[嵌入式linux] nfs挂载linaro-ubuntu,启动导最后卡住了
674|1
 楼主 | 2018-6-12 15:22 | 显示全部楼层 |阅读模式
SD卡可正常启动,如下:
  1. EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
  2. VFS: Mounted root (ext4 filesystem) on device 179:1.
  3. devtmpfs: mounted
  4. Freeing unused kernel memory: 220K (80797000 - 807ce000)
  5. init: ureadahead main process (183) terminated with status 5
  6. init: mounted-proc main process (190) terminated with status 1
  7. * Starting configure network device security                            [ OK ]
  8. * Starting configure network device                                     [ OK ]
  9. * Starting network connection manager                                   [ OK ]
  10. * Starting configure network device security                            [ OK ]
  11. * Starting Mount network filesystems                                    [ OK ]
  12. * Starting Upstart job to start rpcbind on boot only                    [ OK ]
  13. * Starting Failsafe Boot Delay                                          [ OK ]
  14. * Stopping Upstart job to start rpcbind on boot only                    [ OK ]
  15. * Stopping Mount network filesystems                                    [ OK ]
  16. * Starting Bridge socket events into upstart                            [ OK ]
  17. * Starting RPC portmapper replacement                                   [ OK ]
  18. * Starting configure network device                                     [ OK ]
  19. * Stopping Failsafe Boot Delay                                          [ OK ]
  20. * Starting System V initialisation compatibility                        [ OK ]
  21. * Starting set sysctls from /etc/sysctl.conf                            [ OK ]
  22. * Starting NSM status monitor                                           [ OK ]
  23. * Stopping set sysctls from /etc/sysctl.conf                            [ OK ]
  24. * Stopping cold plug devices                                            [ OK ]
  25. * Stopping log initial device creation                                  [ OK ]
  26. * Starting configure network device security                            [ OK ]
  27. * Starting save udev log and update rules                               [ OK ]
  28. * Starting configure virtual network devices                            [ OK ]
  29. * Stopping configure virtual network devices                            [ OK ]
  30. * Stopping save udev log and update rules                               [ OK ]
  31. * Setting up X socket directories...                                    [ OK ]
  32. * Stopping System V initialisation compatibility                        [ OK ]
  33. * Starting System V runlevel compatibility                              [ OK ]
  34. * Starting LightDM Display Manager                                      [ OK ]
  35. * Starting save kernel messages                                         [ OK ]
  36. * Starting anac(h)ronistic cron                                         [ OK ]
  37. * Starting regular background program processing daemon                 [ OK ]
  38. Last login: Mon Jun 11 17:52:04 UTC 2018 on tty1
  39. root@linaro-alip:~#
  40. root@linaro-alip:~#
复制代码
然后我把这个SD卡的根文件系统复制到pc上(保留了文件的属主和权限);然后在嵌入式平台上用NFS挂载该根文件系统,显示挂载成功了,但是启动到最后却卡住了,如下:
  1. rtc-pcf8563 1-0051: low voltage detected, date/time is not reliable.
  2. rtc-pcf8563 1-0051: setting system clock to 2018-06-12 11:21:47 UTC (1528802507)
  3. fec 2188000.ethernet eth0: Freescale FEC PHY driver [Atheros 8035 ethernet] (mii_bus:phy_addr=2188000.ethernet:06, irq=-1)
  4. libphy: 2188000.ethernet:06 - Link is Up - 100/Full
  5. Sending DHCP requests ., OK
  6. IP-Config: Got DHCP answer from 10.100.50.1, my address is 10.100.50.127
  7. IP-Config: Complete:
  8.      device=eth0, hwaddr=b2:cb:c5:14:d3:07, ipaddr=10.100.50.127, mask=255.255.255.0, gw=10.100.50.1
  9.      host=10.100.50.127, domain=, nis-domain=(none)
  10.      bootserver=0.0.0.0, rootserver=10.100.50.233, rootpath=
  11.      nameserver0=10.100.10.2
  12. ALSA device list:
  13.   No soundcards found.
  14. VFS: Mounted root (nfs filesystem) on device 0:11.
  15. devtmpfs: mounted
  16. Freeing unused kernel memory: 220K (80797000 - 807ce000)
  17. init: ureadahead main process (180) terminated with status 5
  18. init: mounted-proc main process (187) terminated with status 1
  19. * Starting configure network device security                            [ OK ]
  20. * Starting configure network device                                     [ OK ]
  21. * Starting configure network device security                            [ OK ]
  22. * Starting network connection manager                                   [ OK ]
  23. * Starting Mount network filesystems                                    [ OK ]
  24. * Starting Upstart job to start rpcbind on boot only                    [ OK ]
  25. * Starting Failsafe Boot Delay                                          [ OK ]
  26. * Stopping Upstart job to start rpcbind on boot only                    [ OK ]
  27. * Stopping Mount network filesystems                                    [ OK ]
  28. * Starting Bridge socket events into upstart                            [ OK ]
  29. * Stopping cold plug devices                                            [ OK ]
  30. * Stopping log initial device creation                                  [ OK ]
  31. * Starting configure network device security                            [ OK ]
  32. * Starting save udev log and update rules                               [ OK ]
  33. * Starting RPC portmapper replacement                                   [ OK ]
  34. * Starting configure virtual network devices                            [ OK ]
  35. * Starting configure network device                                     [ OK ]
  36. * Stopping Failsafe Boot Delay                                          [ OK ]
  37. * Stopping configure virtual network devices                            [ OK ]
  38. * Starting System V initialisation compatibility                        [ OK ]
  39. * Starting set sysctls from /etc/sysctl.conf                            [ OK ]
  40. * Stopping save udev log and update rules                               [ OK ]
  41. * Stopping set sysctls from /etc/sysctl.conf                            [ OK ]
  42. * Starting NSM status monitor                                           [ OK ]
复制代码
一直找不到原因,大侠们帮忙看看,谢谢!
 楼主 | 2018-6-12 16:18 | 显示全部楼层
大侠们,给点建议
使用道具
扫描二维码,随时随地手机跟帖
我要发帖 投诉建议 创建版块 申请版主
快速回复
您需要登录后才可以回帖
登录 | 注册
高级模式
论坛热帖
热门推荐上一条 /5 下一条
快速回复 返回顶部 返回列表
