城| | 2018-6-13 16:38 | 显示全部楼层
看看是否有没有清除的中断请求位未被清零。
紫宸星光| | 2018-6-13 21:16 | 显示全部楼层
清一下PWR_FLAG_WU试试,唤醒之后要清一下这个标志位,不然容易不醒或者醒了睡不下去
pegion1001|  楼主 | 2018-6-14 16:21 | 显示全部楼层
在唤醒后加入__HAL_RTC_WAKEUPTIMER_CLEAR_FLAG(&hrtc, RTC_FLAG_WUTF);情况一样
而且这句在HAL_RTCEx_SetWakeUpTimer_IT函数里调用过了
