使用毫米波雷达传感器的交通监控物体检测与跟踪参考设计
1012|5
dirtwillfly|  楼主 | 2018-6-23 17:09 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
描述
The TIDEP-0090 reference design demonstrates how TI single-chip millimeter-wave (mmWave) technology can be used for robust, long-range sensing in traffic monitoring and other applications. The reference design uses the IWR1642BOOST evaluation module (EVM) and integrates a complete radar processing chain onto the IWR1642 device. The processing chain includes the analog radar configuration, analog-to-digital converter (ADC) capture, low-level FFT processing, and high-level clustering and tracking algorithms. This reference design is intended to be built on top of the TI mmWave software development kit (SDK) for a cohesive software experience that includes APIs, libraries and tools for evaluation, development, and data visualization.
特性
  • Demonstration of environmentally robust object detection, clustering, and tracking using TI single-chip mmWave sensor IWR1642
  • IWR1642 mmWave sensor pinpoints location of objects over a range of 70m for multi-lane monitoring and 195m for single-lane monitoring
  • Measurement bandwidth of 76 GHz to 77 GHz
  • IWR1642 with integrated digital signal processor (DSP) to cluster objects and track their range and velocity over time
  • Based on proven EVM hardware designs enabling quick time to market and out of the box
dirtwillfly|  楼主 | 2018-6-23 17:19 | 只看该作者
用户指南
IWR1642 EVM (IWR1642BOOST) Single-Chip mmWave Sensing Solution User's Guide.pdf (3.79 MB)
使用单芯片毫米波雷达传感器的交通监控物体检测与跟踪参考设 计.pdf.pdf (7.45 MB)
使用单芯片毫米波雷达传感器的交通监控物体检测与跟踪参考设 计 (Rev. A).pdf.pdf (7.45 MB)
dirtwillfly|  楼主 | 2018-6-23 17:21 | 只看该作者
白皮书
Cities grow smarter through innovative semiconductor technologies.pdf (3.56 MB)
Robust traffic and intersection monitoring using millimeter wave sensors.pdf (1.67 MB)
dirtwillfly|  楼主 | 2018-6-23 17:22 | 只看该作者
IR16xx BoosterPack and DevPack Board Assembly Files.zip (8.34 MB)
IR16xx BoosterPack and DevPack Layout Files.zip (355.51 KB)
dirtwillfly|  楼主 | 2018-6-23 17:23 | 只看该作者
个人签名:欢迎进入TI MCU论坛      21ic TI技术交流1群:61549143(已满),  21ic TI技术交流2群:311421422 我的博客:http://blog.timcu.com/
1179
