[资料分享] MYZR Android4.4.2 双屏异步APK 测试手册
177|0
 楼主 | 2018-7-4 14:14 | 显示全部楼层 |阅读模式
文档说明(document instruction)
系统环境说明(system invironment instruction)
  • 编译主机CPU架构:64位
compife CPU architecture of host:64 bit
  • 编译主机系统:Linux
compife host system:Linux
  • Linux发行版:Ubuntu
Linux release version:Ubuntu
  • Ubuntu版本类型:服务器版
Ubuntu version type:server version
  • Ubuntu版本号:12.04.5
Ubuntu version model:12.04.5
  • Ubuntu系统类型:x86-64
Ubuntu system type:x86-64
  注意:开发主机请使用ubuntu 12.04.5 x86-64(桌面版或服务器版均可),使用其他发行版的Linux或Ubuntu的其它版本可能会遇到的不必要的问题。
note:for host please use ubuntu 12.04.5 x86-64(either desk version or server version is ok),it may cause unnecessory problems if use other release versions of Linux or other versions of Ubuntu。 )
操作说明(operation instruction)
1)文档中以“$”开头的行,其后是Linux命令。
the lines start with “$" in document,will be followed by Linux command。
2)文档中所有的Linux命令建议手动输入到Linux主机执行(直接复制、粘贴到Linux主机上执行,可能会执行失败)。
it is recommended to enter manually all Linux commands in document to host for execution(direct copying,pasting to host for execution may cause a failed execution)。
3)文档中的Linux执行命令,如果空格后的下一个字符是“-”的(如:sudo apt-get –y install之类的),请手动输入到Linux主机执行(直接复制、粘贴到Linux主机上执行,通常会执行失败)。
in Linux commands in the document,if following space is “-”(i.e:sudo apt-get –y install such as),please enter manually to host for execution(direct copying,pasting to host for execution may cause a failed execution)。
4)文档中所有一行没写完的Linux命令请手动输入到Linux主机执行,(因为复制、粘贴命令不能包含类似“换行符”之类的特殊字符)。
for any line with unfinished Linux command in document,please enter manually to host for execution(because copying,pasting command can't contain special charaters such as“line break”)。
5)按文档输入并执行Linux命令时注意观察命令的执行结果与文档图片中的是否一致,以确认命令是否输入有误及是否执行失败。)
when enter and execut Linux commands based on document,please see if result of executing command is consistent with document image,to identify whether there was mistake of command input or a failure of executionx。
6)第一遍编译请严格按照文档进行,否则可能出现莫名其妙的错误。
please conduct compilation strictly based on document for the first time, otherwise some unexpected errors will occur.
截图说明(screenshot instruction)
为使视图看起来简洁整齐,截图中的命令提示符统一使用myzr$。
in order for the view to look neat and tidy为,please use uniformly all command prompts as myzr$。
图片中的Linux命令(Linux command in Linux image)
在文档的图片中观察“myzr$”开头的行可以直观的看到输入的Linux命令。
in document image obverve the lines started with “myzr$”,you can see visualy Linux commands inputed。
开发板接上1024X600的LVDS屏和接上1920X1080的HDMI屏,启动板子,进入U-BOOT控制终端。
connect 1024X600 LVDS screen and 1920X1080 HDMI screen with develpment board,boot the board,and enter U-BOOT control terminal。
预备工作(preparation)
1.设置环境变量
set environment variables
setenv bootargs console=ttymxc0,115200 androidboot.console=ttymxc0 vmalloc=400M init=/init video=mxcfb0:dev=ldb,bpp=32 video=mxcfb1:dev=hdmi,1920x1080M@60,bpp=32 video=mxcfb2:off fbmem=10M androidboot.hardware=freescale
2.把显示的视频复制到/data/app目录(需要biheng.mp4名字的MP4格式视频)
copy the vedio shown to /data/app directory(need video in MP4 format and named as biheng.mp4)
chmod 777 /data/app/ (串口终端)
chmod 777 /data/app/ (serial interface terminal)
adb push biheng.mp4 /data/app
3.安装APK软件
install APK software
adb install myzr_disp.apk
测试(test)
默认启动后如下图所示:
after boot with following default :
点击应用,出现以下界面:
click application,come out with following interface:
接着点击Show all displays选项,会出现以下界面:
then click option of Show all displays,come out with following interface:
先点上面的Button按键,出现对应屏的显示信息。(上面对应的是LVDS)点击可以返回。
press the top Button key fistly,information shown on the corresponding screen。(corresponding screen on the top is LVDS)click to return。
点击下面的Button按键,出现对应屏的显示信息。(下面对应的是HDMI)点击可以返回。
press Button key on bottom,information shown on the corresponding screen。(corresponding screen on the bottom is HDMI)click to return。
这里设置的环境变量以HDMI默认做为副屏的,可以点击HDMI的CheckBox选项实现播放视频的效果:
here set environment variables with HDMI as subpanel,click option of HDMI CheckBox to realize playing of video:
可以看到HDMI开始播放视频。如果再点击HDMI的CheckBox选项的话,就关闭视频。
HDMI start to play video。click the option of HDMI CheckBox again,then the video will be closed。
再重复点击LVDS的CheckBox选项:
then press once more LVDS的CheckBox option:
可看到显示的图片,按 返回,可以重新LVDS的CheckBox选项,图片是随机显示的。
can visialize image shown,press back,to LVDS的CheckBox option,image shown is random。
扫描二维码,随时随地手机跟帖
快速回复
您需要登录后才可以回帖
登录 | 注册
高级模式
我要创建版块 申请成为版主
论坛热帖
热门推荐上一条 /5 下一条
快速回复 返回顶部 返回列表
