关于光源追踪的程序问题
956|6
 楼主| Lewisnx 发表于 2018-6-30 16:04 | 显示全部楼层 |阅读模式
dc, ADC, AD, ADC1, TE
点光源追踪代码,是要在一个太阳能电池板上四个角安装四个光敏三极管然后根据光敏三极管产生的电压在单片机进行比较,从而控制电机偏转来跟踪点光源。但是现在烧录程序之后点光源不论怎么移动电机都不会偏转,求高手帮忙解决问题,过两天要用到了,急。。。多谢了!
#include "msp430g2553.h"
#define uint unsigned int
#define uchar unsigned char
unsigned int a[32],b[4];
unsigned int i=50,j=50;
void delay(uint z);
void pwm();
void circle();
void main( void )
   P1OUT=0x00;
   WDTCTL = WDTPW + WDTHOLD;
   BCSCTL1 = CALBC1_1MHZ;
   DCOCTL = CALDCO_1MHZ;
   pwm();
while(1)
   ADC10CTL0 = ADC10SHT_2 + ADC10ON + ADC10IE; // ADC10ON, interruptenabled
   ADC10CTL0 |= 0x0020;
   ADC10CTL1 = INCH_4;                        // input A1
   ADC10AE0 |= 0x10;                        // PA.1 ADC option select
   ADC10CTL0 |= ENC + ADC10SC;            // Sampling and conversion start
   __bis_SR_register(CPUOFF + GIE);       // LPM0, ADC10_ISR will force exit
   b[1]=ADC10MEM;
   delay(2);
    ADC10CTL0 = ADC10SHT_2 + ADC10ON + ADC10IE; //ADC10ON, interrupt enabled
   ADC10CTL1 = INCH_3;                        // input A3
   ADC10AE0 |= 0x08;                        // PA.3 ADC option select
   b[3]=ADC10MEM;
   delay(2);
   ADC10CTL1 = INCH_0;                        // input A0
   ADC10AE0 |= 0x01;                        // PA.0 ADC option select
   b[0]=ADC10MEM;
   delay(2);
   ADC10CTL1 = INCH_5;                        // input A2
   ADC10AE0 |= 0x20;                        // PA.2 ADC option select
   b[2]=ADC10MEM;
   delay(2);
    if(b[1]>b[3])
     if(b[1]-b[3]>150)
       CCR1=CCR1+i;
       delay(300);
       i=i+3;
    if(b[3]>b[1])
     if(b[3]-b[1]>150)
       CCR1=CCR1-i;
       delay(300);
       i=i+3;
   if(b[0]>b[2])
     if(b[0]-b[2]>150)
       CCR2=CCR2+j;
       delay(300);
       j=j+3;
     if(b[2]>b[0])
     if(b[2]-b[0]>150)
       CCR2=CCR2-j;
       delay(300);
       j=j+3;
void pwm()
  P1DIR|=BIT6;
P1SEL|=BIT6;
  P2DIR|=BIT4;
  P2SEL|=BIT4;
TACTL|= MC_1+TASSEL_2;
  TACCTL1= OUTMOD_7;
  TACCR0= 20000;
  TACCR1= 1000 ;
  TACCR2= 1000;
void delay(uint z)
uint i,j;
for(i=210;i>0;i--)
   for(j=z;j>0;j--);
#pragma vector=ADC10_VECTOR
__interrupt void ADC10_ISR(void)
__bic_SR_register_on_exit(CPUOFF);       // Clear CPUOFF bit from 0(SR)
CCompton 发表于 2018-6-30 16:19 | 显示全部楼层
仔细检查输出语句
Richardd 发表于 2018-6-30 16:28 | 显示全部楼层
应该与输出有关
Mattheww 发表于 2018-6-30 16:46 | 显示全部楼层
用的是ADC0809,貌似也有这样的问题
Erichk 发表于 2018-6-30 16:56 | 显示全部楼层
采到数据没有?还有就是光敏器件输出有信号没有呢?
dirtwillfly 发表于 2018-7-1 21:26 | 显示全部楼层
建议分模块分别调试
1、先看四个光敏三极管能不能识别到点光源,以及光线的强弱
dirtwillfly 发表于 2018-7-1 21:27 | 显示全部楼层
2、调试看电机控制是否正常,给定样本数据电机能否转到相应位置
